Old 08-27-2003, 06:26 PM   #301
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
ahh yes that would be the Logitech Navigator keyboard with "web wheel"
nice ehh?
regg151 is offline   Reply With Quote
Old 08-27-2003, 08:51 PM   #302
Omar's Avatar
Where did u get the red tires at they would look cool on my friends car
Omar is offline   Reply With Quote
Old 08-27-2003, 10:13 PM   #303
Do the red tires leave nice red skidmarks????
renjie is offline   Reply With Quote
Old 08-28-2003, 10:51 AM   #304
Default Re: VAUXHALL R40
Originally posted by front1wayFreak
Here's pics of my car
I have been running that body for the past 2 weeks and it is awsome. It has a ton of steering. Anyway what foams are you guys running on your R40's. I ran 35 42 this past weekend and it handle good but it was a little boogy out of the corners. I am going to 37 42 this week and see how it does. I just ordered the front 1 way from competition. They have a few parts in stock.
BallPy is offline   Reply With Quote
Old 08-28-2003, 02:31 PM   #305
Omar's Avatar
Talking
Im goin to try running 35 shore and 40 shore people at my rc track say speedmind tires are the way to.
Old 08-28-2003, 05:38 PM   #306
puma1824's Avatar
Send a message via AIM to puma1824
So I pretty much finished my car. Where are you guys locating your personal transponder and failsafe? I'm not sure where exactly I'm going to place both of those options.
Have any ideas for me?
-Puma
puma1824 is offline   Reply With Quote
Old 08-28-2003, 05:43 PM   #307
regg151's Avatar
the red tires are RdLogics all rubber tires they have been discontinued now for quite some time now.
and they don't leave red skidmarks.
Old 08-28-2003, 09:08 PM   #308
luketob's Avatar
It's not bad at all plus the looks is very nice in my opinion. I'm getting sick of stratus body . Btw nice car regg151..awesome paint job!
luketob is offline   Reply With Quote
Old 08-28-2003, 09:18 PM   #309
luketob's Avatar
HPI provides the plastic mount for transporder, there's a pic of it in my early post. And for for the failsafe, i think you can put next to the steering linkage on the upper deck where the batt. indicator on the pic of my car. Here the pictures...hope this helps
Old 08-28-2003, 09:53 PM   #310
puma1824's Avatar
The mounts (the 3 wings) are cut off my transponder. I don't like having my transponder hanging out. I was thinking about placing the transponder where you have your failsafe.
Old 08-29-2003, 10:17 AM   #311
Frank McKinney's Avatar
Hara used a 5-AAA battery pack (yes, a 700mAh pack) and put it in the standard place. There was enough room left in the battery area to put the transponder on the plastic battery cover. No interference and very well protected.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 08-30-2003, 06:16 AM   #312
HPIRACER310's Avatar
Default side belt tensioner
anyone having a problem with the side-belt tensioner. I thought I was tightening the assembly too tight; the bearings wouldnt spin at all. I think it would be better if part #75008a was threaded on the inside.
I have an old steering post from a racer2 I could use that's threaded on the inside, perfect diameter for the bearings, but its too long, and I dont want to go through the hassle of hacking it up with a dremmel if I dont have to. Does hpi make a part#75008a thats threaded.
any help or info is greatly appreciated.
HPIRACER310 is offline   Reply With Quote
Old 08-30-2003, 06:27 AM   #313
nevermind. problem solved.
Old 08-30-2003, 11:25 AM   #314
regg151's Avatar
Default replacement belts?
anyone know if there are any compatable belts out there? I just ran my first breakin tank and had the front belt shred on me not quite sure how since It never left the starter box, but I remember reading somewhere that the mtx-3 shares some similer parts to the R40 anyone know if the belts are similer?
Old 08-30-2003, 10:44 PM   #315
InitialD's Avatar
Originally posted by HPIRACER310
I also heard the thrust bearing (B033) has two different inner dimensions for the washers and should be installed with the bigger washer facing the motor. is this true?
Yes, all thrust bearings are of the same design on any car. Make sure you install the larger inner diameter washer first, the ball race and then the smaller inner diemater washer.
I didnt like the idea of using shims (Z695/Z825) to set clearance for the clutchbell, so I shimmed it from behind the flywheel.
You can usually do it either way. But shimming from the front makes life much easier Don't need to take out the flywheel in order to re-shim your clutch.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
