Old 04-26-2004, 07:50 PM   #2581
AMGRacer's Avatar
Originally posted by goldenboy
when you buy the hpi rear grpahite shock tower, there is a place to mount the body posts wider... how do you do that??
You can use the body posts from the Pro 4. Comes on tree 73513. Dont know if you can get the seperately.
AMGRacer is offline   Reply With Quote
Old 04-26-2004, 07:52 PM   #2582
AMGRacer's Avatar
Originally posted by Rookie Solara
I might be wrong, but even though you can find one from hardware store, you can only do 1 side only, the other side is REVERSED thread.....thats why BMI has custom made "THE NUTS", one of the nut is reverse threaded.....and that is something you cannot find in hardware store.
Don't forget, the R40 upright turnbuckle are those center adjustable one, that means both thread are in 2 different directions....
If that is a known problem of the R40, please direct that information to BMI (since you are local with them) and have them to made a set JUST for R40.....cause so far there are more then 1 person have the same problem....I remembered when NTC3 came out, everyone are having the exact same problem untill we saw all the TEAM ASSICATE factory driver are having those special made NUTS on their NTC3 and no one know where they got those.....untill BMI made one for the public.
I have had it happen only 1 time to me. I think the plastic on those cups are a little soft. My advice is to use Kyosho parts in this area and it wont happen again.
Old 04-26-2004, 09:20 PM   #2583
Trader Rating: 74 (100%+)
Default .8 gears
I ordered mine.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 04-27-2004, 12:44 AM   #2584
Exclamation About the .8 pitch gear
Hey guys,
I installed the new lightweight two speed transmission (0.8 pitch) and a question popped in my mind while doing it.
Where the heck I can find other spur gear for it.
Checked on a couple of sites ... nothing....
Am I the first one to install it or what?
Frag is offline   Reply With Quote
Old 04-27-2004, 12:46 AM   #2585
Wire Handle
Another short one...
I saw on some pictures ...but can't find it anymore.... little handle made of strong wire instead of the big plastic stock one. I really liked them, anyone know where I can find them?
Old 04-27-2004, 12:53 AM   #2586
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
3Racing makes them.
DOMOisCOOL is offline   Reply With Quote
Old 04-27-2004, 05:33 AM   #2587
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Re: About the .8 pitch gear
Originally posted by Frag
Hey guys,
Hi Frag...
HPI is introing the new gears this week.....They should be available soon.......
Have you run your car with the new 2 sp?.......Any difference in performance?...Also,what ratio comes with it?.....Close to the stock 2 speed?....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-27-2004, 05:47 AM   #2588
Talking 0.8 Kawahara module gear
if you interested on changing your module gear. kawahara 0,8 module gear may be you best bet. It also reduces weight.
Kawahara freak is offline   Reply With Quote
Old 04-27-2004, 08:54 AM   #2589
PTP Racing's Avatar
NCC has a neat fix on his car for the rear camber link he has added a tie strap between the tie-rod adjusting nut and the plastic end so in the event of a problem the tie-strap stops the plastic end from sliding further in on the tie-rod
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-27-2004, 10:41 AM   #2590
Trader Rating: 16 (100%+)
Hey guys,
Someone said TOWER is selling it in the future (or even now..) so keep an eye on their site, but most important, DO NOT STRIP any gears (both pinion and spur...) or you are back to 1.0
Old 04-27-2004, 10:44 AM   #2591
We had the similar solution like that when our NTC3 had the same problem....a better (nice looking too) way to do is buy those model train use copper or alum tub (forgot what size, but any size that is bigger then the turnbuckle) and cut 2 piece for the turnbuckle....
After the major impact, your ball join got pushed in, but at least, it won't pushed all the way in and have -8 camber....
Old 04-27-2004, 10:46 AM   #2592
JLock's Avatar
If the gear chew up that easily, I will be sticking with my 1.0 series. The car is quick enough with the old gears, especially with the motors that I am running. Weight is not that much of an issue with me either (my set-up uses much of the extra weight to my advantage, especially in tight turns on tracks where braking could be an issue).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 04-27-2004, 12:41 PM   #2593
Send a message via AIM to goldenboy
i posted this a couple of days ago and no one has responded, so i will ask again, how do you mount the body posts wider, or what do i need to buy to do that??
goldenboy is offline   Reply With Quote
Old 04-27-2004, 01:17 PM   #2594
PTP Racing's Avatar
yes you can mount the rear body posts wider when using the hpi graphite shock tower
the parts needed are extra pieces included in the kit its a body post that screws onto the outer edges of the new hpi shock tower
i think they are from the rs4 if you dont have the extras in the kit
Jason Miller
Old 04-27-2004, 01:25 PM   #2595
yep i found them, thanks
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
