Old 04-29-2004, 03:35 PM   #2641
Send a message via AIM to goldenboy
thanks, i will def. be getting that soon
goldenboy is offline   Reply With Quote
Old 04-29-2004, 04:00 PM   #2642
since the r40 is what you call "heavy", does anybody know the actual weights of the competitive cars ( r40, mtx3, tc3, 710/05). i want to know actually how much heavier the r40 acutally is?
also what kind of mods have you done to the r40 to make it lighter, with out adding new parts.... like shaving down things, or putting the dremel to the car.??
Old 04-29-2004, 04:30 PM   #2643
Default A lighter R40 file
On my case, I'll try to switch to graphite as much as possible. I didn't shave parts though, I will not do that. I know that some guys completly removed the batterie and receiver case. They sticked the electronics with servo tape under the radio case to keep a clean look.
Some others remove parts like the handle and the foam bumber. With all those parts out, you save another couple of grams.
But I will not go that far. I'll stick with graphite parts, no shaving and removing. In my case, since I am not the greatest driver of all, it will be overkill.
But I am interested to see what other guys did to save some weight.
Frag is offline   Reply With Quote
Old 04-29-2004, 04:35 PM   #2644
hmm the electronic thing is interesting. but i have gotten the graphite shock towers, and the graphite side plate. but i also added some aluminum so it is prolly right around the same weigth i had started
i aslo cut the lower front arms, where the shaft slides though, so that there is better suspension travel and i lose some weight
Old 04-29-2004, 04:55 PM   #2645
I would say that if you feel serious about cutting weight, your next step would be to replace the middle and the 2 speed shafts for the lightweight version + the new 2 speeds transmission.
I would keep those alloy parts out too, but it's your car
Old 04-29-2004, 05:00 PM   #2646
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Hey Frag, you gonna race on Sunday at Cambrian? Ill be there to watch probably.
Also, do you go to Ultimate Hobbies? Do they carry Sidewinder fuel?
Thnx
DOMOisCOOL is offline   Reply With Quote
Old 04-29-2004, 05:28 PM   #2647
PTP Racing's Avatar
i am also planning on starting to shave some weight from my r40
first thing i did was swap the front diff for the one-way then the 2 speed shaft and mid-shaft were replaced with hollow units
now ive gotten the graphite shock towers
next will be a graphite side brace and switching to the smaller mtx3 style reciever pack and maybe titanium screws and the new 2 speed is a must have not for .8 gears but for weight savings which are especially beneficial from rotating parts
but ive been told there is alot of weight that can be cut out of some of the plastic pieces like the cover over the front belt and since when i bought the knuckles it came with a complete bulkhead i see no reason not to drill them out and see what happens
my friend was pitting next to hara at nats last year and witnessed someone drill a large amount of weight out of the plastic parts from haras advice
my local track is run what you brung style racing the only rules being small blocks and sedan bodies so the competition is tough and i could definetly use any advantage i can get especially if its free
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-29-2004, 06:52 PM   #2648
HPIRACER310's Avatar
Originally posted by Thad Garner
-Chassis-
Stock 115.8g
HPI 73924 Option 93.1g
-2-speed-
Stock 60g
0.8m Light weight 87173 43.2g
Hope this helps
-t
Thanks!
HPIRACER310 is offline   Reply With Quote
Old 04-29-2004, 07:02 PM   #2649
Originally posted by fastharry
the HPI ones.....
Thanks, FastHarry.
Are you using the optional graphite parts for the rear shock towers... I dont know what they're called? The two extra pieces of graphite they give you with the rear shock tower.
I'm wondering if it has helped in the increased handling you spoke of.
Old 04-29-2004, 07:14 PM   #2650
fast harry was right on everyting, i got the new shock towers about 2 weeks ago and i raced last weekend and the car was just sooo much better, not really sure why the shock towers helped, but they did. also i run sidwinder prorace blend 30/10% and i will never go back to any other fuel, i love it now. i used to use monster, but now that =junk, and blue thunder has always =junk
amg, do you know when those parts are coming out, i already have the sideplate , but what about the tit. pivot balls?
Thats two positives for the shocks towers. Now I have to get them!
Old 04-29-2004, 07:24 PM   #2651
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by Frag
FastHarry,
did you installed the graphite shock tower in the default setting (as mentionned in the setup sheet comming with it)? Or you played around a little bit with the settings?
stock settings......Plastic shocks also,I might add..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-29-2004, 07:26 PM   #2652
fastharry™'s Avatar
Originally posted by HPIRACER310
Thanks, FastHarry.
Yes I am......If its good enough for Thad Garner,its good enough for me...
Old 04-29-2004, 07:26 PM   #2653
Trader Rating: 16 (100%+)
The 0.8 pitch gear box is lighter, but the advantage of the 0.8 pitch gear box is not only just lighter, the 0.8 pitch is FINER then the 1.0 gears and give a better launch power then the 1.0 (just like those elect ppl use 64 pitch over 48 pitch and over 32 pitch for better acceleration..)......thats why NTC3 are so powerfull on launch, then MTX3, then S710......all having the same gear box.
Old 04-29-2004, 08:28 PM   #2654
Does the 2004 Spec have the new gears?
Old 04-29-2004, 09:00 PM   #2655
i am using the alum. ones, so it doesnt matter what shocks you use if it still produces amazing results
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
