Old 06-27-2004, 01:25 PM   #3301
bballer's Avatar
Hey r40 pilots, i am looking to setup my car, and i heard about the r40 pivot ball clips. Does anyone know where to get them?? Thanks
bballer is offline   Reply With Quote
Old 06-28-2004, 05:01 AM   #3302
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the pivot ball clips cone standard in the kit..
fastharry™ is offline   Reply With Quote
Old 06-28-2004, 05:05 AM   #3303
fastharry™'s Avatar
What have been some of the clutch mods you guys have been doing..
Is anyone running the stock clutch with a nova based engine that feels the clutch is working OK.....
When I say mods,I'm talking about even assembly changes to the the stoch clutch also....(like putting the shims in front of the thrust beaing)...
Also,has anyone noticed that in stock position,the bell does the rub the shoe slightly....when spinning the bell sith the engine on its "back"..?
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
Old 06-28-2004, 10:27 AM   #3304
Registered User
OB42TC3's Avatar
I have found several things with the clutch.
1. You most likely need to put shims between the inside bearing and the sg nut to keep the bell from rubbing the shoe.
2.Clearance to the chassis cutout for the flywheel, on some of my engines I had to remove the big washer behind the collet other wise the outside of the bell will hit the chassis= slip
This can also happen if the motor is aligned too far to the gear side. I think this has been my problem all along, but in the process I learned the fine points of setting up a Centax.
3. The red clutch shoe as with most cars is better than the slip prone black stuff
If assembled right the clutch is supposed to be great; it's nearly identical to the Mugen's.
OB42TC3 is offline   Reply With Quote
Old 06-28-2004, 11:12 AM   #3305
Trader Rating: 16 (100%+)
You are talking about the MUGEN RED clutch shoes....? Or the one from the ebay...? (I think they are from Delta)
Old 06-28-2004, 01:07 PM   #3306
YANMAN's Avatar
Trader Rating: 39 (100%+)
Default R40 2004
Does anyone know were you can get the 2004 version of the R40 in the States?
YANMAN is offline   Reply With Quote
Old 06-28-2004, 01:10 PM   #3307
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
They're not available here yet.
DOMOisCOOL is offline   Reply With Quote
Old 06-28-2004, 01:12 PM   #3308
bballer's Avatar
I know the clips come in the kit, but can i purchase them seperately? I have a g4
Old 06-28-2004, 01:17 PM   #3309
Hi,
I was wondering how the HPI nitro 200mm car feels compered to the Kyosho FW-05R or Asso Ntc3.
Does someone have drive all three dees cars?
How does it handle?
How is the speed, and acceleration?
Thank you in advandge
840918001 is offline   Reply With Quote
Old 06-28-2004, 02:09 PM   #3310
JLock's Avatar
Default Re: R40 2004
HPI has stated that this version will not be available in the states. If you want one, you have to go online and order it from a southeast asian distributor/store.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 06-28-2004, 02:17 PM   #3311
You can ask Fast Harry about his 2004 spec information....1 thing for sure, Rcmodel.com.hk listed there is one, but I knew they can only ORDER 1 for you from japan, they don't have any left in stock..
Since FH just got one from Jet Hobby, I am sure they have some instock....you have to buy from them and EMS over to US for you, and if you see his post on the last page, it is around $380 (shipped) and for that price, it is still $80-100 cheaper then upgrade your stock R40 to 2004 spec with lots of un-used stock parts....
Jets Hobby website is....http://www.jethobby.com/
It was listed on their front page.........
Old 06-28-2004, 02:22 PM   #3312
Trinity G4..? Why do you want to use those clip onto a G4...? One thing you have to find out for sure, pivot balls looks alike, but not necessary the same diameter..........
R40 clips (they called SPACER) are for the threaded part of the R40 Pivot ball studs.........as long as G4 using the same diameter thread pivot balls, you can use the R40 spacer......
Beside........I don't use those spacer on my R40 pivot balls...those are for default setting use only, if you have a setup system to setup your car, you don't really need that...
Yes, you can buy the clips seperately....HPI#73485
http://www2.towerhobbies.com/cgi-bin...?&I=LXFKE9&P=7
Old 06-28-2004, 02:43 PM   #3313
bballer's Avatar
Thanks, the pivot balls are the same size, and i am looking at a cheap alternative to a setup system.
Old 06-28-2004, 07:07 PM   #3314
Send a message via AIM to goldenboy
i just recently bought the 4 gear rear diff. and havnt installed it yet.. i was wondering what oil i should use?? i am also running the front one way if that helps any
goldenboy is offline   Reply With Quote
Old 06-28-2004, 07:15 PM   #3315
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Originally posted by goldenboy
30 to 50,000 Im going to try 30 first and go from there
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
