Old 06-02-2004, 04:51 PM   #3031
Originally posted by tranced
Ahh.. what a pleasure.
Finally got my ass out there to the closest reasonable track.
But one big problem.. 80% run 8th scales there.
Where is this track you speak of?
boom is offline   Reply With Quote
Old 06-02-2004, 09:26 PM   #3032
stanky626's Avatar
Originally posted by AMGRacer
It is an awesome upgrade. Follow Harrys link.
What you cannot really tell from the pics are that the silly big locknuts to hold the spurs on are removed, three screws are used instead, and the shoes themselves are around 50% smaller.
The stock unit is around 65g and the 0.8 module is around 45g. Thats 20g right off the rotating mass. I really felt it immediately.
The upgrade sounds good... the 0.8 gearbox will be my next upgrade, after I swap out my screws for alloys... or titanium screws.
AMG, just curious... if using the 0.8 module, can we still use our old spur and pinion gears? I noticed the 0.8 module comes with a 60 sized spur.
Kyosho RB6 - Tamiya 417X - Losi 5ive-T
SpeedtechRC.com
stanky626 is offline   Reply With Quote
Old 06-02-2004, 09:30 PM   #3033
treky11's Avatar
can't use any of the existing clutch or 2spd gears. the new one are a different pitch.
treky11 is offline   Reply With Quote
Old 06-02-2004, 09:41 PM   #3034
AMGRacer's Avatar
Yep Trekky has got it. Also the new pinions have a revised alloy that resists stone and rock damage to the gears far better than the original gears do. They are also hard annodised rather than just color annodised.
AMGRacer is offline   Reply With Quote
Old 06-02-2004, 11:49 PM   #3035
stanky626's Avatar
Default belt tension
What should the correct belt tension be on the center belt? And, would a loose belt cause the rear to spin out?
I was at the track tonight... and the rear was spinning out all night. It mainly spun out on acceleration. But, when i got home, I noticed the belt tensioner was loose.
SpeedtechRC.com
Old 06-02-2004, 11:52 PM   #3036
AMGRacer's Avatar
Default Re: belt tension
Theoretically yes it could. If the belt was so loose you were not getting drive to the front wheels your car was only a RWD and it might spin under power. I have experienced this from a belt breakage before, never from a slipping belt.
Old 06-03-2004, 10:18 AM   #3037
Registered User
OB42TC3's Avatar
Default clutch
What are the fine points of getting the stock clutch to work? I recently found that the sides of the weights have some rough flashing, cleaned it up and it seems to work much better. Also how much gap between the shoe and bell seems to work best. There are no shims called for in the manual between the inside bearing and the threaded piece, but when I build it like this the bell rubs the shoe. Can somebody that really knows what they are doing with a Centax go over their assmebly of this clutch in as much detail as possible?
OB42TC3 is offline   Reply With Quote
Old 06-03-2004, 10:32 AM   #3038
InitialD's Avatar
Default Re: clutch
You could refer to the Serpent one at mytsn. Although it is for the 710, the main principle behind the Centax assembly is the same.
Old 06-03-2004, 10:42 AM   #3039
Registered User
OB42TC3's Avatar
Default Re: Re: clutch
I know, I just want somebody's perspective on this particular clutch.
Old 06-03-2004, 10:52 AM   #3040
Send a message via AIM to goldenboy
ok i just took of my front end and then put it back on, and now i have no suspension travel at all, i think it is my front sway bar is holding it back, but i didnt adjust and thing, so i dk why it is different now. do you guys know anythings that might be makin it do this??
can anybody help me out on this
goldenboy is offline   Reply With Quote
Old 06-03-2004, 11:50 AM   #3041
Default Re: clutch
I like the clutch engage earlier for smooth acceleration, so I set the gap between 0.3 - 0.5mm. I don't use shims between the inside bearing and the threaded piece. The shims are only used on the flanged bearing to adjust the gap. I also loose the spring nut as much as possible. But I make sure the spring nut is not rubbing the inside bearing. Hope that helps.
wangcc61 is offline   Reply With Quote
Old 06-03-2004, 11:53 AM   #3042
loosen both the droop screws and bump stop screws and see if that helps.
Old 06-03-2004, 12:12 PM   #3043
it does help a little bit, but i didnt adjust anything while i was takin it apart, so i dont know why it wont work the same.
Old 06-03-2004, 12:49 PM   #3044
TerraX's Avatar
Send a message via ICQ to TerraX Send a message via AIM to TerraX Send a message via Yahoo to TerraX
Check to make sure you have the rubber bits that fit into the front shock towers in correctly. They are oval, but one end is up and the other down. There is a little dot on the rubber pieces that faces the front of the car. The dot should be down.
Good luck.
Chris
TerraX is offline   Reply With Quote
Old 06-03-2004, 12:58 PM   #3045
nope, thats not it, they are in correctly
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
