Old 05-13-2004, 10:04 PM   #2821
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
thats cause I spend so much on cars ..its a 2 meg camera...
fastharry™ is offline   Reply With Quote
Old 05-13-2004, 10:05 PM   #2822
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by fastharry
30% Sidewinder World Championship formula....has a thinner oil in it that Greg Degani really liked....throttle transition is GREAT...
We have a 100 ft strait...and this car loses NOTHING to a nitro tc3 RB 5 port in a drag race.....from a standing start...
you took off the.1 shim correct?
Old 05-13-2004, 10:08 PM   #2823
Super Moderator
Marcos.J's Avatar
how about the old fashioned way..
hey Harry here is your other photo
Old 05-13-2004, 10:14 PM   #2824
fastharry™'s Avatar
yes
Old 05-13-2004, 10:16 PM   #2825
Super Moderator
Marcos.J's Avatar
yes
thanks , last question , did it improve performance with the shim out? thanks
Old 05-13-2004, 10:23 PM   #2826
fastharry™'s Avatar
yes
Old 05-14-2004, 07:40 AM   #2827
PTP Racing's Avatar
i sliced and diced my car up last night finally removing some weight
switched the regular 1100mah pack out in favor of a 720 mah AAA pack heck i even stripped the heat shrink since my plan was to secure it to the tray with electrical tape
ditched the top of the battery box and the handle
then i took the bottom off the reciever box drilled a new antenna hole and secured the reciever the the top of the reciever box which i bolted to the upper deck
also i drilled a few holes under the engine and in the front bumper
i cant wait to weigh it now
im going to get the hpi lightweight chassis next
i want to drill the 2 speed housing but im afraid i may knock it out of balance
trophy race this weekend hope this helps (even if only slightly)
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-14-2004, 11:48 AM   #2828
TerraX's Avatar
Send a message via ICQ to TerraX Send a message via AIM to TerraX Send a message via Yahoo to TerraX
Default Magic Blue Canister???
here it is for you harry
I don't think I know what the little blue canister is nestled next to the fuel filter. What is it?
Chris
TerraX is offline   Reply With Quote
Old 05-14-2004, 11:50 AM   #2829
treky11's Avatar
Default Re: Magic Blue Canister???
Chris
Its a boost bottle inserted into the exhaust line to attempt to regulate the pulsations in the pressure and deliver fuel at a more constant rate.
treky11 is offline   Reply With Quote
Old 05-14-2004, 01:16 PM   #2830
NCC
NCC's Avatar
PTP, you have no excuses for this weekend. You should be atleast 70grams lighter. I must try to defend my trophy race title from last year. Last year I ran my r40 bone stock except for the oneway. Currently I think I'm overpowering my r40 so this race I will be tuning down my motor. I'm spinning tires out the turns and once in a while I over shoot so I'm going to go for consistancy on this big race. Also, I'll be trying out the new Aero2 for the first time. It looks so much sleeker than my Losi Alfa so I can only imagine faster lap times.
I know proteus is set and ready
-LILROBBY are you still having engine problems? I highly recommend the ostr turbo. Plenty of power and reliable as hell.
NCC is offline   Reply With Quote
Old 05-14-2004, 01:58 PM   #2831
Default i to am running the stratus 2 body
whats up nigel i to am running the new stratus body looks verry streaky should be good im looking to step up this week after a dissapointing loss that im trying to forget
fastntc3 is offline   Reply With Quote
Old 05-14-2004, 03:23 PM   #2832
Exclamation R40 Setup sheet
Hey guys,
I am searching for the R40 setup sheet. The one on the HPI site need japanese language and came out with missing parts. Anyone have it somewhere?
Frag is offline   Reply With Quote
Old 05-14-2004, 04:49 PM   #2833
NCC
NCC's Avatar
Default fastntc3=Rob?
Old 05-15-2004, 01:06 AM   #2834
tranced's Avatar
Anyone know if there is a way to give the front tires a tiny bit of overdrive so that the front and rear tires wear at the same rate? My rear tires are consistantly smaller then the fronts after a long day of running..
tranced is offline   Reply With Quote
Old 05-15-2004, 01:39 AM   #2835
Super Moderator
Marcos.J's Avatar
cut the front tires about 1mm smaller than the back.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
