Old 03-15-2004, 05:00 PM   #1996
AMGRacer's Avatar
Anybody tested the hard shock bladders yet? My initial testing did not really give me good results as my tire choice was poor.
AMGRacer is offline   Reply With Quote
Old 03-15-2004, 06:32 PM   #1997
Manticore's Avatar
R/C Tech Charter Subscriber
the hard bladders suppose to give faster shock rebound. the same as what you have on your EVO.
Manticore is offline   Reply With Quote
Old 03-15-2004, 06:39 PM   #1998
AMGRacer's Avatar
Yep agree. I was testing it on a somewhat bumpy track and I wanted to see if the rebound was too severe and I was losing front and side bite. The HPI hard bladders seem to be less stiff than the Kyosho ones.
Old 03-15-2004, 06:50 PM   #1999
Manticore's Avatar
i think the harder bladder works better on kyosho as the EVO car is too stable. it needs quicker suspension reaction.
Old 03-15-2004, 10:48 PM   #2000
do I have the CA the edge of the CF piece on the R40???
i'm in the process of building R40
nero1943 is offline   Reply With Quote
Old 03-15-2004, 10:50 PM   #2001
Manticore's Avatar
CA the edge of the CF if it is used for main chassis. it is for comestic reason if you do it on upperdeck and shock tower.
my 2 cents! !!
Old 03-15-2004, 10:52 PM   #2002
AMGRacer's Avatar
You dont have to. You can do it for looks if you like. CAing the edges is mainly useful in areas which are prone to delamination due to rubbing on the ground, etc. CAing the shock towers for instance will not make them any stronger unless they get hit in the ends, pretty unlikely.
Old 03-15-2004, 11:10 PM   #2003
Trader Rating: 16 (100%+)
Originally posted by CraigH
You know what? I don't care which is better. I just want HPI to get the 2004 out.
This really cought my attension.........Japan released the car last week, lets do the count down and see when can we get the 04 spec....HK still has no word of getting the 04 any time soon...
Old 03-16-2004, 05:05 AM   #2004
Wink tip please....
okay, I used the stock 50k oil in the rear diff and 30k oil in the front. Is this okay? I am a super noob with on road stuff.
Old 03-16-2004, 07:26 AM   #2005
JLock's Avatar
Default Re: tip please....
You want to use the 50k oil in the front and the 30k oil in the rear.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 03-16-2004, 07:41 AM   #2006
I think my front diff is leaking. Is this a common problem???
Old 03-16-2004, 07:48 AM   #2007
JLock's Avatar
Yes, this is a common problem. Just use some sealant (type/brand can't think of off the top of my head) around the seam and let harden and your problem should be solved.
Texas 5
Old 03-16-2004, 08:31 AM   #2008
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default front diff leaking
hey all, I was wondering about the front diff leaking. I found that when I put some sealant around the seam of the diff (where the top and bottom of the diff connects) there were no leaks. However I am seeing some leakage from the out drive on the front diff. Anyone else have this problem?
thanks Jason
jscamry is offline   Reply With Quote
Old 03-16-2004, 09:00 AM   #2009
I don't want to bring up the word SERPENT again......but really, I have 2 things that I always use from SERPENT on any RC car that I have....
(1) the Serpent damper adjustable shock....no need to replace damper at all, just CLICK.........the best shocks in the market
(2) the Serpent cleaning gum...................not for cleaning, I put alittle of the gum inside the front diff, then apply some 50K (some, not a lot, if you dropped to much, it will leak)......it works perfect, and there are no leaking..........
Serpent Cleaning Gum 1690
Give them a try........
Old 03-16-2004, 09:04 AM   #2010
Default Re: front diff leaking
thanks Jason
You cannot SEAL the whole diff.......and the outdrives are the only area that you cannot touch and the only place for the grease to go....
I used YOKOMO HARD diff grease, those are like GLUE, and I apply just enough (not packing it) along with the Serpent GUM, the gum itself will hold the grease within the housing, then I use CA to seal the whole diff................the chance that I can ruin a gear diff is low, so I CA the whole edge. But I prefer using SEALANT, so the diff is still servicable.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
