HPI R40 Nitro Car Forum
#1711
#1712
had a good run
hi all ,
just to let you know that i had a great run with the car today (finally). i put the kyosho four gear diff (can,t get hold of a hpi ) and it tranform the car totally i ran 45 fronts and 42 rears and it was awesome .just wonder though is there a secrect to the clutch i just can,t seem to get it to come in hard enough is there a after market shoe
cheers ozysnake
cheers ozysnake
#1713
ozy some of the veterans on our track sand down some parts on the clutch to improve its performance. i havent really studid what part exactly but you might want to take a closer look at it.
#1714
Re: had a good run
Originally posted by ozysnake
hi all ,
cheers ozysnake
hi all ,
cheers ozysnake
My clutch comes in dang hard man. What are you endfloat and adjuster nut settings? I have .3mm endfloat and .9mm on the adjuster nut. I have not run on really high traction tho, your 45/42 tire combo seems to indicate your track is pretty high grip.
#1715
Re: had a good run
#1716
Re: had a good run
hi all ,
cheers ozysnake
hi all ,
cheers ozysnake
TO ALL - what oil weight would you use for the front and rear gear diffs what you have the 4 gear set installed?
thanks !!!
#1717
we have a high grip track
hi all ,
thanks for the advise on the clutch i will try that,i tryed soft tyres 42 fronts and 40 rears but the car seem to go off at the end of ten mins on 45 fronts and 42 rears i think i could go all day but on saying this i have not yet race the car so it might be to slow with to much understeer we will see this weekend . as for the diff it came out of a v one r so i don,t have a part number .
cheers
ozysnake
cheers
ozysnake
#1719
Re: we have a high grip track
hi all ,
cheers
ozysnake
hi all ,
cheers
ozysnake
First up all the Mugen centax clutch shoes do fit the HPI clutch. There was a little bit of binding on the pins, nothing a little clearancing would not fix. So you could try the high bite Mugen clutch shoe.
Also the Mugen clutchsprings fit. You could try putting the Mugen high tension spring (gold colour I think) in to increase the punch.
#1720
hi ,
thanks for that amg . been a brisbane driver u would no what the grip is like at brendale (england park ) if you have race there it is high grip .mostly at tille events it real becomes high and there is a chance of traction rolling . don,t seem to have the problem yet with the hpi.
cheers ozysnake
cheers ozysnake
#1721
hi ,
cheers ozysnake
hi ,
cheers ozysnake
You will have trouble traction rolling the HPI, but you can do it! The HPI team drivers recommend using the much more laid down front shock tower to reduce the chance of traction roll.
#1722
I just bought an R40, New-in-box, for 239$ and free shipping from a guy on ebay. Sweet deal huh?
#1723
I was at the winternats with my R40 and ran it inbetween my photography duties (i'm the webmaster of http://www.winternats.com ).
The car was awesome, but I had a bearing failure in my clutchbell. The smell flanged bearing came apart, allowing the clutchbell to extend out too far and lodge up against the chassis, this put such a load on my engine that it fried it in a matter of seconds..
Serpent has a package of high quality bearings that fit perfect, but it's $15 for two of them...
Just FYI. I knew the HPI bearings were low quality when i assembled the kit and I should have been prepared for this.
#1724
BTW, nice job done on the coverage and website !
#1725
I've also been working with Wolfpack Radicals on the R40.
He wants to make other parts and will get with me later on that, but i'm testing a prototype 2 speed he made for the car.
it includes a titanium 2 speed shaft and TC3 2 speed that drops about 20 grams of weight from the car (and it's all rotating mass).
I've got to give him some measurements from the car tonight and discuss further information with him, but he says he'd put it into production if there's enough interest. The TC3 2 speed is much MUCH smaller in diameter than the HPI 2 speed.
