Old 03-20-2004, 09:54 AM   #2101
rodrigo1508's Avatar
Dinball has a online store RC-Mart
rodrigo1508 is offline   Reply With Quote
Old 03-20-2004, 11:26 AM   #2102
Regional Moderator
Darkseid's Avatar
I guess I don't have to worry about finding the rear tower now. I just found out from my buddy that the shop where I got the front tower also had the rear. Right on the hook below it no less!
So now I have the rear tower too. Not much else I planned on getting for my car...
TLR 22...Tamiya F104...
Old 03-21-2004, 09:19 PM   #2103
Send a message via Yahoo to LILROBBY
has anyone that has used the hpi tires on the r 40 that the rear tires rub on the hubs?
If rubbin is racin' then I'm rubbin harder than ever!!
The team Hoopty comeback tour is coming to a track near you!!
Associated T4
Associated Rc8 electric?
Associated TC5
LILROBBY is offline   Reply With Quote
Old 03-21-2004, 10:14 PM   #2104
Regional Moderator
Darkseid's Avatar
No problem here...
Old 03-22-2004, 05:35 AM   #2105
Default Hara Setup
Alright, I'm close to putting this thing on the track and was looking at the Hara setup but haave some questions.
There are two settings in his list that I am puzzled as to how he measured. Bump stop 0mm and Rebound stop 1mm. Is this referring to how far the grub screws stick out through the sway bar blocks?
burger is offline   Reply With Quote
Old 03-22-2004, 08:00 AM   #2106
I think that refers to downstop(droop) and upstop. because normally drivers want 0 downstop so the arms are at the level of the chassis. I dont know much about upstop but I have been told its better not to use it. You need set up tools to measure the droop.
Old 03-22-2004, 09:59 AM   #2107
Registered User
OB42TC3's Avatar
Default Re: Engine Removal
Originally posted by Vr6vroom
I remedied this by cutting away at the top plate with a nice STEADY hand and a dremel, removing the excess material from the rear of the top plate. When I take the engine out I also leave the engine mounts on the chassis, I unscrew the cap screws holding down the engine to the engine mounts.
I did this too and can now get picco xp12s, and sirio evo 2s in and out easily. One key is that when dropping it back in is to push the brake back with a finger under the brake brace until the flywheel clears. After a few times it's cake.
OB42TC3 is offline   Reply With Quote
Old 03-23-2004, 09:29 AM   #2108
treky11's Avatar
Anyone find the R40 upgrade kit for sale anywhere outside Japan yet? or even a link to buy it in Japan?
treky11 is offline   Reply With Quote
Old 03-23-2004, 10:01 AM   #2109
Regional Moderator
Darkseid's Avatar
Anyone heard when HPI will make the releaved upper deck availible here in the states? Haven't heard much about it in a while.
Old 03-23-2004, 02:54 PM   #2110
Trader Rating: 16 (100%+)
If you can't find it from HK (rcmodel...etc), you won't see it coming to state.................(beside Japan)
Beside, I talked to seveal friends in HK (store owners) none of them know it will be imported and none of them are interested...(Market is low about R40 oversea....all FW-05R, S710, G4 and of course.....MTX3)
Old 03-23-2004, 03:02 PM   #2111
AMGRacer's Avatar
Not yet, but quite soon it will be available in HK. Check RainbowTen in Japan they usually have quite a bit of stock.
AMGRacer is offline   Reply With Quote
Old 03-23-2004, 03:03 PM   #2112
AMGRacer's Avatar
I am quite sure some kits will make it to HK, but as you say the car is not very popular there.
Old 03-23-2004, 03:10 PM   #2113
AMGRacer's Avatar
Nope.
Old 03-23-2004, 03:14 PM   #2114
AMGRacer's Avatar
Default Re: Hara Setup
The industry standard for droop measurement is the HUDY tool. Basically what it refers to is how far the hub sits above or below the chassis line. Bump is uptravel, I assume Hara means "unrestricted" by 0mm. Most people do not restrict uptravel. Rebound is droop and is measured with the above method.
Old 03-23-2004, 04:02 PM   #2115
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default rear shock spacer
Does anyone know where I can find part number Z805 for the R40 it is a spacer used in the front and rear shock towers. they are in between the ball studs and the shock towers. I lost one while running and I looked on tower but did not find them. Are there anyother cars that may use this same peice?
thanks Jason
jscamry is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
