Old 07-23-2004, 07:42 AM   #3526
crazy_azz_mat's Avatar
thaxs andy.....wat do you have planned for the alfa body?
crazy_azz_mat is offline   Reply With Quote
Old 07-23-2004, 09:18 AM   #3527
Regional Moderator
Darkseid's Avatar
Stoneman said it perfectly. Tools needed will be.
-Rotary tool w/ various bits
-maybe a small rounded file for fine work
-some fine grit wet/dry sand paper to smooth everything out
-some CA and Q-tips to seal up the edges of the graphite where it was cut
-PATIENCE!!! Just remember, you can always take more material off, but you can't put back on!
Please don't forget to wear a breathing mask of some kind and work in a ventalated area. Probably a good idea to keep the kids and pets away from the area as well! And as soon as your done, clean up the area. Clean the work surface with a wet cloth and vacuum the floor. That graphite dust is nuthin' to get lazy with on the clean up, once it goes in the body, it doesn't come back out!
I've already got the picture sized pretty close to perfect. Now I just have to print it out. I'll be picking up the hollow shafts and lightweight chassis this weekend, so I'm going to have the car pulled apart anyway, so I figured I'd wait till then to make my attempt.
TLR 22...Tamiya F104...
Old 07-23-2004, 10:25 AM   #3528
BF
Check out your shells as well.
I see a 40 gram difference between the heaviest and lightest shells here.
It's gotta be paint.
BF is offline   Reply With Quote
Old 07-23-2004, 10:44 AM   #3529
Trader Rating: 16 (100%+)
Originally posted by Darkseid
I think instead of dumping $48 on theirs, I'll simply modify mine. I'll simply resize, print, and trim the pic I have until it works as a guide for where to cut/drill my current upper deck. I've done stuff much harder than that before, so this wont be too much work.
Thats $48 I can spend somewhere else!
I think if WEIGHT is the issue that ppl want to concern on the radio deck, the stock carbon deck has plenty of room for you to DRILL HOLES and save weight...that will save you good $45....and pobably ended up lighter then this LW radio deck.
Old 07-23-2004, 07:25 PM   #3530
IDrinkNitro's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...910898639&rd=1
Does anybody know anything about this eagle racing stuff? These mounts look similar to the hpi mounts. I am not familiar with this company. Anybody using this stuff??
IDrinkNitro is offline   Reply With Quote
Old 07-24-2004, 03:07 AM   #3531
HPIRACER310's Avatar
Has anyone released a better steering servo guard yet?
HPIRACER310 is offline   Reply With Quote
Old 07-24-2004, 04:41 AM   #3532
PSI Racing's Avatar
I know Integy sell Eagle Racing parts.
PSI Racing is offline   Reply With Quote
Old 07-24-2004, 06:21 AM   #3533
rowveg36's Avatar
Trader Rating: 21 (100%+)
does anybody here tried a proline vauxshall astra on their r40? hows the handling of it?
rowveg36 is offline   Reply With Quote
Old 07-24-2004, 01:01 PM   #3534
i was going to get the r40, but I was like nawww...I got my nitro rs4 2 and I dont race. dont reply to this or you'll be talking to yourself
viperracing is offline   Reply With Quote
Old 07-24-2004, 05:29 PM   #3535
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Thanks for sharing....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-25-2004, 04:08 PM   #3536
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
quick question how the heck do you get the 2nd gear pinion of the clutch housing? I have the pinion wrench and a can of WD40. I've tried heating it as well as freezing to no effect I'd like to get this stock gear off without destroying anything any tips would be much appriciated.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 07-25-2004, 04:33 PM   #3537
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Use two pair of channel locks one on the housing and one on the gear hold it tight enough so it won't slip I had the same prodlem
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-26-2004, 11:13 AM   #3538
Registered User
Put a piece of wire through the hole behind the 2nd gear, and twist the two ends of wire till they are close to touching the bell. Be careful not to go to tight or you may warp the part. Then get a pair of chanel locks, and twist.
P.S. It may be easier to hold the wire with another set of pliers as you are doing this.
Hope it helps.
2quick4you is offline   Reply With Quote
Old 07-27-2004, 10:42 AM   #3539
Regional Moderator
Darkseid's Avatar
Old 07-27-2004, 12:21 PM   #3540
Does anybody know of a good place to get the lightened two speed setup? I checked tower and I don't see it listed.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
