OS .12TZ - 3 Port vs. 5 Port
do you want to stay legal for racing or is that not a concern?
My local track usually has a few club races and they are pretty much outlaw so thats why Im considering the 5 port. Honestly, Im not going to be racing much within the ROAR or IFMAR Rules so I'm just curious on seeing what kind of power difference these engines make. Maybe in the future, Ill try to have both the 5port and the 3port so If I ever decide to race legally I can swap in the 3port, but thats wishful thinking for now.
For one, the 5 port is cheaper but you won't see the difference unless your track is reasonably "big" or has a long stretch of straight. I have both and I usually use the 3 for smaller/street tracks, and use my 5 for the larger and straighter tracks.
Be sure to spend time breaking in the engines. The OS take some effort but once done, they are great.
Here is where it gets tricky the best pipe for the os was o.s 1040 pipe and header combination but i hear that that o.s is not making that pipe any more. I have tried every thing from the rd logics pipes to the nova rossi 2630. The o.s like pipes that are designed like to the 1040 like the nova 2601. this pipe worked well on the os. If you concerned about cost the rd logics turbo pipe are good and very sturdy.
I raced a TZ 5 port on the track and we were very close on the straights with me in the lean. Probably he had the wrong pipe on the car and could work on tuning to get more. Then again I have a Carlson TZ tuned .12 so no telling there. You won't need a 5 port to beat the rest anyway - just go with the best pipe you can get or get something slightly faster for the same price.
i had the 12tz-p5 and now its a 12tz-p3 after rebuild. i used the os 1040 pipe on both... have to say it a very good pipe for this engine, car felt responsive. fuel mileage with this pipe is quite good.
3port - normally has low-end torque and is on better fuel consumption between the 2. very good for small to medium size technical tracks.
5port - has the upper hand on top end and good for large tracks with long straights. sips fuel more though compared to its 3port brother
I think the O.S. Tz 5 port will be good for the new GPR kawahara conversion since the 5 port has more RPM's up on top.
