Old 06-09-2004, 04:31 AM   #3136
Send a message via AIM to goldenboy
i used to run the stratus, but now i am running the mazda 6, i love it. i am waiting to get the hpi aero 2 in, and i will try that out.
goldenboy is offline   Reply With Quote
Old 06-09-2004, 05:39 AM   #3137
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Re: 4 gear diff mod shafts
Originally posted by jscamry
hey all, I know that this was covered a while ago and that hpi makes a kit for the diff mod. But I searched on the forum and was not able to find the shafts that people were using to complete this mod, I do remeber that some were using ofna shafts but I was not able to recall which cars they were from.
thanks all Jason
did you want the kit?......Whick is what I would do...Its nice to have both diffs to tune the car...I'm running the 4 gear diff right now....and in a low traction situation,the car sometimes spins...
heres the link for the kit...
http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX3&P=7
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-09-2004, 09:59 AM   #3138
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Re: Re: 4 gear diff mod shafts
no I did not really want to the kit, i did not want to spend the $30 bucks for the kit. So which shafts can I use to make a 4 gear diff?
thanks Jason
jscamry is offline   Reply With Quote
Old 06-09-2004, 11:51 AM   #3139
rod_b's Avatar
Send a message via AIM to rod_b
Originally posted by stanky626
What bodies are you guys running out there? The Stratus seems to be the most popular around my home track.
Losi Alfa and Protoform Mazda 6 have been my 2 favorites right now.
rod_b is offline   Reply With Quote
Old 06-09-2004, 12:42 PM   #3140
what is the benefit of having the four gear diff?
Old 06-09-2004, 01:02 PM   #3141
rod_b's Avatar
More mechanical friction...more consistent diff action
Old 06-09-2004, 01:54 PM   #3142
Send a message via AIM to Proteus
you're killing me...
It's to adjust the roll center for the front upper arms. If you noticed that your kit came with two of those. They are to control the height of the rear portion of the front upper arm. Also, the kit came with two different rubber grommetts (sp?); the piece that fits into the bottom of the shock tower which holds the front upper arm hingepin. With the two different rubber pieces....you have three different positions where you can mount your arm, stock (low), center, and high. Use the corresponding rear pices to adjust the upper hingepin to keep the hingepin parallel to the lower hingepin. Hopefully that makes sense. And there you have it. I've tried raising the roll center by adding one rear shim plus using the other rubber piece. The car felt quite responsive but had no grip. I also tried angling the upper arm as I was using kickup on the lower arm. I ended up going back to the low roll center. That seemed to give me the most traction. I guess on high bite tracks where traction rolling is a problem, using a higher roll center up front would help. AND THERE YOU HAVE IT.
Proteus is offline   Reply With Quote
Old 06-09-2004, 03:02 PM   #3143
AMGRacer's Avatar
Nice pickup!
AMGRacer is offline   Reply With Quote
Old 06-09-2004, 05:58 PM   #3144
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
any one using the body post on the carbon fiber shock towers and what's the part numder the one's I have are to small can't find pins that work
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-09-2004, 07:54 PM   #3145
fastharry™'s Avatar
Now I can finally.......
Thanks bubba!!!!
Old 06-10-2004, 06:43 AM   #3146
Send a message via Yahoo to arsenal9102001
well i have been reading this hole thread now for about ten minutes. there are somethings that i just have no idea what you are talking about but that is cool i am still pretty new.
i have a question i am getting an r40 soon, but the thing is the engine. i was wondering if i could get some suggestions on some really fast and durable engines. and i also was wondering if you can fit a .15 size in it?
i am really stoked about getting the r40. can't wait to put it together and to start running it. thanks to who ever responds.
arsenal9102001 is offline   Reply With Quote
Old 06-10-2004, 11:03 AM   #3147
Trader Rating: 16 (100%+)
For the stock R40 shocks...........I just realized that there is only 1 SHOCK DAMPER(piston) for you to choose from (the standard 2 holes).........what if I need some bigger holes or smaller holes damper....? (or 3 holes, 4 holes or 1 hole option...?)
What is the HPI optional shock damper parts #...? Thanks....
Old 06-10-2004, 11:09 AM   #3148
Before you go too far, narrow down some options about your engine....
(1) How big is the track you are running...(usually, need to know the length of the straightaway)
(2) 3 port, 5 port, TURBO or NON TURBO..?
(3) How much $$$ you want to spend....
You can choose from OS TR ($120) to JP Nova MAX ($400 plus) engine.....so, you have to set a limit......but 1 thing for sure, I see ppl use OS TR engine beat some JP engine........but I also see the OS TR engine ppl cannot even touch those JP engine ppl (due to the large hugh track)....
If you are looking for BIG BLOCK 15 engine...forget it
R40 will fit those new 12 engine block's 15 engine, aka SMALL BLOCK 15 engine.........it use 15 engine parts in a 12 engine body, it is a little faster, but a lot more expensive....but you can choose the new OS 18, or Sirio 15 for around $160 each, or the RB V15 or Nova Rossi NS15 ($300 plus)........but my opinion, they are not worth it cause your track or your friend will think that is ILLEGAL (actually, under ROAR rule, it is illegal.)
Old 06-10-2004, 12:59 PM   #3149
hey thanks for the very good advice. i do not know what ppl means though( sorry). well i really do not run on atrack right now because i live in germany and well were i live there isn't much around if you know what i mean. i have a stadium truck right now which is fun as he!! and i now am looking for on road car. i have heard some real good things about hpi and they seem to be worth it. but it will be my first kit so i want to do it right. also any advice on radio gear would be cool. i am looking to race when i get out of the army and get back to the states. so right now i am looking for more wide open running. money not really an issue. but i want a really good reliable engine. so if i pay 300 or more it needs to last well if i don't jack it up of course but i am pretty good with tunning. thanks again for the advice!
Old 06-10-2004, 01:03 PM   #3150
TerraX's Avatar
Send a message via ICQ to TerraX Send a message via AIM to TerraX Send a message via Yahoo to TerraX
ppl=people
TerraX is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
