Old 05-24-2004, 02:20 PM   #2956
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Originally posted by goldenboy
ok , that is the exact problem i was having, what kind of servo do you have? maybe my servo is too tall or something, so it is farther out
I have the JR metal gear servo that comes with the XS3.
DOMOisCOOL is offline   Reply With Quote
Old 05-24-2004, 02:42 PM   #2957
Send a message via AIM to goldenboy
hmm, i have a hitec digital mg, so i guess it isnt my servo that is doin it. i know people where there arm is like 3mm away from the upperdeck, and they did no sanding, but they said they didnt do anything special, so i dont know what is up with mine
goldenboy is offline   Reply With Quote
Old 05-24-2004, 02:55 PM   #2958
Post
does anybody know a trick to get the pinions off, without using a pinion wrench, i am trying to put on my .8 pinions but i cant get the old ones off , i have tried using vise grips, but then i cant keep a hold of the other part ( i dont no wat it is called, lol)
thanks
Old 05-24-2004, 04:00 PM   #2959
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I have the same stuff and don't have a problem with mine at all
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-24-2004, 04:02 PM   #2960
see that is what i am saying, i dont know how people do have a problem, then others dont at all, i wonder if the wholes for the servo mount pegs are cut differently? i dk?/
Old 05-24-2004, 04:51 PM   #2961
PTP Racing's Avatar
like i said maybe you should enlarge those holes
i use a hitec digital and its very close but works ok
once i noticed after a race though that my servo had moved slightly so i had to readjust it
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-24-2004, 05:03 PM   #2962
ok thanks, i didnt even see your earlier post
Old 05-24-2004, 05:15 PM   #2963
PTP Racing's Avatar
your in virginia huh
ever try racing at dougs
its the best track around
Jason Miller
Old 05-24-2004, 05:21 PM   #2964
i want too, but i havta race on sundays, and dougs doesnt race on sundays... i work at hobby hangar, so i work sats
Old 05-24-2004, 09:16 PM   #2965
what are somethings that i can do if my rear end is loose?
Old 05-24-2004, 11:12 PM   #2966
NCC
NCC's Avatar
[QUOTE]Originally posted by goldenboy
what are somethings that i can do if my rear end is loose? [
/QUOTE]
1. Softer rear tires
2. Taller rear wing
3. More rear toe-in
4. Use a rear swaybar
5. Softer rear springs
6. Lighter rear diff oil.
I could probably go on and on. These are
Just a few ideas of things you can try. Maybe
if you give a more detailed scenario along
with your set up such springs,tires etc. we
may be able to spot the problem.
NCC is offline   Reply With Quote
Old 05-24-2004, 11:29 PM   #2967
AMGRacer's Avatar
[QUOTE]Originally posted by NCC
/QUOTE]
2. Taller rear wing
3. More rear toe-in
Good call. We need more info as to where the rear end is breaking loose and details on your setup.
AMGRacer is offline   Reply With Quote
Old 05-25-2004, 04:34 AM   #2968
ok, i am running 50 weight shock oil, with the hpi white springs, i am at negative 4 camber, my shocks are in the third hole (the farthest i could lay them down), i am running 37sh foams, and my rear diff oil is mugen 3000, i have towed it in a little bit.
Old 05-25-2004, 05:30 AM   #2969
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Since I've seen a few STOCK set up r40's run so well(including mine)......and thats in 60 or 100 degree weather,I'd return that car to stock settings...including the black PROPER LENGTH springs....30,000 diff fluid in back,5.5 ride hgt on 60 mm foams..2 degrees camber front,3 in back....3 degrees toe in rear..0 in front........(I'm running 2...but I like the way it turns)...40 shore fronts....37 or 35 rears......
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-25-2004, 06:55 AM   #2970
AMGRacer's Avatar
Truely I would do like Fastharry says and go back to stock settings. Your settings seem pretty far from standard. You really need to drive the car standard and adapt your driving to it a bit before messing around too much.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
