Old 07-31-2003, 09:12 PM   #31
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
then the clutch shoes wont be completely on/ in the clutch bell
is that bad too?
edit: this pic is with the clutch pushed ouot as far as it will go
but it will go in far enough to be flush with the fly wheel
pic in next post
corvettecrazy is offline   Reply With Quote
Old 07-31-2003, 09:23 PM   #32
Old 07-31-2003, 09:41 PM   #33
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Red face shims
Originally posted by corvettecrazy
The shim he is refering to would only be about 3/5 thousands of an inch. thick. Try stoping by your L.H.S. and see if they can hook you up.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-31-2003, 09:50 PM   #34
oh...well our hobby shop is very pittyful and would probably have to order it and the last few orders I had never came. but I can try
Old 07-31-2003, 09:52 PM   #35
vones's Avatar
or u culd find some replacement shims in hardware shops.....0.1 mm, 0.2mm,0.3mm....as shims will always come in handy....
vones is offline   Reply With Quote
Old 08-01-2003, 06:13 AM   #36
but what about the clutch shoes?? shouldn't the be completely inside the clutch bell at all times????
Old 08-01-2003, 10:02 AM   #37
NitroNut's Avatar
Ok quick question never happend to me before but when I put on my brakes it closes the entire hole in the carb how do I adjust that, do I adjut the idle screw or what?
NitroNut is offline   Reply With Quote
Old 08-01-2003, 12:09 PM   #38
yes the idle screw
you must have loosened (lowered the idle) which means you turned it left
you need to turn it RIGHT to increase the idle and prevent it from closing.
Old 08-01-2003, 12:29 PM   #39
NitroNut's Avatar
gotcha thx.
Old 08-01-2003, 09:22 PM   #40
what about my clutch shoe problem????? scroll above
thanks
Old 08-01-2003, 10:10 PM   #41
NitroNut's Avatar
Well.. the problem you probably have is what the others have been saying ur cluch bell is probably rubbing on the flywheel and you should just get some shims and place in there.
Sorry about not responding to your question I thought the others explained it for you already.
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
