Old 03-18-2004, 10:59 AM   #2056
mtveten's Avatar
Trader Rating: 27 (100%+)
Default 4-gear diff modification
Has anybody tried using the lightning 4-gear diff setup like in the setups on the HPI site? I was wondering how this effects the handeling of the car?
mtveten is offline   Reply With Quote
Old 03-18-2004, 01:02 PM   #2057
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
so US is not gettin the 2004 kit or upgrade?
cHckbOY5 is offline   Reply With Quote
Old 03-18-2004, 01:55 PM   #2058
Trader Rating: 16 (100%+)
NO ONE knows.......but it doesn't look like there will be one (since there are NO INFO whatsoever on HPI USA site....)
Everything is SAVAGE...........I heard they will release a 21 powered Savage on road car and Micro with Savage chassis...
Old 03-18-2004, 02:51 PM   #2059
AMGRacer's Avatar
Default Re: Setup
Originally posted by Vr6vroom
First RC King,
A lighter diff oil is going to make the differentials rotate faster, thus in turn making the car react faster to any input. There is a point of too light though, that is were some good old fashion track testing helps. Alot of things go into the soup for the right setup. Such as TEMPERATURE, tire size and shore and company, chassis setup, body, gearing, and so fourth. We can only post what is right for our track at that given day, because tommorrow it may bring a whole other type of conditions. But we will try and help with the best of our ability.
Amg never heard back for the Ti pivot balls, where did you order them from.?? I too, ordered the Gpm pieces, Pins, Rotor, Brake mount.
Last,
I too have experieced the motor brace bolt holes being stripped. So I guess we need some screws huh? Also the HPI or 3 Racing brace is a much need support! There is a lot of flex from my point of view right at that spot.
Hmm thats funny I PMed you back. Anyway I got the GPM parts from Harmony Models in Hong Kong. GPM normally is very low quality, but they are cheap and therefore worth testing
I am now running M3 x 25mm screws and they are tight in the holes now, no more coming loose. I also agree with the flex fromt the brace. Lateral flex is low due to its design, but there is a lot of flex in the other directions.
AMGRacer is offline   Reply With Quote
Old 03-18-2004, 06:23 PM   #2060
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Yeah... The HPI USA site is definately the worst of the three! That's why I prefer the European site better.
Nrctc3 is offline   Reply With Quote
Old 03-18-2004, 09:05 PM   #2061
Trader Rating: 74 (100%+)
Default web site?
AMG,
do you have a address for Harmony?
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-18-2004, 09:18 PM   #2062
AMGRacer's Avatar
Default Re: web site?
AMG,
They do not have a useful website. Best is to email:
[email protected]
Very good service, very good prices, huge range.
Old 03-18-2004, 09:22 PM   #2063
Default website
Thanks Amg.
Old 03-18-2004, 09:23 PM   #2064
Regional Moderator
Darkseid's Avatar
Default First runs...
Well, I finally got in my first runs with the car. And what can I say really? I thought my ReflexNT was pretty well set up, but this car was absolutely hooked! I've never seen any car with this much steering without the use of a one-way. I can't imagine needing one in this car. The car exhibits almost no body roll thanks to the dual sway bars. I started the car with 2.5 degrees of rear camber expecting to have the tires cone on the outside like they did on my Reflex because of body roll. Nope, nadda... In fact I'll have to take it back down some to keep them from coning on the inside.
Hmmm....what else...the car cleans up amazingly well. Very easy to reach everything. I had the car cleaned up from some very dusty running in only 30 minutes.
I found it neccesary to cut some material off the bottoms of the rear hubs to keep small particles from jamming the rear wheels. The tolerances here were simply waaaay too small. Even small sand particles were enough to completely stop a wheel before the modification.
The main belt seems to be a little loose after only 8-10 runs. Thats not good. I'll take up the slack with the tensioner, but the belt doesn't seem to have much of an expected lifespan...could be wrong, but thats the way it looks.
Thats about it for the car. i'm very happy with the car right now and looking forward to the season. I feel confident that this car can compete and win against anything out there with or without all the hop ups that some people have.
-ON A SIDE NOTE- I know this isn't an engine thread, but I must say that my Sirio .12 makes for a perfect partner for the R40. Insane power and speed...simply insane!
This engine and car combo only go to prove my original opinion that with the insane power of modern`1.45+hp engines, the difference between a 1800g car and a 1725g car wont be notice by most mere mortals.
TLR 22...Tamiya F104...
Old 03-18-2004, 09:31 PM   #2065
AMGRacer's Avatar
Default Re: First runs...
Originally posted by Darkseid
Well, I finally got in my first runs with the car. And what can I say really? I thought my ReflexNT was pretty well set up, but this car was absolutely hooked! I've never seen any car with this much steering without the use of a one-way. I can't imagine needing one in this car. *snip*
Hehehehehehehe not bad huh I run a oneway and you should see this badboy turn in
Old 03-18-2004, 09:53 PM   #2066
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
here's HPI's next advertising campaign...
"less time wrenching ....more time running .....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-18-2004, 09:56 PM   #2067
AMGRacer's Avatar
I agree except for the motor access issue. It is such a darn pain in the ass to get a motor out of the chassis. Have to remove both braces, very annoying.
Old 03-18-2004, 10:24 PM   #2068
what you guys to setup your cars? Is there a better way than others? I use rpm camber guage. I normally use my eye to adjust the toe. But it looks quite diffcuilt with on road cars. HELP!!
nero1943 is offline   Reply With Quote
Old 03-19-2004, 02:20 AM   #2069
The Sleeper's Avatar
I had the same problem but only with the kit tires. Other tires I use; TRC and Fast Tires; didn't jam up
The Sleeper is offline   Reply With Quote
Old 03-19-2004, 03:52 AM   #2070
cHckbOY5's Avatar
the r40 a good beginner car?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
