Old 04-28-2008, 04:10 PM   #1
Armedforces's Avatar
Default Car Set Up ?? Clutch Pre-Load
Hello to everyone I have few questions regurding on road set up:
What is clutch pre-load what does it do ?
What is clutch gap and what does it do ?
Diffrance between solid axle and dif how does it work ?
And one more thing lets say that on the I have my line on a race track very cosistant laps around 14.200 what would be the first thing to adjust on a on road car to get better lap times ???
Armedforces is offline   Reply With Quote
Old 04-28-2008, 06:15 PM   #2
dj apolaro's Avatar
What is clutch pre-load what does it do ? - How tight the spring is to move the show towards the bell
What is clutch gap and what does it do ? - The distance the shoe moves to hit the bell and fully engage
Diffrance between solid axle and dif how does it work ? - solid has a direct action. The diff can be adjusted and offer more or less diff action, which affects turn in, mid and exit on power steering
And one more thing lets say that on the I have my line on a race track very cosistant laps around 14.200 what would be the first thing to adjust on a on road car to get better lap times ???You want to be able to hold the power deeper in the turn and get on power earlier. Practice that first. Aslo a car easy to drive is normally not the fastest. The car needs corner speed. Make adjustments with roll center, suspension, tires, sway bars, etc.
Hope this helps to start with,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 04-28-2008, 07:06 PM   #3
Clutch preload is how high you want the engine to rev before the clutch engages. If the car has low RPM and is sluggish off of the corner you can tighten the preload and allow the engine to rev higher before engaging. If the rear end is fish tailing coming out of the corner on the power, you need to back off the preload a little.
Clutch Gap is the distance from the clutch plate face to the clutch bell face. If the gap is too large the clutch won't fully engage and it will fry the clutch disc. If the gap is too close you will cause the clutch to engage early or if it is too-too close it will destroy the thrust bearing. Keep this gap between .30 to .40 mm .
This way you can adjust your clutch preload to work for the track and then just maintain the gap
Solid axle "locks" both wheels together during power and braking ( doesn't turn well off power, turns real well on power) like an 1/8 scaler
Diff allows the wheels to turn independently of each other and then can be adjusted (tightened or loosened) for on power and braking ( touring cars use these
If you have nice consistant laps going, snug up the clutch a little and get from corner to corner quicker (see less fuel economy) then brake deeper into the turn and then get the power on earlier off the corner.
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 04-28-2008, 07:08 PM   #4
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you can also go to the NT1 setup book it will give all the info you need to setup eveything on your car http://www.teamxray.com/teamxray/pro...ria=0&catName=
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-28-2008, 08:27 PM   #5
Much thanks guys for the advice and the funny thing is I'm about to get XRAY NT1 as you all menchoned here
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 03:54 AM
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 01:34 PM
Xxx-s G+ Mother Load!!! imprsme R/C Items: For Sale/Trade 39 04-09-2005 06:58 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 09:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
