JLR Red Dot .12 Engine Help
i have the JLR red dot on road engine (not evo 3), can anyone tell me if the mega (picco) .12 conrods are the same in these two engines. want to get a spare conrod for my JLR .12, ive heard that they are picco engines as are the mega (serpent), so would the conrods be the same.
thanks
rias
thanks
rias
As per manual should be 0.3mm ( 0.1+0.2).
I run my Mega with 16% and 0.3mm for large size track.
If the track is short you may try to remove a 0.1mm to gain some bottom end
it is the same ?????
hi, i have a picco .12 jl red dot and see this auction by ebay:
IT IS THE SAME ??
--- IDM .12 EVO 2 P/L picco novarossi serpent ---
http://cgi.ebay.com/ws/eBayISAPI.dll...ksid=p3907.m29
regards from germany
IT IS THE SAME ??
IDM is not the same as JLR! They are both Picco based, but there are some slight differences.
