HPI R40 Nitro Car Forum
#1696
hi guys
hi guys,
i have been running the car for 6 months now with out a good result . had a lot of d.n.f with stuff like clucth brearings failling and camber links letting go broke a sevo saver at last years australia titles and had no parts as i was the only one running a hpi r40 . but not to give up this years another year so with a bit of help from you guys i will sort this car out and hopefully put it up the pointy end of the field as i ran 5th at the Qld state titles with a v one r .
Cheers ozysnake
hpi r40
n.s.3 jp black
team lauterbacher Australia (1/5th scale )
Cheers ozysnake
hpi r40
n.s.3 jp black
#1697
I've lost 3 bearings all on the clutch side. first it was B019, then B018, now the thrust bearings blew up. I dont know what i'm doing wrong, maybe someone can shed some light over here.
#1698
Originally posted by Rookie Solara
Fatboy Joe..........if you are running front 1-way (assumed you are running some mid-large size track)....your rear diff must be toward STIFF to SOLID condition..........if you look at most 235mm Serpent IMPACT or MUGEN chassis that run front 1-way stock, they only come with a SOLID REAR stock........so what you are saying about your rear diff oil getting light and car is getting hard to control does match the theory of the front 1-way rear solid equation....the idea is...your front wheels are spinning almost in all condition (since no DIFF to slow them down), and IF your rear diff spin freely with a little or less diff to slow them down itself, it is like your driving a car with NO BRAKES....so the car will push and slide entering or exit corner, and in your case, overpowered and causing fish tail (if traction on the track is poor....)
If you can get the 4 gear diff, yes, that is your best answer, mating with 30K grease (or anything a little lighter then what you used on your 2 gear)........more gears inside the diff, the more CONTACT between both side gears...before, there are only 2, not is 2X = 4....so, if you used the same grease (50K), it will make your diff almost hard solid....so I would try the 30K first, beside, you can always ADD more, but removing your old grease are PAIN.
I don't know what grease you guys tried before, but since I raced my Serpent Impulse back 5 years ago, I only used 2 grease....1, it is from MUGEN...good stuff, but big bottle and pricy, like $20 plus each....and lately I changed to this one.....Yokomo, hard or medium grease.........basicly the same thing as Mugen, but much cheaper and much easier to put them on to the diff (Mugen is a bottle, take forever to see those 50K grease drop to the diff)...and Yokomos can be purchase at TOWER and much cheaper....the cars I used these grease are Impulse and HPi SNRS4.....and I hardly experience any grease leaking or getting THINNER after a long run.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXCNK5&P=7
Hi Rookie,
thanks for the tip I'll be getting me some 4 gear diffs for the back. Does the mugen gears fit? Thanks
#1699
Does anyone know how the R40 compares to the Serpent 710? I'm in the market for a nitro sedan, and so far I'm considering the 710, R40, LD3 (hong nor) and the 2 new kyoshos. I just don't wanna fall into the "hop-up trap" . Why spend $200 on hop-ups, when I can get the serpent 710 for $100 more? But, if the R40 will offer "serpent performance" for less $$, I'm all for it. Thanks in advance for your replies fellas!
#1700
Hee hee, you just started another SERPENT vs HPI challenge (or G4/MTX3/710/R40)...........In fact, I am working on both of the car right now (time by time) and I can give a little input for those who still haven't decided what to get....
Before you guys heard about 710 is so good and so this and that...make sure you have the money to afford this car first, PARTS are expensive (they just had a price raise about 14% for everything....) 710 is definitely a better construction car (I am just being honest) over R40....again, the whole car's construction, better material, more adjustment and probably a FASTER car....probably.....however, 710 is no more Serpent Impulse,Pro or 705........Michael Salven took almost 2 full days to fine tune his 710 on Winter National to the way that he like....if he need 2 days to do the work, guess how many years that will take us....
When I build the 710, it is no HPI, you have to be very knowledgable about RC to get that car build right...again, Serpent expect all 710 owner are in the RC for some time before getting one....on the other word, no really a PLUG and PLAY thing. The 710 Setup book is like 38 pages.....that is just for STANDARD setting and a basic knowledge about 710...you MUST read thru it and know about every singel function of each nuts and bolts.........talk about HIGH TECH.
I haven't had chance to run the car, but from 710 ppl said, the stock setting of 710 is good enough to race very nicely.....and 710 can provide quite a lot more different setting and conditoin to fullfill your local track in different condition and driving style....but again, you MUST know how to do that...
Overall, 710 is around $360...car doesn't need carbon this and titanium that....car is optionless (3racing made tons of option for 710, but almost NONE of them are usefull....all eye candy), but parts can cause you arms and legs, and if you are LHS shopper for parts, make sure they carry Serpent....
HPI R40.......much easier to UNDERSTAND and construct......not sure how durable about the whole car, but seems like it is a little stronger then their previous RS4 series, all the adjustment on the R40 are very typical....very straight forward. Car is also race ready out of the box...........price is around $250....but options might required in order to IMPROVE the cars (ie, shocks, springs, carbon tower, light wieght gear box, clutch....etc)....so there are some money spending issue followed on this car if you are getting better and trying to catch those big boys......
Parts are cheaper and easier to get then Serpent......car is no RS4, doesn't need to have 80% of parts upgraded. Aftermarket parts are there (plenty)........setup can be find everywhere, and adjustment can be done very fast at track and result is quite obvious.......
However, the real testing is the one that I have to do......right now, I am leaning toward R40, cause 710 still took me quite alot of time to setup to the way that I like, and by touching the 710, I still do think that is what I like............on the other hand, R40 does not have that much option, which can be a good thing, by using stock setting, car can be very easy to drive and fast.
So, if I use the same engine/pipe elect and stuff, on both cars in stock form, I will say 710 will be a faster and better car...........BUT (again, please).....that is only apply to those really know what they are doing, for me..........I rather have a easy to tune car (R40) then a 710 that might need a lot of time invested to setup....I might not be able to beat the 710, but I will have fun all the time.
Again, that is my opinion only.................this applied to be cause my friend and I just made the exact same decision (between 710 and R40) and he decided to sell his brand new 710 and get the R40 with me....
Also....when we all concentrating between 710 and R40..........don't forget about the MTX3.....did you guys know that MUGEN just shut the worlds up (in all classes including the odd ball 235mm class which should be dominated by Serpent) at Winter National....? And that was not including those Mugen Japan Team driver....
#1701
IMHO, if you have to ask, you're not ready for the 710. I know some very experienced local racers that say the 710 is an amazing car but it takes quite a bit of knowledge to fine tune it. The stock setting is a "good" starting point but it doesn't make the 710 stand out in a crowd. What makes the 710 "supposedly" better is the ability to fine tune it to your heart's content. To do so requires a vast knowledge of what different adjustments will do, why you would/should choose one adjustment over another, as well as a huge comfort zone with your own driving style. My LHS owner called it "the Veteq of sedans" because of it's frustratingly multiple setup options.
Now with that said, I personally don't have the car or have ever run one. I do know that I'm not hardcore enough to even want to tinker with setups all day long. When I get to the point to where I can run a 30+ min main without a bobble and still lose, then I'll consider the fact that I may need more car.
If you want a top of line car so your ego will not wonder if you have enough car, go for an MTX3 or V1RR Evo. If your ego makes you want to prove an HPI car belongs on the same list as the "better" cars, go for the r40.
#1703
I looked at it from the money stand point:
2-R40=520 2-710=720
extraparts=150 300
670 1020
Thats a difference of $350 dollars.But the parts for the R40 are much cheaper.
The reason for 2 cars and parts is because I would like to race some big races and like having everypart just in case.
2-R40=520 2-710=720
extraparts=150 300
670 1020
#1704
Thanks for the replies Rookie & Rod
Im not insulted in the least bit Rod. I've been racing an X-ray (the most adjustable Electric TC) for the last 2 years, and I'm quite proffecient with setting up a car to my liking. I just want to hear "from the horses mouth" about how the 2 cars Im most interested in, compare to one another. I kinda considered the MTX-3, but being that Im such an Xray fan, I'm leaning more towards the serpent.
BTW, people I race with said the same thing about the Xray when I was shopping for an electric TC(about how expensive everything is) and I listenened and bought a TC3 FT, what a mistake!! Then came the Pro 3, which required about 200$ in parts and chassis upgrades to be competitive. After splurging on the Xray evo 2, I've yet to break the car and it handles better than any other electric I've ever owned. My point is that I should've bought the best car from the beggining, and I would've saved money.
You guys see where I'm coming from?
R40 racers......
Have you guys started noticing any weird "wear-n-tear" problems with your R40s?
R40 racers......
#1705
We are all here to help each other out...including making the car decision.....and not saying 710 is the best or MTX3 is the best....when I was racing my Serpent Impulse back 5 years ago, the fastest guy at our track was running a nicely setup and hopped up HPI RS4 and not one of us can catch him, including those mugen and yokomo.....
If you have the X-ray back ground.....then I will say you can consider 710......again, I still believe BOTH car are about the same at the track (I am assuming both are driven and tuned by experienced driver....) R40 is a little LESS about fine tunning, but that also means you don't have to worry about all those little things.....710 has a MILES of setting for you to choose, but the worst thing is....it is way too many different setting and combination for you to choose from, sometime, you just want to ask Serpent....."why all these luxury....."
I can only speak for Serpent, Serpent rarely has WEAR and TEAR issue.....things like pulley, belts and plastic seems only getting better and better when you run the car more...(kinda like the whole car need a break in period...).....if you want to know how good is Serpent parts, you can ask yourself that question....how good is X-rays parts....
But also, R40 is no RS4.....from all the friend I knew that own the R40....car is very strong and parts are unexpectedly durible....
P.S.....when ppl said 710 is the TC version of Veteq 1 and 2.....that is NOT a understatment at all....but just hope the 710 is not another over-engineering products.
#1706
So what would be the difference between a solid rear axel and a rear 4 gear diff
#1707
In any case, please do not take my comments negatively and take it in a bad light that I'm bashing the R40. I would respect any car you choose as every car would have pros and cons. These are just some of my views.
#1708
#1709
Anyway, there's always the setup book that you can follow. What is advised for racers is to use the stock setup, see what inadequacies or what is lacking in the car (steering, traction etc) and use the table in the last page of the setup book provided to fine tune.
#1710
In any case, I can honestly say that the 710 parts while generally being cheaper than the older 705 parts, they are not as strong as the older Serpent 705 parts. I'm referring to arms, bulkheads etc. However, their drive train parts are excellent. Better than the 705.
By all means if parts availability and support from the LHS is non existant, go with the car that has most support.
Apologies for the little digress. Anyway, lets get back to R40 discussions.
