Old 04-20-2004, 01:01 AM   #2506
tranced's Avatar
this might have already been answered.. excuse my ignorance.. but has anyone found a decent rubber tire setup for this car?
i run on a very dusty track and it eats foams for breakfast..
a generic setup would be appreciated.. thanks
tranced is offline   Reply With Quote
Old 04-20-2004, 01:13 AM   #2507
Send a message via AIM to Proteus
Originally posted by boom
How do you guys adjust the idle stop screw with the carb turned like that?
I took my trusty dremel and grinded the case down a little. No problem adjusting the idle now.
Proteus is offline   Reply With Quote
Old 04-20-2004, 02:03 AM   #2508
AERO II
Anyone of you guys tried the new Taurus AERO II body from HPI? It's ROAR legal, so it must be not too bad!
Frag is offline   Reply With Quote
Old 04-20-2004, 10:07 AM   #2509
NCC
NCC's Avatar
Default Re: Re: R40 gearing
Originally posted by AMGRacer
Really? I guess if you are entering the straight fast already it could be a problem. Do you have your 2 speed engagement point maxed out?
Yes, I'm usually carrying alot of momentum into the straight. I run my tires anywhere from 58-60mm and anything beyond that will drop my lap times. I've also played with the adjustment point on the 2 speed. My r40 loves a small tight tracks though. All I need is just a hair more top end to give me the confidence for big tracks. I can remember seeing a 22 tooth some where, oh well I have some researching to do.
Jeff B- Let me have your gears!
NCC is offline   Reply With Quote
Old 04-20-2004, 10:48 AM   #2510
Registered User
OB42TC3's Avatar
Post
You can use the kyosho fantom 22T or the mugen 23T I think. My strategy is usually run newer tires (62-59 mm) on the bigger tracks. I know the G4 had no problem at Cincy last year and it's top gear ratio is 4.86, vs 4.93 for R40 and 5.05 for mtx3. The longest straight I have to run is Cincinnati at 270' and the G4s had no prob with that last year and they even had undersized tanks.
OB42TC3 is offline   Reply With Quote
Old 04-20-2004, 10:52 AM   #2511
Registered User
OB42TC3's Avatar
Default Re: AERO II
I tried the electric one on my Tc3 for carpet season and it was OK, it felt fast down the straight (is that why it's called aero). Maybe I 'll throw it on tonight and compare w/pf alfa 2.
Old 04-20-2004, 12:02 PM   #2512
PTP Racing's Avatar
i can only wish my car was as fast as NCC's car
proteus when are you going to come back to dougs?
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-20-2004, 12:44 PM   #2513
I'm leaving Atlanta tomorrow. I should be up there Wed night. I'll try to make it to dougs on Thur and Fri, but the weather channel is calling for isolated T-storms.
Old 04-20-2004, 01:52 PM   #2514
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Default Track Gearing
The two tracks irace at one is around 180 + and the other is i think is close to 230 to 250 most of the drivers us [email protected] ports i have a 3/prt they beat me down the straits but i catchem in the infeild turns
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-20-2004, 02:15 PM   #2515
PTP Racing's Avatar
are you going to be in the area long proteus?
im going to race my 1/8th buggy this weekend hopefully
i probably wont race at dougs again till may
i like my r40 but still perfer my mbx5
Jason Miller
Old 04-20-2004, 07:17 PM   #2516
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Default Adjusting Clutch?
I just finished building my R40 and went to test it out today. I noticed I have to rev over 1/2 throttle to get the car moving. How do I adjust the clutch so that it engages earlier? Thanks
DOMOisCOOL is offline   Reply With Quote
Old 04-20-2004, 07:33 PM   #2517
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Its some way u can just take a small alen screw and stick it in the hole of the clutch bell. Or you can take off the clutchbell and loosen up the thing that holds down the screw.
nsxshogun is offline   Reply With Quote
Old 04-20-2004, 07:39 PM   #2518
AMGRacer's Avatar
Default Re: Re: Re: R40 gearing
Try decompressing the motor slightly with shims. It works wonders and keeps your motor cooler on larger tracks.
AMGRacer is offline   Reply With Quote
Old 04-20-2004, 08:35 PM   #2519
InitialD's Avatar
Ummm, the lowest gearing on the G4 is 4.66 with the 25T/46T combo. The 4.86 FDR that you're referring to is using 25T/48T combo. That's probably the reason why the G4 does not have problems in Cincy.
Old 04-20-2004, 09:03 PM   #2520
NCC
NCC's Avatar
Amg you are right about the motor running cool just by adding shims. It's also easier on the plugs.
Proteus I will see you at dougs on Friday. What time will you be there?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
