Old 02-24-2004, 10:28 AM   #1726
JLock's Avatar
Originally posted by Jpilone
I've also been working with Wolfpack Radicals on the R40.
He wants to make other parts and will get with me later on that, but i'm testing a prototype 2 speed he made for the car.
it includes a titanium 2 speed shaft and TC3 2 speed that drops about 20 grams of weight from the car (and it's all rotating mass).
I've got to give him some measurements from the car tonight and discuss further information with him, but he says he'd put it into production if there's enough interest. The TC3 2 speed is much MUCH smaller in diameter than the HPI 2 speed.
Understand that everyone want to drop some grams from the car, but why limit yourself with the NTC3 2-speed gear selection. That has been a complaint for months with the NTC3. You use the two gear choice NTC3 2-speed while I blow by you with my HPI/Serpent multi gear choice 2-speed.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-24-2004, 10:37 AM   #1727
Moderator
Jpilone's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Jpilone
I must correct myself, the only AE parts you're using is the clutch shoes, and the sleeve that slides over the 2 speed shaft..
The HPI spurs fit. They made the gear adapter and everything.
Here's a photo I took of it
-Jarrod Pilone
Pro R/C Photographer
http://www.jpsportspics.com
Jpilone is offline   Reply With Quote
Old 02-24-2004, 10:50 AM   #1728
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
you are droping 20 grams of rotating mass correct.but are you going to add that 20 grams as dead weight to bring the car back up tp the legal minimum weight?
Old 02-24-2004, 10:57 AM   #1729
Moderator
Jpilone's Avatar
Marcos,
it doesn't matter if the car already weighs 1840 grams....
-Jarrod Pilone
Old 02-24-2004, 11:22 AM   #1730
Super Moderator
Marcos.J's Avatar
Marcos,
okay, i was wondering how much it helps by changing the rotating mass to dead weight?
Old 02-24-2004, 11:26 AM   #1731
Moderator
Jpilone's Avatar
I noticed it spools up a bit quicker for sure, and the shifting is much smoother than the stock 2 speed.
-Jarrod Pilone
Old 02-24-2004, 11:41 AM   #1732
Super Moderator
Marcos.J's Avatar
cool
Old 02-25-2004, 08:25 AM   #1733
Thad Garner's Avatar
Originally posted by 20 SMOKE
whats the advantage of the 4 gear rear dif and would it work in the front
Increased mechanical friction. With the 4 gears the car seams to square up quicker out of corners. (You can get back on the throttle sooner) I haven’t used the front diff. 4 gears would work in the front but im not sure of its benefits
We found that the best rear diff combo is…
Loose track- 2 gears with 50,000
High bite track – 4 gears with 30,000
-Thad
Thad Garner is offline   Reply With Quote
Old 02-25-2004, 01:49 PM   #1734
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Thanks thad is that 4 gear 30,000 and oneway or dif
20 SMOKE is offline   Reply With Quote
Old 02-25-2004, 02:55 PM   #1735
AMGRacer's Avatar
-Thad
Yep I totally agree. Except to add that on my medium grip track even the 4 gear diff felt better with 30K vs the stock 2 gear with 50K.
AMGRacer is offline   Reply With Quote
Old 02-25-2004, 03:01 PM   #1736
smz
Default front toe adjust
what's the easy way to adjust the toe angle in the front? The A-arms seem to be in the way to make larger turns with the nut. How do you experienced guys do this?
also, I purchased a front one way tube form 3racing and have no idea how to install it. there's nowhere for the belt to go onto. Am I supposed to reuse the front diff housing?
smz is offline   Reply With Quote
Old 02-25-2004, 03:22 PM   #1737
AMGRacer's Avatar
Default Re: front toe adjust
The front oneway comes with a oneway pulley. I think you need to buy this.
Old 02-25-2004, 11:11 PM   #1738
Default 4-Gear Diff??
Hey all, I can't seem to find the 4-gear diff parts. Where can I order them from?
jay272 is offline   Reply With Quote
Old 02-26-2004, 12:46 AM   #1739
OvalEvader's Avatar
Send a message via AIM to OvalEvader
Hey guys, finished my R40, looking to sell possibly. But if that falls through, I will be doing some racing with it. I am totally new to onroad as a whole, although I'm pretty good with nitro offroad. I'm going to be doing some parking lot races, as well as a medium bite track. Would a one way improve performance on these tracks. I'm also having problems with the front diff leaking, the rear is fine, but I think almost all of the oil is gone from the front after the build. Also, the side belt is really loose, and I havn't figured out a way to tighten it yet.
Looking for some reccomendations on a engine, I could either pull out the standard shaft from my MT-12 and throw in a SG and use that, or I could just buy a new engine, probably around 100 bucks (same price as a new shaft and carb for the mt-12). What would you guys reccomend?
Also open to any setup, foam tire, and hopup reccomendations.
Thanks,
Ryan
OvalEvader is offline   Reply With Quote
Old 02-26-2004, 02:40 PM   #1740
Super Moderator
Marcos.J's Avatar
Thanks,
Ryan
You can ask fastharry or JPILONE they both run the R-40 and both of them know alot about the R40
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
