Old 07-27-2004, 12:33 PM   #3541
treky11's Avatar
Originally posted by IDrinkNitro
Does anybody know of a good place to get the lightened two speed setup? I checked tower and I don't see it listed.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX1&P=7
treky11 is offline   Reply With Quote
Old 07-27-2004, 12:42 PM   #3542
IDrinkNitro's Avatar
Thanks for the link. That is wierd because I did a search on tower for hpi r40 and saw no trace whatsoever of the lightweight two speed
IDrinkNitro is offline   Reply With Quote
Old 07-27-2004, 09:53 PM   #3543
Regional Moderator
Darkseid's Avatar
Yeah, you gotta know how to search on Towerhobbies. You basically have to know exactly what your looking for, where to find it and what the part number is, its date of birth, Social Security Number, and blood type!
Kinda stupid huh?....If you knew where to find what you were looking for, why would you need their search engine.
I've told them that their search engine is a little anal. That it needs to be a little more user friendly. No changes yet though...
TLR 22...Tamiya F104...
Old 07-27-2004, 11:31 PM   #3544
straightsixers's Avatar
Default 2nd speed and Radio System Concerns
Guys two quick questions...
1. Do you guys have problems with 2nd speed engagement. I seem to be having problems moving from 1st to 2nd.
First when i had this problem, i reduced the tension of the springs onto the drum. THinking it was not engaging coz it was too tight but that didn't help. Suspected that the 2speed balls were worned out and got stuck to the screws therefore no rotation of the drum. Changed new balls but didn't really help. Now i've changed the spring tensioners thinking that the spring rate could be the factor and that helped. But the other day on the track i tried a new fuel and it didn't seem to engage again. Any similar experiences and remedy.
2. Radio
Need to clear some clouds here. Am thinking of getting 1 3pk real soon but can't make up my mind bet HRS and PCM. What's the diff and advantages/disadvantages? Have heard that the fail safe feature does not work with HRS - is this true??
Thanks in advance budds.
HPI R40
Novarossi NSR512S5 - novarossi P7 turbo plug
Team Magic Turbo Outlaw In-Line Pipe
straightsixers is offline   Reply With Quote
Old 07-27-2004, 11:48 PM   #3545
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
If you get the 3PK HRS, you gotta fetch out the wallet and dig deep for some digital servos.
DOMOisCOOL is offline   Reply With Quote
Old 07-28-2004, 02:27 AM   #3546
But aren't the Futaba S9451 servos that come with the radio digital servos already??
Old 07-28-2004, 07:48 AM   #3547
Regional Moderator
Darkseid's Avatar
The 3PK doesn't come with servos Its just Transmitter and receiver.
Old 07-28-2004, 08:43 AM   #3548
treky11's Avatar
Default Re: 2nd speed and Radio System Concerns
I have the 3PK and love it.
HRS does have failsafe and it works fine. It has saved my car from interference and low battery.
Yes its pricey but worth every penny in my book.
Old 07-28-2004, 09:52 AM   #3549
X-Garage's Avatar
Can I use FUTABA 3PK with Airtronics receiver?
X-Garage is offline   Reply With Quote
Old 07-28-2004, 11:16 AM   #3550
Trader Rating: 16 (100%+)
As long as they are in the same freq and channel, it is a YES...however, it does not have the build-in failsafe...for me, that is a well $80 to spend....saved me several 60 mph head on....
Old 07-28-2004, 11:18 AM   #3551
LOL.........well said.....I tried to do the PRO4 search, the HPI PRO4 didn't even show up......because it is called PRO (SPACE) 4....
Old 07-28-2004, 11:22 AM   #3552
2. Radio
3PK with PCM receiver DOES have failsafe build-in, just like the 3PK with HRS receiver.....HRS = high respond system, must use ONLY digital servo......and what it does is it transfer signal 3 times faster then regular....
However, no human being can tell how fast is 3 TIMES faster on signal transferring......but I can tell how fast is digital servos and how $$$$ they are for sure...
My opinion....to save money, get the PCM receiver and some high torque servo and high speed servo....if money is no object, get the HRS and S9550 and S9451
Old 07-28-2004, 12:32 PM   #3553
DOMOisCOOL's Avatar
No, since Futaba and Hitec use different shift (I think it was negative), than JR/AIR/KO.
Old 07-28-2004, 12:39 PM   #3554
X-Garage's Avatar
Do you mean connector?..
Old 07-28-2004, 12:48 PM   #3555
DOMOisCOOL's Avatar
No, different shifts.
Check out the receiver in the pic. You notice that Hitec/Futaba are different from the rest.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
