Old 03-09-2004, 06:57 PM   #1891
nitro13's Avatar
do yall know if this starter box will work with the r40 http://www2.towerhobbies.com/cgi-bin...?&I=LXRS98&P=7
nitro13,
nitro13 is offline   Reply With Quote
Old 03-09-2004, 07:02 PM   #1892
Trader Rating: 74 (100%+)
Default starter box
That box should work without a problem, but it is a little heavy.
I like and use the Team Magic X5, ultra light and compact.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-09-2004, 07:06 PM   #1893
nitro13's Avatar
that good for me i ordered it with a cupon i got from tower in email and got it for $30
nitro13,
Old 03-09-2004, 07:22 PM   #1894
AMGRacer's Avatar
You will notice that I have made some postings about the one-way equipped cars some pages back. Key points:
1. You car must be not tweaked at all. Remove all tweak.
2. Play with your cars braking power via the transmitter EPA so that you do not lock up the brakes. You will then be able to apply some braking not much.
3. I noted above that the stock R40 setup for the rear is not optimal for usage on a one-way. Remember that when driving a oneway you should basically never brake. All of your cornering speed adjustments are made by letting off throttle at the right moments. Hence you will find that you corner very quickly and you will be taxing the rear outer tire on most corners. Try a lighter shock oil in the rear, around 50wt.
AMGRacer is offline   Reply With Quote
Old 03-09-2004, 07:35 PM   #1895
Default EDITABLE SETUP SHEET
I found the setup sheet but I cant edit it? Any suggestions. I am using Adobe 6.0.
Old 03-09-2004, 07:43 PM   #1896
AMGRacer's Avatar
Default Re: EDITABLE SETUP SHEET
Do you have the reader or the editor? A full version will allow you to edit .pdf files.
Old 03-09-2004, 07:48 PM   #1897
Default Which one?
You know I dont know, I guess I have to look. Also I forgot to ask, does anyone know the part # of the larger tank. I cant find it on HPI's site?
Old 03-09-2004, 08:01 PM   #1898
nitro13's Avatar
heres the link to the 75cc tank on towers site http://www2.towerhobbies.com/cgi-bin...?&I=LXFKD8&P=Z
nitro13,
Old 03-09-2004, 08:16 PM   #1899
AMGRacer's Avatar
nitro13,
As far as I can tell there is no larger tank from HPI yet as all tanks I have seen available and on instruction sheets have the same part number. Unless HPI has made a running change to the tank and used the same part number.
I will attempt to measure my tank tonight.
Old 03-10-2004, 05:18 AM   #1900
Default bigger tank?
I got this quote from the link that Nitro13 posted."NOTES FROM OUR TECH DEPARTMENT
This is the Stock Racing Fuel Tank for the HPI R40 Kit.
FEATURES: 2.5oz (75cc) capacity", so what is it a stock size tank, or a upgraded tank????
ANd I will download the rest of Adobe 6.0 for the setups. Thanks AMG, I'll keep ya posted.
Last but not least, any takers on the blowout special r40 NIB?
Old 03-10-2004, 06:07 AM   #1901
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the stock tanks are around 73cc..
there will be new tanks going in the kits...they are a tad taller...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-10-2004, 08:53 AM   #1902
Hi guys,
I ordered a R40 a week ago and I just realize there's a new 2004 version comming out I am new with on road and I currently own a RS4 Evo. Should I just sell the R40 and pratice with my RS4? Needless to say I will have to spend lots of $$$ to make it run. (very broke at moment) I might get into racing when I have better skill
How does the current R40 stock compare with MTX-3 with the same engine, mainfold, pipe, servos, etc???? I am asking because there's more MTX-3 parts than R40 locally.
Please help me out guys...
nero1943 is offline   Reply With Quote
Old 03-10-2004, 11:31 AM   #1903
Regional Moderator
Darkseid's Avatar
Originally posted by nero1943
Hi guys,
Well you've already bought it, so I don't see any reason for you to sell it. Remember, most of the extras on the 2004 spec really wouldn't be noticed by someone just taking their first steps into racing as you seem to be doing.
As for getting 'into racing when you have more skill'....how do you think you get those skills! If your local track has a sportsman nitro class, hop in, get used to racing and learn your skills there.
Its kinda hard to compare the cars the way you mentioned, becasue hardly anyone ever runs the exact same setup(pipe, manifold, servos, etc...) as someone else. Theres so many variables to put into comarisons that they're almost pointless.
I would say since you bought it, stick with it.
TLR 22...Tamiya F104...
Old 03-10-2004, 01:12 PM   #1904
mtveten's Avatar
Trader Rating: 27 (100%+)
Default 2004 spec R40
Can someone please tell me what the differance between the 03 R40 and the new 04 spec version is? Will it be worth waiting a couple of months for the new version?
mtveten is offline   Reply With Quote
Old 03-10-2004, 03:22 PM   #1905
AMGRacer's Avatar
Yep I used the IFMAR syringe measurement technique and my tank plus fuel line worked out to be 73cc. My tank is the same tank as comes in all the HPI R40 kits according to the manual. I dont think the larger tank has been released yet, unless they are using the same part number for the newer tank.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
