Old 01-29-2004, 07:06 PM   #1516
I'm running the front sway in the stiffest position and the stock rear sway.
1 deg toe- out frt, -2deg camber frt, -3deg rear, stock toe- in rear, whatever that is. 40/40 on the foam tires but not trued down, they are about 64 mm. How much harder do tires come?
What if I take all the oil out of the front diff? Will it understeer less, on power?
rod b, back out your suspension stop screws.
h82crash is offline   Reply With Quote
Old 01-29-2004, 07:37 PM   #1517
AMGRacer's Avatar
Sways seem to be OK. Possibly use the gold stiffer on in the rear.
Front toe and camber seems ok, stock toe is 3 on high grip you should be able to go to 1-2.
40/40 is ok for a start, mayby go as far as 45/45 or 42/42. 45 is pretty much the hardest.
64mm tires are suicide on a high grip track. Too large by a long way, you need to get them to 58mm or lower (I am talking big grip here now).
Front diff, no good on high grip. You need a oneway to maximise the corner speed, a diff will work but you will always be slower.
Remove droop as I have said before, make it almost zero. With low droop settings it pulls your car down towards the racing surface when cornering lowering the CG. This is a very good thing on high grip surfaces.
AMGRacer is offline   Reply With Quote
Old 01-29-2004, 07:55 PM   #1518
Send a message via Yahoo to LILROBBY
AMG RACER, WHAT IS THE PURPOSE OF THE 4 GEAR DIFF IN HARAS SETUP? WOULD THAT BE GOOD FOR ANY TRACK OR WAS THAT BECAUSE OF THE TEMP AT THE TIME OF THE RACE? ANY INFO WOULD HELP.
If rubbin is racin' then I'm rubbin harder than ever!!
The team Hoopty comeback tour is coming to a track near you!!
Associated T4
Associated Rc8 electric?
Associated TC5
LILROBBY is offline   Reply With Quote
Old 01-29-2004, 08:22 PM   #1519
AMGRacer's Avatar
Most "Pro" cars have 4 gear diffs. Basically you have double the contact surface area on the gear surfaces and therefore the surface has to do less work. Diff gears that are overworked tend to sharpen off and become "grindy" feeling.
Another byproduct of the extra surface area is the more contact area = more operating friction. A 4 gear diff empty of oil or grease has more natural resistance than a 2 gear diff. Therefore you can use lighter silicon oil and achieve a similar degree of stiffness.
For example I use a 4 gear diff with 30000wt oil in my V1R whereas I am using a 2 gear diff with 50000wt oil in my R40. Both produce similar amounts of resistance.
Old 01-29-2004, 08:44 PM   #1520
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
AMG..how about an evaluation of how the car drives?...
I respect your opinion......
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 01-30-2004, 08:36 AM   #1521
AMG, when you say minimum droop, do you mean to maximize suspension travel and preload?
Usually more roll=more traction, correct?
I could be misunderstanding something.
What is your ride height?
It would seem my tire size is the big problem.
Old 01-30-2004, 09:43 AM   #1522
rod_b's Avatar
Send a message via AIM to rod_b
Minimizing droop would be removing suspension down-travel.
Does anyone know what the #700 weight shock oil that comes with car equates to in associated/trinity shock weights. I didn't use the stock shock oil. I usually start my cars with 50wt/40wt but the springs feel really hard. The stock setup must be for high speed, high traction track.
rod_b is offline   Reply With Quote
Old 01-30-2004, 11:40 AM   #1523
That's what I thought. Not sure how that enhances chassis roll as advised by AMG. I set the droop to about 1 mm when I lift the car and unload the suspension. I set the ride height at 5 mm F & R.
Someone said it was 70 wt.
With the stock set up I'm rolling at Revelation. Very high traction and I need to go stiffer.
Old 01-30-2004, 01:27 PM   #1524
AMGRacer's Avatar
On the high grip track I run on I usually set droop so my suspension drops maximum of 1-2mm when I life that end. Usually around 1mm. I invariablily use a 4mm ride height unless it is a very long main.
More roll = more traction to a degree. Droop does not stop roll really, that is mostly the springs job. Droop determines what the chassis plate itself does when rolling. Less droop pulls the plate towards the racing surface when rolling lowering the CG which is good to fight the traction roll. Also very low droop means your chassis will hit the ground before rolling too far.
Old 01-30-2004, 01:31 PM   #1525
AMGRacer's Avatar
It feels like around 60 in the associated scale to me. Just a total guess there.
Old 01-30-2004, 01:35 PM   #1526
AMGRacer's Avatar
This might help with droop:
With a lot of downtravel:
Without much downtravel:
Old 01-30-2004, 10:48 PM   #1527
thanks for the info amg racer
Associated T4
Associated TC5
Old 01-31-2004, 08:14 AM   #1528
AMGRacer, your time is much appreciated.
Old 02-01-2004, 12:24 AM   #1529
rodrigo1508's Avatar
which servo would you recomend?
rodrigo1508 is offline   Reply With Quote
Old 02-01-2004, 05:16 PM   #1530
Hi there well I finally find out a way to put my battery pack I gued some velcro to the pack and to the battery compartment door
so far it had hold on quite well
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
