Old 07-28-2003, 12:18 AM   #1
Send a message via AIM to 2Hard2Handle
Default Fuel Line Filter??
is it alright to put a fuel line filter between the tank and the pipe? if so what whould do?
2Hard2Handle is offline   Reply With Quote
Old 07-28-2003, 07:05 AM   #2
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
why would you need a filter on the back pressure line??? it only flows gases and the ocasional oil but both of those would go through the filter.
corvettecrazy is offline   Reply With Quote
Old 07-28-2003, 07:10 AM   #3
stefan's Avatar
Send a message via AIM to stefan
A lot of people including myself are using them.
It's simply a little insurance that no particles that could be in you pipe make it into the gas tank.
My filter usually has some grime in it when I clean it, so it does the job.
stefan is offline   Reply With Quote
Old 07-28-2003, 09:39 PM   #4
InitialD's Avatar
I would not know if particles would enter from the pipe to the tank. I thought the reason why a filter is put in between the tank and pipe is to regulate pressure... I could be wrong.
In any case, if any foreign matter were to enter the tank, the tank should already have an internal filter.
Old 07-28-2003, 11:35 PM   #5
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default InitialD.
As you and I both know the serpent car has a problem with thiere new in tank filters. It is always a good idea to run an in line filter!
Slotmachine is offline   Reply With Quote
Old 07-28-2003, 11:49 PM   #6
Im2lazy's Avatar
That is the usual purpose, but, it seems putting it there to keep crap from entering the tank is the new "en-vouge" thing to explain the use of a fuel filter on the pressure line . It is a pretty good idea, but totally unnecessary for onroad cars that only see the race track. If you drive in very dirty parking lots (something I don't highly advise) it could be helpful.
Im2lazy is offline   Reply With Quote
Old 07-29-2003, 12:28 AM   #7
InitialD's Avatar
Default Re: InitialD.
Well, I was referring to general cars... I didn't want to get Serpent specific
Yup, an inline filter to the carb it is... But this is a fuel filter in the pressure line between the tank and pipe they are debating here
Old 07-29-2003, 12:33 AM   #8
InitialD's Avatar
I guess that would be it.
Talking about this fuel filter in between the tank and pipe, Mugen has a part number for the MRX-3 which I believe is called the Pressure Chamber Set : Part # B0116. Now what did Mugen say that was for?
Is that a real fuel filter named as a pressure chamber which is kinda "en-vouge" thing like what you say?
Old 07-29-2003, 12:35 AM   #9
B
you do not need that kind of things for touring cars
1/8th on road, maybe
not touring
B is offline   Reply With Quote
Old 07-29-2003, 12:47 AM   #10
InitialD's Avatar
Why not touring? What is the explanation for that? Both TC and 1/8th scale cars will run on similar on road tracks...
I'm actually interested to know what is the real reason for the pressure chamber in between the tank and the pipe on the MRX-3 is needed.
Old 07-29-2003, 01:30 AM   #11
Im2lazy's Avatar
I see that sort of thing for 1/8 off road buggies more actually.
You can do it to whatever car you like, but it borders on excessive, unless you are running offroad, dusty onroad track or have an extremely long main to run in. If you worry about this stuff... put it in, but otherwise, its like wearing a huge hat when the day is cloudy.
Old 07-29-2003, 01:59 AM   #12
InitialD's Avatar
I like that analogy
Old 07-29-2003, 02:07 AM   #13
Im2lazy's Avatar
Thumbs up
Some people say I have a way with (fumbling) up words , but every once in a while, I make sense when I talk .
Old 07-29-2003, 02:32 AM   #14
FREAKAH's Avatar
Maybe it's to help neutralize exhaust pulses so the engine gets a steady fuel pressure. Same thing like using a long pressure line but without the reduced pressure from using such a long pressure line.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-29-2003, 02:44 AM   #15
Im2lazy's Avatar
That is what it was generally used for before
I've personally done it and does work quite well because I usually like to keep my lines short so they don't flop around and get into dangerous spots.
What Fuel Filter? Captpete Nitro Off-Road 2 07-27-2008 10:24 PM
Run with or without a fuel filter? GHETTOTEACHER Nitro Off-Road 5 08-14-2007 08:50 AM
Fuel Filter? customride Rookie Zone 11 05-27-2007 02:51 PM
in line fuel filter question atebit Rookie Zone 2 05-13-2007 10:39 AM
fuel filter and air filter GReddy Electric Off-Road 1 07-10-2004 08:04 AM
