Old 04-19-2008, 12:26 AM   #1
Default picco P9r plugs???
Do you have to run picco plugs in these engines?
or will novarossi plugs work?
many thanks
kurtcash is offline   Reply With Quote
Old 04-19-2008, 12:33 AM   #2
many thanks
Only PICCO plugs will work on PICCO engines, now if you want your PICCO to leak then go ahead use a Novarossi plug and be ready to buy a new head button.
hello is offline   Reply With Quote
Old 04-19-2008, 12:42 AM   #3
nitrodude's Avatar
Yes, you HAVE to run picco plugs, nova plugs will leak.
http://kamikazetoysandhobbies.com/pr...php?cat=4&pg=2
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-19-2008, 06:03 PM   #4
Split Pin's Avatar
Default Plugs
No you don't have to run Picco plugs. I have a Trinity Picco XP12 which I purchased from USA & have tried Novarossi plugs & they worked fine but I found them to be faulty, the end of the coil came loose from the body (must have been a bad batch).But the best plug I found is the Odonnell Racing ODO77T & I get great HP out of the motor & last a long time up to 4 race meets & still OK. These plugs are also pure platinium while other plugs have iridium alloyed into them.
Split Pin is offline   Reply With Quote
Old 04-19-2008, 09:23 PM   #5
nitrodude's Avatar
I repeate, you HAVE to use Picco plugs. Picco Plugs have lasted me way more than 4 race meets. I havent changed mine since january.
Steven Muller
Ronin Speed Parts
Old 04-19-2008, 09:39 PM   #6
Team Kamikaze's Avatar
Not only that the plugs last longer, the taper of this new version PICCO's are different from the old engines like XP 12, also if you put an Odonell plug in the PICCOs it does not seal properly and as hello just said it will leak and more likely damage the tread in the head button.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-20-2008, 06:05 PM   #7
Split Pin's Avatar
I think kurtcash should have said what model Picco he has or intending to purchase, because there are a few different brands of piccos ie picco, trinty, ofna, adam drake, etc . This is good to know that the new Picco needs Picco plugs I assume this is written in the instructions some where clearly and the reason as you have mentioned. Thanks for the info.By the way, that is 4 or more race meets since January with 4 qualifiers of 5 mins & 20 min finals. Thanks for the info.
Old 04-21-2008, 12:11 AM   #8
Colt4g63's Avatar
Picco or Dynamite plugs are what I personally use.
Adam Blevins Owner/Operator of AB Mods X-Dyno equipped and World Record holding engines!
www.ABMods.com
Colt4g63 is offline   Reply With Quote
Old 04-21-2008, 09:20 AM   #9
Dynamite for some reason does not seem to work well with the P9's, with the 12 it's not that bad, I believe the dynamite plug are hotter than the original PICCO plugs, and they don't last, also if you compare the coils it is way skinnier than the PICCO plugs.
Old 04-21-2008, 10:52 AM   #10
Send a message via AIM to FITO
you can use mega and sirio onroad plugs aswell both the same as picco plugs
RODOLFO
KYOSHO M3, PICCO, KO PROPO, MAXY FUEL
FITO is offline   Reply With Quote
Old 04-21-2008, 12:15 PM   #11
Colt4g63's Avatar
I have yet to test the life span on the P9R using the Dynamite compared to Picco plugs. On the JLRs the Dynamite are what I use and what are in my JLR on the dyno when it made 1.22HP and 38 Oz/IN They worked VERY well on the JLRs. I run the 8s in it. I use them as they seem to work well for me and the local hobby shop here stocks them and there cheap I will take your word for it and grab some Picco plugs off you and throw them in the P9R and see how they compare to the Dynamites as far as longevity and power on the dyno. Play with heat ranges etc
www.ABMods.com
Old 04-21-2008, 09:49 PM   #12
You will definitely notice the difference when using it with the P9R, switching from a PICCO P7TC to a Dynamite plug.
Old 04-22-2008, 12:20 AM   #13
Roelof's Avatar
Send a message via ICQ to Roelof
Because the bore/stroke is the same as Novarossi you can always get an Novarossi underhead to use NR plugs in your Picco
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 04-22-2008, 12:41 AM   #14
Obviously you never tried it, Novarossi head button's mounting holes are different from the PICCO head button's mounting holes, it won't line up.
Old 04-22-2008, 02:22 AM   #15
Colt4g63's Avatar
The head button/combustion chamber has ALOT to do with how the engine performs. Just throwing any head button on and engine is not a good idea.
www.ABMods.com
picco p6tc plugs tony block R/C Items: For Sale/Trade 0 09-06-2008 12:51 PM
Breaking in picco .12xp and keeps blowing plugs???????? BIG DADDY8 Nitro On-Road 4 08-17-2008 07:21 PM
Picco Plugs bherzog513 Nitro On-Road 34 07-31-2008 07:25 PM
JLR .12 Red-Dot Picco vs Z.12R Team Spec.3 vs Picco (#P1-4073) P1-R .12 RE EVO 3 Tur nickiphorosn Onroad Nitro Engine Zone 11 04-13-2007 10:18 PM
picco .21 + extra plugs and clutches for sale houston R/C Items: For Sale/Trade 9 03-02-2007 08:39 AM
