Old 07-27-2003, 09:15 PM   #1
NitroNut's Avatar
Default Help with O.S engine
I am trying to break in my os tr engine i've gotten 2 tanks in and whenever i try to put the car on the ground the engine just shuts off, can ne one help me plz?
NitroNut is offline   Reply With Quote
Old 07-27-2003, 09:17 PM   #2
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Check the clutch.
Dan is offline   Reply With Quote
Old 07-27-2003, 09:23 PM   #3
NitroNut's Avatar
The clutch seems fine and dandy what should i check for exactly?
Old 07-27-2003, 09:45 PM   #4
Dan
Dan's Avatar
What car is this?
When I had my RC10GT with MIP clutch, the spring got loose and would cause my engine to stall everytime I put it on the ground. When I had my Nitro MT with standard clutch, one of the clutch springs snapped and it did the same.
Usually this is one of the more common causes since the engine will idle fine or will idle a little high but once you put it on the ground where it will have more load, the engine will die out.
Old 07-27-2003, 10:29 PM   #5
NitroNut's Avatar
Its on a v1r and i jus checked the spring and it still in tack i dunno whats up wit my car i have worst of luck when it comes to engines first one i had couldnt start cuz of idle second one the engine was pain and now this engine. sigh...
Old 07-27-2003, 10:51 PM   #6
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Talking nitro nut/clutch
Check to see if your bearings on the clutch have not seized up,second: when you push in on your clutch bell make sure the bell does`nt hit the flywheel or the clutch pads.
Do the wheels of your car spinn when the car is at idle, I mean when the car is not on the ground?
Slotmachine is offline   Reply With Quote
Old 07-27-2003, 10:59 PM   #7
check the drivetrane to make sure its free and try turning the idle up a tad to keep it running. run car to adj high needle then adj low and idle respectively. it might just be real rich on the low end.
SC Racing is offline   Reply With Quote
Old 07-27-2003, 11:06 PM   #8
Old 07-28-2003, 08:47 AM   #9
Default OS 12TR
I just broke in my engine 2 weeks ago. I had similiar problem as you described. I end up opening the idel stop screw so the opening is close to 1mm instead of the factory setting of 0.50mm. I also lean out the HNS to 1 1/2 from the default of 2 turns out.
The engine was breaking in around 170 to 180 deg.
Hope this help.
Supra66 is offline   Reply With Quote
Old 07-28-2003, 09:22 AM   #10
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
nitronut- turn your idle screw in about 1/8-1/4 of a turn. this will help it when it hits the ground
Nitro Rules
mtx3racer is offline   Reply With Quote
Old 07-28-2003, 01:41 PM   #11
NitroNut's Avatar
Ok i should turn it left or right?? thx u guys for all the posts. and yes my wheels they spin when the car isnt on the ground.
Old 07-28-2003, 08:08 PM   #12
turning it in should be tightening it so its to the right
if the wheels are spinning at idle after engine warms up sounds like the idle is set to high. take the air filter off and check the carb opening when at idle. the opening should be about the thickness of a fingernail or 1 mm.
Old 07-28-2003, 09:42 PM   #13
check to make sure that the clutch spins freely from the flywheel. If not, then theres somthing wrong with the clutch.
R1ceboy is offline   Reply With Quote
Old 07-28-2003, 11:13 PM   #14
Thumbs down Wheels
If the wheels are spinning at a resonable idle when the car is not on the ground then you definately have a clutch problem!
Old 07-28-2003, 11:44 PM   #15
AMGRacer's Avatar
That is bad, very bad. What this means is that your clutch is engaging the clutchbell at very low RPM (I assume your idle is low).
You have a centax clutch or shoe type?
AMGRacer is offline   Reply With Quote
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
