HPI R40 Nitro Car Forum
#2971
Here is a shot of the graphite rear arms. Notice the additional droop hole and the second position to attach the swaybars (used by Hara at the ROAR nats)
#2972
Here are the graphite arms, better shot.
#2973
Super chassis + graphite arms all around.
#2974
Top down view, can see the nice top deck.
#2975
#2976
#2977
hpi r 40
if anyone is interested, i have a r 40 for sale with air94737 and air94357 servos plus a 1100 mah batt and also a .12r xs motor with two tanks run thru it, please pm me or email me. serious inquires only thanks
#2978
ive always found rear toe is the best way to adjust the rear
3 degrees gives it a really stable high traction rear end
i use 2 degrees for the extra steering
between 2 and 3 makes a huge difference at least on my car
are you talking about when racing at olde town because when i was there there were some really rough spots in the corner that would loosen the rear up alot and adding droop and ride height helped alot
#2979
Originally posted by Proteus
Nice car. Looks almost like mine. The only thing different is that I run AE springs and in the car right now I'm breaking in the V12 5 port Murnan mod. The only thing I have left to add is the Kawahara micro clutch. I'll try to post pics some time this week. BTW....what setup are you running?
jason
#2980
Originally posted by jscamry
how is it going protues, thanks for the tip on using ae springs on the r40..
jason
jason
#2981
#2982
no i wasnt there i was at DRCW at the nitro offroad regional part 1
i raced olde towne earlier this year before dougs started like march and those rough sections were really tough to control and also tough on tires
thats why i usually only race at dougs
but at the olde town race i was talking to nigel and he mentioned he was using 8-9mm ride height
try the rear toe though first if your using less than 3 degrees try that and see how you like it
#2983
yah i will try more toe in. i raised my ride hight to 6mm, i will try that out.
i am gonna try to go up to dougs, not this sat, but the next.what kind of show up do you guys get at dougs? how many nitro touring mains are there?
#2984
As scary as this may seem I am running almost a dead stock setup. The only changes I have made are:
50wt front shock oil and 40wt rear.
Rear swaybar on outer lower linkage.
4 gear rear diff with 30K oil.
-3 front droop and 0 rear.
5mm ride height.
40 shore Monotuning tires at 59mm all around.
Mazda 6 body.
The stock setup is just so dang great I have not bothered to go away from it except for a few tweaks for our higher grip course.
#2985
My V12 is just a 3 port, but hey it hammers
5mm ride height.
Mazda 6 body.
5mm ride height.
Mazda 6 body.
