Old 08-25-2003, 12:29 PM   #286
Puma,
I used the following at the rear:
3mm Lower Hingepin Front Spacer
2mm Lower Hingepin Rear Spacer
so far, nothing to dislike on it's handling or it's ability to handle.
However, I have noticed on my kit the need to glue (w/ silicon or something like it) the king pin ball nuts. They came loose on the front while I was using the car to break in a motor.. so it didn't take much for them to work themselves loose. Also, the rear camber links seem to have more play than I'd like.
Has anyone else seen what I have or is it just my kit?
tinman is offline   Reply With Quote
Old 08-25-2003, 02:23 PM   #287
HPIRACER310's Avatar
I agree the rear camber links have more play than I would like.
Thanks for the heads up on the king pin nuts. it might have something to do with the uprights being pre-threaded.
I also heard the thrust bearing (B033) has two different inner dimensions for the washers and should be installed with the bigger washer facing the motor. is this true?
I didnt like the idea of using shims (Z695/Z825) to set clearance for the clutchbell, so I shimmed it from behind the flywheel.
I have a Novarossi TOP installed, turning the carb to clear the gas tank wasnt a problem. the idle screw doesnt hit the motor. I'm more worried about being able to fit a screwdriver in there to adjust it.
If the plastic bumper was going to be that wide, it should have been wider to protect the front wheels better.
HPIRACER310 is offline   Reply With Quote
Old 08-25-2003, 04:26 PM   #288
I must have not moved it to the right as far.. (just enough to get decent access to the low-speed needle) because I still have plenty when getting to the idle screw.
Good idea on the clutchbell clearance and I'll have to check on the thrust bearing washer..
Old 08-25-2003, 05:51 PM   #289
HPIRACER310,
is that the kit with aluminum shocks and one-way? if so, who has it and do they sell the one-way by itself?
Old 08-25-2003, 09:31 PM   #290
HPIRACER310,
tinman, I have the U.S. version. The aluminum shocks you see in my pic are from my retired RS4-2. So, I am also looking for the one-way. here's a link for part #s on upgrades:
http://www.hpiracing.co.jp/contents_...up_e/0307.html
Old 08-25-2003, 11:32 PM   #291
Default one-way
I just checked hobby people's website, they already have the one-way listed (part#75026) but no price yet to order it, so it wont be long til they or local shops should have them in stock.
http://www.hobbypeople.net/mfr/hpi02.asp
Old 08-26-2003, 09:21 AM   #292
Smile Parts
Hi guys
I went to Jet Hobby in Hong Kong today. They just got in a new shipment of R40 parts. I got some pinions and spurs and some spare belts. I'm not really sure if they have the one ways or alloy shocks (I have the racer kit so didn't ask) and and all the parts were still in the big box........ I guess I went to hk on the right day.
From memory their website is www.jethobby.com
P.S. the pinions are all colour coded :-)
renjie is offline   Reply With Quote
Old 08-26-2003, 09:06 PM   #293
luketob's Avatar
Default Puma1824
Hey puma1824,
Sorry for a fuzzy pic. Cheap camera
luketob is offline   Reply With Quote
Old 08-26-2003, 09:08 PM   #294
luketob's Avatar
oopss..here it is
Old 08-26-2003, 09:10 PM   #295
luketob's Avatar
Default VAUXHALL R40
Here's pics of my car
Old 08-26-2003, 09:10 PM   #296
luketob's Avatar
Old 08-26-2003, 09:12 PM   #297
luketob's Avatar
Old 08-26-2003, 09:15 PM   #298
luketob's Avatar
last one...
Old 08-27-2003, 04:57 PM   #299
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
nice I like it.
here's mine
regg151 is offline   Reply With Quote
Old 08-27-2003, 05:32 PM   #300
EdwardN's Avatar
Originally posted by regg151
nice I like it.
here's mine
I don't see very well, my monitor is bad, on what chasis this body on?
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
