Old 02-09-2004, 10:11 PM   #1606
Jea3's Avatar
I noticed mine is rubbing also. I had a custom made gear adapter and oneway made when my stock one was defective and HPI took over 2 weeks to respond to me.
I thought maybe we had measured it wrong, but when I did finally get my new one from HPI, it also rubs.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 02-09-2004, 11:15 PM   #1607
smz
clutch adjustment question. It seem that my engine has to rev really high before it starts moving. I know that I have to add/remove shims to get the correct "play" in the clutch. My question is, do I add or remove shims to make the engagement earlier?
Also, sometimes the motor will rev like I have a huge cam like a lumpy cam in a V8 would. What might be causing this, and what should I adjust to correct it?
EDIT: i just found on the trinity site, that the eratic idle may be caused by a leak in the carb. I'm assuming that the leak would be from where the carb connects the motor. Is there a good way of testing if there is a leak or not? I know with cars, spraying some alcohol in the suspected area would cause the idle to bump up a little if there was a leak.
TIA
smz is offline   Reply With Quote
Old 02-09-2004, 11:20 PM   #1608
InitialD's Avatar
Try loosening the 87095 spring pre-tensioner one quater turn at a time first.
Old 02-10-2004, 07:14 AM   #1609
SMZ… Like InitialD said, try first with the 87095 and if your clutch still engage to late, then add more shims to make the engagement earlier.
R40freak is offline   Reply With Quote
Old 02-10-2004, 09:38 AM   #1610
Registered User
OB42TC3's Avatar
Originally posted by AMGRacer
Just had a tinker with the linkages and got them working fine now. You really need to line the motion of the slide up with the linkage itself to get it working nicely.
Has anybody else had a problem with the 2nd gear housing rubbing against the back of the 1st gear spur and oneway holder? Mine rubs a fair bit, was thinking some shims in this area may help.
Or you can tap the oneway bearing in the first gear adapter a little to one side
OB42TC3 is offline   Reply With Quote
Old 02-10-2004, 10:10 AM   #1611
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Me and 4 other top drivers at our tracks have had the 2 speed rubbin gon the gub, but it doesn't effect the cars. If the car is new just make sure to clean it out until it's done rubbing. That way the metal shards wont scare the clutch shoes. After that you'll be alright.
Nrctc3 is offline   Reply With Quote
Old 02-10-2004, 01:48 PM   #1612
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
are you calling me a top driver at the track to, that i've only raced a couple of times and once with the r40
20 SMOKE is offline   Reply With Quote
Old 02-10-2004, 02:02 PM   #1613
Nrctc3's Avatar
Maybe you are...
Old 02-10-2004, 05:27 PM   #1614
20 SMOKE's Avatar
all right, well 3rd in the c main with front weel drive all weekend i'll take it, if hpi calls me back i'll try to get my dif back and show you the next race
Old 02-11-2004, 04:22 AM   #1615
555
555's Avatar
Default R40 with Side Exhaust?
Hi
I just got the kit and not sure if I can use a side exhaust engine for the car?? if I use a side exhaust, do I just get a normal mainfold side exhaust one?? or it needs to use a special one??
Regards
555 is offline   Reply With Quote
Old 02-11-2004, 05:47 AM   #1616
Jea3's Avatar
Is that new light weight super chassis worth the money? I just ordered the graphite shock towers, light weight shafts. What next?
Old 02-11-2004, 07:47 AM   #1617
rod_b's Avatar
Send a message via AIM to rod_b
Pics of my car. Still need to weigh it. Actually, still need to race it.
R40 Front
R40 Rear
Pipe side
Front corner
Chassis
rod_b is offline   Reply With Quote
Old 02-11-2004, 08:15 AM   #1618
Regional Moderator
Darkseid's Avatar
Default Re: R40 with Side Exhaust?
Originally posted by 555
Hi
Regards
Since most of the modern day cars are designed from the start to use rear exhaust engines, chances are you'll need a special manifold for the rear exhaust. Check out some of the Yokomo manifolds that they use for their older RTR cars. www.yokomousa.com They bend up at an angle before curving, so that they clear the rear bulkhead and/or side braces.
If anything will let you use a side exhaust in the R40, that probably will.
Good luck...
TLR 22...Tamiya F104...
Old 02-11-2004, 10:42 AM   #1619
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Rod_B
Have you weighed your car w/ all the parts that you have added? I was wondering if the carbon fiber battery holder is woth the $. Is the battery holder from 3Racing.com???
thanks Jason
jscamry is offline   Reply With Quote
Old 02-11-2004, 10:53 AM   #1620
rod_b's Avatar
jscamry - Yes it is from 3Racing.com. I haven't weighed it but in all honesty, I think the graphite part is the same if not heavier. I was thinking about using a AAA rx pack and removing the upper battery case and just using velcro or shoe-goo to secure the pack to the bottom plate.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
