Old 07-29-2003, 06:01 AM   #1
Default help! rody mod rb 5port carb setting
i have a rody rb 5 port whats the starting point setting I have tried diff setting the engine still run high temp 260. and very hard to restart.
hunt is offline   Reply With Quote
Old 07-29-2003, 07:30 AM   #2
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
i don't have a rody, but some of my fellow racers do. They settings are around 1/2 turn out on bottom, and i think the top is around 3.
Nitro Rules
mtx3racer is offline   Reply With Quote
Old 07-29-2003, 09:12 AM   #3
vones's Avatar
try 2rds from close for LSN n 5 rds for HSN....then tune frm there
vones is offline   Reply With Quote
Old 07-29-2003, 09:49 AM   #4
Default Re: help! rody mod rb 5port carb setting
hunt: the basic starting point for the 'modified' Nova Rossi based
engines...RB, JP, Mugen, NovaMaxx, etc is around 2.5 turns on
the bottom and 4.5 turns at the top end needle...What most
racers ignore or do not know is that the pipe length from the
backside of the header to the seam in the middle of the pipe
is related to the rpm range of the engine...in your case you have
a genuine 40K + rpm engine that requires a measurement of
102mm to 105 mm (4.0 to 4 1/8"). If you run too short a pipe,
the engine tends to run hot because the timing of the exhaust
gases out of the exhaust port collides with the unburnt gases
being pushed back in by the timing length of the pipe divergent
cone...ask any of the racers who are now trying to break in the
new NS12 S3 engines with their old pipes...I know of at least 3
at the Revelations track in L.A. this weekend who had nothing
but overtemp problems until they went to the pipe length
I specified above....I have looked around for pipes of this
configuration...so far I have found two: the Trinity Team
Magic 12 and the Collari Sirio pipe...both are in between 102
and 105 mm. Oh yeah, I use the obsoleted Mugen/Nova Rossi
51601 pipe that was discontinued two years ago...something
tells me that they will re-appear again....good luck with your
Rody Rhoem...he builds good modifieds...too bad he doesnot
provide more specific info on making them work...but then again,
he is French....
jd300zxtt is offline   Reply With Quote
Old 07-29-2003, 11:54 AM   #5
I really appreiate everyone help Thank
Old 07-29-2003, 12:19 PM   #6
rod_b's Avatar
Send a message via AIM to rod_b
Default Re: Re: help! rody mod rb 5port carb setting
he is French....
That is very good info. Have you measured the RDLogics Turbo ROAR Legal pipe? Supposedly modded engines run really well on these pipes. Even Dennis Richey's commented on how well his engines ran with the RDL pipe.
rod_b is offline   Reply With Quote
Old 07-29-2003, 04:55 PM   #7
mckrooz's Avatar
Send a message via AIM to mckrooz
he is French....
Where should you check the length on the pipe? Just from end to end?
mckrooz is offline   Reply With Quote
Old 07-29-2003, 05:06 PM   #8
EVOLUTION's Avatar
double post.
EVOLUTION is offline   Reply With Quote
Old 07-29-2003, 05:07 PM   #9
EVOLUTION's Avatar
Old 07-29-2003, 09:05 PM   #10
Jonathan's Avatar
he is French....
I think the pipe that you are smoking from is too long... try telling your spew to Robbie and Pepe...both running the 514 one piece. one of the shortest pipes...and yeah Robbie was running a JP NS12. I ran the Collari Sirio one piece, which falls between the 102 and 105mm and still came off the track at 280 after 20 mins. It did what it is suppose to do though... super low end and falls flat at the top..
Jonathan is offline   Reply With Quote
Old 07-29-2003, 09:37 PM   #11
InitialD's Avatar
Woow, 2.5 turns out on the LSN is a little lean for the NovaMax. The one I tune already gives a lot of power at 3.5 turns out. Then again, this may defer as climate, fuel and pipe lengths used are different. Well, the 4.5 turns out on the HSN is spot on though...
in your case you have a genuine 40K + rpm engine that requires a measurement of 102mm to 105 mm (4.0 to 4 1/8").
This is interesting. Not meaning any disrespect, the Novarossi inline pipes and the NovaMega TP05 outlaw inline pipes have pipe lengths in between 94 to 96 mm. The RDLogic .15 inline pipe has a fixed pipe length of 92 mm. All of these pipes work flawlessly with the NovaMax (which is from the new NS12 varient) and idles to kingdom come. Did you get the pipe length figures from Dennis?
Old 07-29-2003, 09:42 PM   #12
InitialD's Avatar
Default Re: Re: Re: help! rody mod rb 5port carb setting
I think you're right on that one Jonathan Someone I know ran the Collari pipe on a JP and he was chasing the engine carb tuning all day long.
The Novarossi inline pipes are spot on for the NS12. I've seen most with these pipes paired with the NS12 and never had tuning problems
Carb Setting for Hyper 7 Mach 28 Aceboy Electric Off-Road 1 06-24-2006 06:21 AM
CARB SETTING mattxxx-nt Onroad Nitro Engine Zone 2 02-03-2006 02:11 PM
mugen mt12 carb setting dido41 Nitro On-Road 3 07-24-2005 07:36 PM
mugen mt12 carb setting dido41 Rookie Zone 0 07-24-2005 12:22 PM
Factory setting for NSR12 5port temjin006 Onroad Nitro Engine Zone 1 07-07-2004 09:35 AM
