Old 02-16-2004, 03:55 PM   #1666
AMGRacer's Avatar
Originally posted by Fatboy Joe
Yes, I noticed that too. Where can I get the 4-gear diffs? I use 50k oil and notice that the handling of my car becomes very unstable whenever the oil thins out. What is the theory behind this? My car will be like it corners on rails everytime I refill the diffs with new oil but would just spin out and become unsrable after a couple of weeks.
Yep exactly like mine. Wierd huh. I now have the 6 gear diff installed but only have 1 race meet on it. I initially thought the diff might be leaking but it definately was not. I really cannot explain why it "thinned out". My Kyosho diff was consistent for months without a rebuild, it is a 6 gear style.
As to why the car becomes unstable it is due to probably the diff being inconsistent in its stiffness. A stiff rear diff gives less off power steering and more on power steering basically. If the rear of your car is changing this bias lap to lap that cannot be a good thing.
AMGRacer is offline   Reply With Quote
Old 02-16-2004, 04:02 PM   #1667
AMGRacer's Avatar
Default Re: 4-gear rear diff.
Actually this is the set I purchased:
It comes with all the parts required to make either a complete front or complete rear 4 gear diff.
Part number is 33406.
Old 02-16-2004, 04:59 PM   #1668
So after cleaning my car and putting it back together, I threw it on the scale. 1648g w/o body and fuel. I still have to make a couple of changes, so I will probably drop another 10g before the race season starts.
C0NTENDER is offline   Reply With Quote
Old 02-16-2004, 05:23 PM   #1669
Send a message via Yahoo to LILROBBY
amg, where did you get yours? i ordered mine from r-c model.com.
If rubbin is racin' then I'm rubbin harder than ever!!
The team Hoopty comeback tour is coming to a track near you!!
Associated T4
Associated Rc8 electric?
Associated TC5
LILROBBY is offline   Reply With Quote
Old 02-16-2004, 05:29 PM   #1670
Fatboy Joe's Avatar
Originally posted by Rookie Solara
Your rear spinning out = rear traction is not enough, or you can say, your front has too much traction too....= oversteering = fish tail at rear.
Usually, if your rear diff spin freely, you should have MORE traction then tighter diff......so if your rear diff oil got thinner, diff will spin easier and faster, that should give you MORE traction (lets not count the shock, camber, ride height and other factors....)
Are you saying your FRONT diff oil get thinner, then your car will spin out? Or you are talking about your REAR diff oil got thinner, then your car will spin out....?
Please specific..................
Hi Rookie,
Sorry about the details I am using front one-ways. I just notice that everytime the rear diff oil thins out, my car is more unstable. I do not know the exact explanation for it but what I think about it is that when the oil thins out, it doesn't have much "limited slip" diff feel in it anymore that it doesn't push the car's rear tires to the ground as much as with fresh diff oil. My car will be so hooked and balanced when I put in fresh diff oil (50,000) in the rear diffs.
Fatboy Joe is offline   Reply With Quote
Old 02-16-2004, 05:38 PM   #1671
Fatboy Joe's Avatar
Thanks for the info. Yes, I think that's the theory behind it. When installing the 4-gear diff, what oil do you put? Let's say 50,000 for the 2-gear diff, what about for the 4-gear? Should it be thinner? Thanks for the info
Old 02-16-2004, 07:12 PM   #1672
rod_b's Avatar
Send a message via AIM to rod_b
I think the Team Drivers used 30K with the 4 gear set at the Sedan Nationals at Revelations.
rod_b is offline   Reply With Quote
Old 02-16-2004, 09:01 PM   #1673
AMGRacer's Avatar
OK this is freaking me out. My car minus body weighs in at 1766g. This includes motor, battery, servos etc minus fuel. How in the heck are you guys getting yours so light?
I have:
Rody 3 port X12
Graphite towers
Lightened shafts
1100mah large battery
1 x 9550 futaba servo
1 x 3003 futaba servo
Airtronics 211 2 channel RX
Everything else stock.
I am like 120g overweight compared to the rest of y'all!!!!!!!!!!
Old 02-16-2004, 09:21 PM   #1674
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
FBJ - from what i have seen a lighter oil was used when the 4 gear set is intalled. i saw a couple of guys put together a 4 gear diff for the mtx-3. is it possible that we could use those gears?
S-T-R-l-K-E-R is offline   Reply With Quote
Old 02-16-2004, 11:31 PM   #1675
AMGRacer's Avatar
When both diffs were brand new and not run the 50K 2 gear felt looser than the 30K 4 gear diff that I built. They were somewhat similar however, so they are somewhat equivilent.
Old 02-17-2004, 07:59 AM   #1676
JLock's Avatar
For you guys that have your cars under 1700g, remember that ROAR minimum weight is 1725g with personal transponder. The car do not give you much area to add needed weight where you want to put it. Be careful about making it too light or you won't be able to run a ROAR race due to not meeting the minimum weight requirement (food for thought).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-17-2004, 08:50 AM   #1677
Trader Rating: 16 (100%+)
Fatboy Joe..........if you are running front 1-way (assumed you are running some mid-large size track)....your rear diff must be toward STIFF to SOLID condition..........if you look at most 235mm Serpent IMPACT or MUGEN chassis that run front 1-way stock, they only come with a SOLID REAR stock........so what you are saying about your rear diff oil getting light and car is getting hard to control does match the theory of the front 1-way rear solid equation....the idea is...your front wheels are spinning almost in all condition (since no DIFF to slow them down), and IF your rear diff spin freely with a little or less diff to slow them down itself, it is like your driving a car with NO BRAKES....so the car will push and slide entering or exit corner, and in your case, overpowered and causing fish tail (if traction on the track is poor....)
If you can get the 4 gear diff, yes, that is your best answer, mating with 30K grease (or anything a little lighter then what you used on your 2 gear)........more gears inside the diff, the more CONTACT between both side gears...before, there are only 2, not is 2X = 4....so, if you used the same grease (50K), it will make your diff almost hard solid....so I would try the 30K first, beside, you can always ADD more, but removing your old grease are PAIN.
I don't know what grease you guys tried before, but since I raced my Serpent Impulse back 5 years ago, I only used 2 grease....1, it is from MUGEN...good stuff, but big bottle and pricy, like $20 plus each....and lately I changed to this one.....Yokomo, hard or medium grease.........basicly the same thing as Mugen, but much cheaper and much easier to put them on to the diff (Mugen is a bottle, take forever to see those 50K grease drop to the diff)...and Yokomos can be purchase at TOWER and much cheaper....the cars I used these grease are Impulse and HPi SNRS4.....and I hardly experience any grease leaking or getting THINNER after a long run.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXCNK5&P=7
Old 02-17-2004, 09:01 AM   #1678
For those who is interested in the R40 light weight diet........have you guys think about the weight of the throttle servo?
I am not saying it is going to work....but I remembered back to the old times.....they did use some chopper servo (which is smaller in size = lighter weight) for the throttle servo...
Again, the idea is...get a lighter/smaller/micro servo that has equal or a little LESS speed/torque and use it for throttle.....now a day, what servo cannot pull a 12 engine throttle linkage...but that might be easily shaved 15-20 oz from the car.
Then...use 5 AAA cells and without the ON/OFF switch....that is good 10-15oz total (I think...)
The stock carbon upper plate.........quite a lot of area that we can cut or drill....
Last....drill some holes onto the stock purple chassis.......but not too many (since the chassis is weak enough already)....but I would not recomment to do that unless you are sure you are a very good driver on the track (my stock SNRS4 chassis is like a Z shape now...)
Just some idea.....
Old 02-17-2004, 09:53 AM   #1679
rod_b's Avatar
I was thinking about trying the Yokomo Med diff grease (mostly because it doesn't leak out) and the 2 gear set. The diff grease is supposed to be somewhere around 75K. Do you think it's too stiff for the rear?
As for making the car lighter, I was thinking about removing some material from the bulkheads. They're so bulky and there is so much support all over that a bit of material off of them shouldn't weaken the car. Also thinking about drilling some holes in the spur gears. Not that this would save you a whole bunch in weight but I've seen it done on the old Impulse spurs to try to lighten them up to get a little better acceleration response. Holes in the chassis sounds a little extreme to me...especially if you have no way to balance it. Anyone else with any ideas?
Old 02-17-2004, 11:02 AM   #1680
Just a question, isn't the 1725g weight requirement with the body and fuel included?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
