Old 05-01-2004, 08:00 PM   #2686
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Tranced,mine is 8mm....that's good for 2 degrees camber..BTW<I hate my hudy set up......I use a combo set up guage from my nitro tc3,and a hudy ride ht and droop blocks to set to the car up...I adjust rear toe just like I did on the tc3...stand the car on its tail,pop the guage next to the wheel,and its done..I use it for camber also,,front and back...the only thing you really need the set up for is front toe.....and I do that by eye( I remember reading in an old Vector set up book that front toe is the easiest adjustment to do by eye).....
fastharry™ is offline   Reply With Quote
Old 05-02-2004, 12:47 AM   #2687
AMGRacer's Avatar
Originally posted by fastharry
AMG..have you tried the 4 gear rear yet?.......Thats my next step...
BTW,I just picked the 9550 servo..very sweet.....Futaba also makes a 3010 servo.......90 oz of tq......and a .16 transit time....Top ball bearing.....and get this...weighs 41 grams...only 23 bucks......might make a great throttle servo..esp with the high tourque.....and LOW weight....
Yes I have been running the 4 gear rear for a few months now. The problem I had with the 2 gear rear was that the diff became inconsistent. After around 10 tanks or so it lightened up significantly until you rebuilt it. Wierd.
That servo combo you mentioned is exactly what I am using. Works unreal.
AMGRacer is offline   Reply With Quote
Old 05-02-2004, 12:51 AM   #2688
AMGRacer's Avatar
Originally posted by tranced
AMGRacer can you tell me the width of your rear camber turnbuckle link (as seen in instruction manual specification: "6mm")? The length im looking for is from the inside edge of one ball cup to the other.
Stock, as you said earlier, is -6 degrees, which is very much obscene.. you said you had -3, which is what i'm shooting for, i have an outdated hudy setup so i have to go by measurements, etc..
if you can get that length for me, its much appreciated.
Around 8.3 to 8.4mm if you are using the graphite rear tower and the starting position they mention in the instructions.
Old 05-02-2004, 03:25 AM   #2689
What kind of carbon shocktowers are you using 3racing och HPI`s ? And where can i get spurs pinions and clutchparts for the R40 ?
Mange is offline   Reply With Quote
Old 05-02-2004, 04:57 AM   #2690
fastharry™'s Avatar
After seeing the results with HPI's towers(esp. the rear one with the lower arm standoff's), I WOULD NOT use any other brand...
BTW,I might have the gear stuff for sale...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
Old 05-02-2004, 09:12 AM   #2691
Send a message via AIM to goldenboy
i use the hpi one also, and everybody i know uses the hpi... so if i were you, get the hpi
goldenboy is offline   Reply With Quote
Old 05-02-2004, 09:40 AM   #2692
jrighter's Avatar
Any hop ups that are a must have for the R40? I'm sure they are listed but 90 pages is alot to sort through. Thanks in advance!
jrighter is offline   Reply With Quote
Old 05-02-2004, 09:46 AM   #2693
graphite shock towers, and umm that it is about it.. pretty much anything that will make it lighter, lightwieght shafts, .8 tranny..... and depending on your driving style you might want the front one way.
Old 05-02-2004, 10:11 AM   #2694
BTW,anyone kmow where to get a lightweight battery pack?...Trinity has them,but not in the flat style...
if you want light... get a LiPoly (lithium polymer), i work at a hobby shop and all the plane guys put them in there planes because they are lightest things out right now, and they also get the longest runtime. so if you are only using it as a receiver pack then it will last a long time. they are pretty expensive, and depending on what charger you have, a charger is really expensive also.
Old 05-02-2004, 10:46 AM   #2695
NCC
NCC's Avatar
PTP/Fastharry the rd logics pack retails for $19.
NCC is offline   Reply With Quote
Old 05-02-2004, 11:43 AM   #2696
PTP Racing's Avatar
what are you trying to say NCC?
just cause my car weighs 1885g you think i need a smaller battery
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 05-02-2004, 02:50 PM   #2697
tranced's Avatar
OH please.. can we stop complaining about the weight?
Sounds like its affecting your sanity more then your laptimes people!
tranced is offline   Reply With Quote
Old 05-02-2004, 04:44 PM   #2698
for about a 110 ft straight away, what spurs/pinion gears would be the best to run ??
Old 05-02-2004, 04:52 PM   #2699
PTP Racing's Avatar
no i cannot stop complaining about the weight its 1885g for crying out loud
ask NCC and proteus i can run a damn near perfect line for an entire race and still be a full second per lap slower than most everyone else
and yes i know there are alot of other things that could be causing my somewhat slow laps but honestly i think its the fact im pulling nearly 200g more around the track than most of my competitors
goldenboy i am using the stock gearing for 2nd and went down 1 tooth on the 1st gear pinion to 15t and up 1 tooth on the 1st gear spur our track is about 120ft but it depends on your engine also
Jason Miller
Old 05-02-2004, 04:58 PM   #2700
i am running a novarossi s3
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
