Old 07-15-2004, 11:10 AM   #3466
Regional Moderator
Darkseid's Avatar
Originally posted by nsxshogun
You mean just like Hara did correct.
Yeah, thats what I was talking about.
TLR 22...Tamiya F104...
Old 07-15-2004, 11:42 AM   #3467
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I want to remove the reciver box but where would I put the reciver.
it go's on the throttle servo, the light weight radio tray has the c/f cut so there is nothing next to the throttle so the receiver can be brought up so it does not hit the track you have to cut the c/f if you don't have the light weight tray
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-15-2004, 03:29 PM   #3468
crazy_azz_mat's Avatar
theres a lightweight radio tray? how do i get me one of those?
crazy_azz_mat is offline   Reply With Quote
Old 07-15-2004, 04:01 PM   #3469
Regional Moderator
Darkseid's Avatar
Your best bet is to look at the over seas shops. Its one of those "coming soon" things that never quite 'came' to the US. Most of the other hop ups have made it here. But I haven't seen that one yet.
Old 07-15-2004, 04:01 PM   #3470
20 SMOKE's Avatar
http://shopping.rcmodel.com.hk
or try rcmushrooms ( i think that rite)
Jamie W
Old 07-15-2004, 04:11 PM   #3471
nope they dont have no lightweight receiver casing....has anyone taken out the reciever box and installed their rx on the servo? how much weight do you reduce from doing so? also has anyone taken out the battery box? Hara's car is like that........
Old 07-15-2004, 04:15 PM   #3472
20 SMOKE's Avatar
I have not much weight saved I thought I saw a top plate I have 2 R40's both have different top plates
Jamie W
Old 07-15-2004, 04:18 PM   #3473
20 SMOKE's Avatar
Originally posted by Frank McKinney
Someone made a list earlier in this thread, I've modified it a bit:
- Both Hollow shafts #33401 & #33402
- Graphite front and rear shocktowers #73089 & #73090
- Full set of Ti screws (#Z368 for the HPI set, Yokomo also makes machine-thread Ti screws, and you can use aluminum screws in low-stress areas to save some grams)
- Titanium turnbuckles (two 4 x 40mm, two 4-40 x 24mm)
- Super chassis #73924
- Light top deck (#33408, must order from Asia or just remove the receiver box, see below)
- 0.8 module gearbox #87173
- Heat sink engine mount #33405
- Graphite suspension arms (not sure if part # is different, the arms have been updated since initial release - if you have 2 sway bar mounts on the rear arm you have the new arms)
- Titanium pivotballs (#33426 for 2 or #33427 for 8)
- Titanium hingepins (not sure of brand/part #)
- Graphite steering drag plate (not sure of brand/part #)
- Graphite lower front suspension mounts (not sure of brand/part #)
- Graphite side brace #73104 or #73105 (thinner version)
- Lightweight HPI battery (#33410, order from Asia make your own, see below)
- Remove upper battery cover
- Front One-way #75026
- 9550 steering servo, 3003 throttle servo (or any low-profile servos)
- Airtronics (Sanwa) 211 RX or and micro-size receiver
- don't use the aluminum rear brace or upper deck mounts (that's my suggestion)
You can also save 40g by making a battery pack from 5 AAA NiMH batteries in 2 + 3 shape instead of a normal battery pack. Mount in the normal position.
You can also mount the antenna on the upper deck and attach the receiver to the upper deck or main chassis using silicone sealant or fiber strapping tape. This allows you to remove the receiver box.
Use an AMBrc personal transponder instead of a normal hand-out transponder. Instead of the plastic mount, you can use spare Lexan to mount it to the upper deck (might save a few grams if you don't use too much glue to hold it in place) or use silicone windscreen seal to attach it to the lower deck (next to the lightweight battery pack).
found this looking back this might help some of you
Jamie W
Old 07-15-2004, 04:27 PM   #3474
ummm.....i wonder where in asia he ordered it from? and wat company
Old 07-15-2004, 05:22 PM   #3475
20 SMOKE's Avatar
AMG or Fastharry will probably post it later Amg put everthing on a post but its been a while, nice avatar
Jamie W
Old 07-15-2004, 05:27 PM   #3476
StoneMan's Avatar
Wondering if any R40 racers will be racing here http://www.oneeighthracers.com/
in The Great Lakes Challenge. I would like meet some of you. There are very few R40's here and I've been reading and learning from this site. Haven't posted much. Seems every time I come up with a question it's been asked and answered in the past 100 pages.
StoneMan is offline   Reply With Quote
Old 07-15-2004, 05:46 PM   #3477
AMGRacer's Avatar
My R40 weighs 1730-1740 with body, tires, transponder etc ready to run. I actually am still running the receiver box. If you can get the list of hopups that I posted a few pages back then you can get a similar weight. I would recommend that you keep the RX where it is in the box, unless you like them to get dirty and get smashed. I ran my Kyosho RX in a similar positions to Haras and I was always nervous about it getting broken. Remember that Hara gets free RX units
AMGRacer is offline   Reply With Quote
Old 07-15-2004, 06:42 PM   #3478
and he also doesnt hit the boards as much as some of us do......
Old 07-17-2004, 06:40 PM   #3479
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
hey guys....
It looks like they are going to cancel the Edison race because of impending bad weather....
Didn't want you to drive for nothing..
I'll keep you posted about the next race..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-17-2004, 09:20 PM   #3480
Unhappy 'Break-In' Postponed 'til 8/15/04
Yep Harry's right... Unfortunately we have a 90% chance of heavy rain headed our way and decided to wait until the evening weather report was released before we made a final decision.
Tomorrow's scheduled Big Apple 'Break-In' race we regretfully have to postpone until Sunday 8/15/04.
Please accept our sincerest appologies for any inconvienience this may have caused any one.
Chavo Figueroa
Big Apple Racers
[email protected]
NitroHead is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
