Old 07-28-2003, 05:41 AM   #1
Default Another Break-in Question Thread
I am attempting to break-in my first engine. It's on e of the Novarossi NS5's. I am using Trinity Monster Horsepower Break-in Blend. It has 18% oil compared to 12% in their reqular Monster Horsepower. The engine in supposedly setup on a flow bench with break-in settings before it leaves the factory. The problem is that with the rich factory settings and the excessive oil in the fuel, I can't keep it running for more than two or three minutes. I wanted to let the engine idle for the first couple of tanks but that's out of the question. I did finally get my first tank through last night. I had to blip the throttle ocassionally. It would still died after a couple of minutes. Then I had to remove the glow plug, tutn it over, let it set a little, replace the glow plug and then I was good for a couple more minutes. This shouldn't be this difficult. Please advise.
jcrouse is offline   Reply With Quote
Old 07-28-2003, 09:24 AM   #2
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
change fuels, i use byrons 20% for break in and 30% for racing. It works great.
Nitro Rules
mtx3racer is offline   Reply With Quote
Old 07-28-2003, 10:44 AM   #3
Default Break In
Although your suggestion may lessen the richness problem, it still doesn't resolve the basic premise of my dillema which is, how are you supposed to run an engine overly rich for an extended period of time at low rpm without loading it up. Thanks for the response but I choose to stick with the fuel I have. That's why I bought the special break-in blend.
Old 07-28-2003, 12:20 PM   #4
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
i had the same problem. and after a long time of that I said screw it and started slowly driving it around. of course the extra throttle helped get rid of the built up oil sitting in the pipe which is what I assumed to be the problem of it not staying started.
and after a while of your 1/2 tanks it cant hurt that much to slowly drive it around.
also you could try running it at a 45 degree angle to let the oil spill out as it is idling...haven't tried this but its a thought.
corvettecrazy is offline   Reply With Quote
Old 07-28-2003, 12:20 PM   #5
you should rev it slightly to remove the clog up
Nitro Rules
Old 07-31-2003, 10:29 AM   #6
Post
hi,since u guys are on the topic of engines.....need some help here. Been trying tp run in a GS15R....everything seems fine, 'cept that the exhaust keep spitting fuel.....thought maybe throtlle a little.....doesn't help....have eadjusted everything....from needle, idle valve and the air fuel mixture screw...can't seem to solve the problem.....or is this nromal?? any help wud be aprreciated, thanks in advance!!
oldnewbie is offline   Reply With Quote
Old 07-31-2003, 12:38 PM   #7
are you sure it is fuel. they do spit oil it wont hurt anything
it could also be going through your preasure line into the pipe and the comming out.
what color is it?
Old 08-01-2003, 11:19 AM   #8
thanks dude...colour's slightly darker than the nitro i'm using.....if it's normal.....guess i'll just run it a couple of rounds to see what happens...thanks again.
Question on nitro break-in Ken4 Electric Off-Road 1 12-24-2006 08:40 AM
Engine Break-in Question Burnz27 Onroad Nitro Engine Zone 14 03-14-2006 09:40 PM
break-in question beetlebz Electric Off-Road 0 08-18-2004 01:32 AM
break-in question bbmfkp Electric On-Road 2 02-04-2003 06:41 PM
Question on break in Cheese Nitro On-Road 3 10-11-2001 04:57 PM
