Old 07-28-2003, 12:31 AM   #1
Send a message via AIM to 2Hard2Handle
Default Break in a new engine?
hi guyz i just got a novarossi top tt12s1 turbo engine and i was just wonderint how many tank do u guyz break in and where is a good point to stop im not a newb just to make sure
2Hard2Handle is offline   Reply With Quote
Old 07-28-2003, 01:06 AM   #2
me43's Avatar
this meathod works pretty wells
me43 is offline   Reply With Quote
Old 07-28-2003, 10:55 PM   #3
hey thanks me43 but when i check my engine temp its around 150's is it any good but i saw smoke coming out from the heat sink?
Old 07-28-2003, 11:19 PM   #4
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Thumbs down SMOKE?
If you see smoke coming from under the heat sink, check the head bolts to make sure they are tibht. Somtimes after you run a new motor they need to be re-torqed.
Slotmachine is offline   Reply With Quote
Old 07-28-2003, 11:24 PM   #5
me43's Avatar
yeah that sounds weird
smoke. hm...
wells you should run it a bit hotter
Old 07-29-2003, 01:11 AM   #6
no not smoke UNDER the heat sink i mean like it heat up and kinda see some smoke and it was around 150's F but i think its normal
Old 07-29-2003, 09:38 PM   #7
mckrooz's Avatar
Send a message via AIM to mckrooz
Maybe you touched the head with an oily hand. If so, it could be the oil burning off the head.
mckrooz is offline   Reply With Quote
Old 07-29-2003, 09:54 PM   #8
EVOLUTION's Avatar
2Hard2Handle,what's up with that loooooooooooooong url,dude.I've got a small monitor and i can't see the whole page when you post,LOL.
As for the running in try to get the temp up to 200F and run it for around 6-7 tanks fairly rich but maintaning the heat range and you should be alright,but please shorten that LINK of yours.
EVOLUTION is offline   Reply With Quote
Old 07-29-2003, 11:23 PM   #9
lol but someone just told me to break in the engine runing it against the wall 6 tank and turn it 1/4 rich then back to 1/4 lean is that a good way he told me he got it from NYS champions (New York State Champions) so lmk if this a good way
Old 07-30-2003, 12:03 AM   #10
EVOLUTION's Avatar
What exactly do you mean "running it against the wall"?
Everyone has a method they swear by,i personally have never taken any more then 6-7 tanks after idling the first on my nova motors,If you want a general idea for running in engines and good advice,check out http://www.parisracing.com/tipspage.htm
Old 07-30-2003, 08:08 PM   #11
when i ment runing it against the wall is letting the car bumber next to the wall not runing INTO but like put it against the wall u know what i mean?
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 10:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 03:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 08:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 04:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
