Old 10-01-2008, 02:32 PM   #106
My bad... I see the weight issue between the 220mm and the 235mm has already been raised in the ROAR Nats. thread... Hopefully, ROAR will make the right and fair ruling on this.
RC_Alan
Last edited by rc_alan; 10-02-2008 at 08:37 PM. Reason: I really need to use spell check... lol
rc_alan is offline   Reply With Quote
Old 10-01-2008, 03:41 PM   #107
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I was doing some wieght comparisons between the 1/10 sedan and the 220mm car. The 220 car is 74g heavier to begin with running the same servo's engine, ect.... As it sits after testing with rims for tires, my car sits in close to 1850g with no added slugs..... Is 150g a lot?
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 10-01-2008, 03:45 PM   #108
Team Kamikaze's Avatar
Weight limit for the new 220mm class should be set at 1875 grams.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-01-2008, 04:06 PM   #109
rcfoolz's Avatar
1875 sounds good for when they make the rules for it, but for now, we will have to run a little heavy....anybody got A LOT OF LEAD?
Old 10-01-2008, 08:12 PM   #110
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
start by running standard battery with the heaviest brass tray you can get and then leave all the light weight stuff in your tool box and put the stock screws, pivot balls etc. back on your car
Speedypeterb is offline   Reply With Quote
Old 10-02-2008, 09:42 AM   #111
grub's Avatar
what no bling
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 10-02-2008, 01:32 PM   #112
aturbotony's Avatar
We'll need a 10port .12 just to go fast
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
Old 10-02-2008, 04:14 PM   #113
Francis M.'s Avatar
Adding over 200 grams will defeat the purpose of the 220 class to begin with.
Tire wear will go up and I don't know if any one has even tested the car with that much weight???
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-02-2008, 04:49 PM   #114
rcfoolz's Avatar
Well, I have been able to add 208 grams of weight to the car and have it all secured. However, I still need to add an additional 70grams to get it up to the 2000 gram weight limit. I leaded in the battery tray, the front chassis opening and added 65 grams to other areas all down the center line. I sure feel sorry for a turn marshal if they get in front of one of these cars. They will weight in at just over 4 1/2 lbs.
If nobody shows up with a 235mm car, we might be able to ask for consideration of the weight.
Old 10-02-2008, 05:02 PM   #115
dj apolaro's Avatar
It is not the 235 cars that you have to worry about. It is the advantage over the 200mm car that is the issue. If you go with less weight it makes for an even larger advantage for the 220mm car over the 200mm. It will be interesting to see how many people actually run this class. It makes for high expenses and Mike S. is the only team guy running. Paolo and I are not and the others that have already signed up only signed for the sedan class. Good luck though it should be fun to watch these cars.
DJ
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-02-2008, 07:14 PM   #116
rcfoolz's Avatar
The car feels like a sled at 1994.7g....I cannot imagine adding another 6g.... I do wish to run the car, but not at the expense of twisting a chassis or destroying the car with an extra 10+ onces (275grams). If running a .15 engine, I could see running at the higher weight, but 1850 would be a good weight to be "considered" for the 220mm cars. At 4lbs 6oz VS 3lbs 8oz, The 200mm car I think would have a large advantage over the 220mm car running the same engine, wouldn't you think?
DON'T READ THE REST OF THIS UNLESS YOU LIKE NUMBERS!!!!!
If you look at the size of the 200 mm car and the size of the 235 cars, and the wieght difference between the two, is 275grams.
Taking 35mm of width and devide the wieght difference by 35 then times it by 20mm for the 220 cars, you would come up with a wieght of 1883. BUT on the same token the 220 cars run .12's not 15's, so if you look at that difference between the two engines, the .12 are 80% the size of a .15. and a smaller fuel tank by 6.25%, Take 73.75% the wieght difference of 153grams gives you 113 grams...that makes a "fair wieght" of 1837.5 grams.....make it an even number of 1835grams.....
Old 10-03-2008, 02:21 AM   #117
MHarrison's Avatar
Like Dj Said. The car is up against a 200mm car. The 220 runs ALOT bigger tires, So what disadvantage you may have in weight, you will gain alot of advantage in GRIP.And I thought I read that the 220 can be just as fast as a 1/8 scale????Thats a fast critter right there. Besides One of the 6 of you will have a National title.
MHarrison is offline   Reply With Quote
Old 10-10-2008, 04:35 PM   #118
madbeats's Avatar
Default NT1 Knack
cool
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 10-11-2008, 07:36 AM   #119
madbeats's Avatar
Default MTX Meets NT1
cool
Old 10-11-2008, 05:51 PM   #120
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
madbeats - very sexy rides w/ the KNACK kit. I miss my MTX4 and nitro onroad in general.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
220mm GPR Class Arboleda Nitro On-Road 108 01-04-2009 08:24 PM
3 Racing TA05 Conversion!! Refujiado R/C Items: For Sale/Trade 3 10-10-2007 03:21 PM
JT racing MSR conversion for sale! Blacktiger355 R/C Items: For Sale/Trade 9 08-18-2007 06:15 AM
Knack Racing Subaru B4 RC MARKET Nitro On-Road 0 03-14-2007 03:23 PM
******************************* JT Racing/TMAXX Conversion ****** Brandon Powell R/C Items: For Sale/Trade 17 04-28-2005 07:51 PM
