Old 05-03-2004, 08:59 AM   #2716
PTP Racing's Avatar
fastharry i didnt really notice much of a difference with the graphite towers
but handling isnt my issue
dont get me wrong guys i really like the r40 its been good enough to get me into the A main everytime i race
but i need to go a little faster and lightening is something that ought to help
fast harry your car is extremely light 1718g if i recall correctly what have you done to make it so light
legal min weight is 1725g right if i can get close i would be happy
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-03-2004, 11:00 AM   #2717
Registered User
OB42TC3's Avatar
What engine/pipe/fuel/gearing/tire diameter are you running?
Oh yeah and are the fast guys running one-ways? are you?
OB42TC3 is offline   Reply With Quote
Old 05-03-2004, 11:25 AM   #2718
PTP Racing's Avatar
roar legal slightly modified mt-12
rdlogics turbo 2 outlaw pipe
30% byrons fuel
changed 1st gear to 15t and 1 tooth larger spur
2nd unchanged from kit
60mm tires 37 shore front and rear
one-way
hollow 2 speed shaft
hollow midshaft
2 gear rear diff 30k mugen fluid
hpi graphite shock towers default shock location
55wt front
60wt rear
front sway bar soft
rear stock
stock springs
5mm ride height
standard 5 cell 1100mah battery
hitec digital servos
3pk pcm radio
weight w/fuel no body 1885g
thats my set-up it handles great just too slow
Jason Miller
Old 05-03-2004, 11:44 AM   #2719
rod_b's Avatar
Send a message via AIM to rod_b
30% byrons fuel
one-way
hollow midshaft
55wt front
60wt rear
front sway bar soft
rear stock
stock springs
5mm ride height
3pk pcm radio
I have almost all the same stuff you have but I also have the lightened chassis and mine is in the high 1700s.
Also, have you ever tailed one of the faster guys to see where they are making time on you. It could just be setup. I raced with a friend that was gaining seconds on me every lap. I noticed he was on the throttle so much earlier than I was through some of the turns. Even though my setup was planted, I changed it to be able to run like he did and was able to close the gap. Someone could make a fortune if they could invent a telemetry device.
Lastly, are you one of the "Top" drivers at your track. Some people will just be better than you no matter what you try. Not trying to put you down. Just stating that there is a reason why the Pros are Pros.
rod_b is offline   Reply With Quote
Old 05-03-2004, 01:34 PM   #2720
PTP Racing's Avatar
honestly i am finishing as good as i ever have
there are definelty faster guys than me
but if i dont strive to improve ive given up
and since my driving has been pretty good lately its time to look at the car to get faster
lightweight chassis is definelty something im looking to buy
also the lighter 2 speed and maybe titanium screws
and im going to order the smaller 700mah battery very soon
and if i had alot of money i would get a kawahara micro clutch and a 5port engine
Jason Miller
Old 05-03-2004, 01:51 PM   #2721
Originally posted by DOMOisCOOL
Thanks, do you know if they are open on Sundays?
Yes they are.
Frag is offline   Reply With Quote
Old 05-03-2004, 01:55 PM   #2722
Send a message via AIM to Proteus
PTP
Your car definately had power. The problem I noticed with your car (and mine) was that you weren't carrying enough corner speed. Was your car pushing into the turns? I had a real bad push. Last weekend was a bad one for me because I was trying to set my car up for two-three different setups. I had to mix and match tires that were between 56-58mm. I had only enough tires to run them once for qual. This weekend will be much different as I will have some tires. Also, I think your running to much diff wt. Try to back down to 10k. I had 30k with 4gears and I hated it because I had to really baby the throttle around the turns. With 10k, I was able to run the car harder. If you had seen NCC's car he definately had the corner speed and same with Mike. Even with the 04 edition, my car still weighs in at 1738 w/o body. I think NCC's car would have done better but he would overshoot a couple of turns. I talked to him and he even told me that when he started to ease off of the throttle his lap times got faster.
Proteus is offline   Reply With Quote
Old 05-03-2004, 02:50 PM   #2723
PTP Racing's Avatar
proteus i think your right i wasnt carrying enough speed through the corners im not really pushing though do you think 10k would give me more steering?
i think because of the weight i have to go a little slower
i didnt have as much power as you did i kept noticing you gaining on me rapidly
also i think the weight is making it slower out of the corners
my tire situation was poor also all i had when i got there was a set of used speedmind 37 and the fronts were almost 60 but the rears were probabaly 58mm or smaller also ive found i have to rotate the rear tires side to side after each qualifier or the left rear wears out way too fast that sweeper off the straight is a tire eater
Jason Miller
Old 05-03-2004, 03:12 PM   #2724
rod_b's Avatar
I think you'll be greatly disappointed when your lightened car does not make a huge difference if this is the case. 100 or so grams is not gonna put any kind of load on an engine with 1+ hp
Old 05-03-2004, 04:16 PM   #2725
Send a message via AIM to goldenboy
does anybody know anyone who makes a graphite transponder holder, and where i can find one. .... if not, does anybody know where you can buy a piece of grpahite so i can make one, it isnt so much for the lightness, but for the look
goldenboy is offline   Reply With Quote
Old 05-03-2004, 04:46 PM   #2726
PTP Racing's Avatar
i hope its not a huge disappointment but i can definelty see where your coming from
im not really looking for a huge difference though
but im sure it will make some difference
Jason Miller
Old 05-03-2004, 05:31 PM   #2727
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default lightweight issues.
I agree..lucky if it is 1/10 sec a lap.
J.Gonzalez is offline   Reply With Quote
Old 05-03-2004, 06:38 PM   #2728
Trader Rating: 74 (100%+)
Default Ti Screw Kit
Originally posted by PSI Racing
I think HPI is coming out with a titanium screw kit for the R40.
Try this link.
http://shopping.rcmodel.com.hk/produ...oducts_id=4057
I have purchased the kit from RC Model, its a great kit. It is very light compared to the original hardware. It is also is made with 2mm hex screws, all coarse screws, where they call for coarse, and machine screws where machine screws call for.
I think it is a worth while investment.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 05-03-2004, 08:52 PM   #2729
are they all counter sunk, or are they only counter sunk where they call for counter sunk??
Old 05-03-2004, 09:33 PM   #2730
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default 2 speed clutch shoes
hey all, I was wondering, what is the best way to thread the grub screws into the 2 speed clutch shoes? The reason that I ask is that when I was building the car; I guess that I did not have the grub screws centered and the shoes cracked. So i had to use a buds clutch shoes untill mine new ones came in......
thanks all Jason.
jscamry is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
