which set-up system? >
Old 07-24-2003, 12:12 AM
Advanti's Avatar
Default which set-up system?
hi all,
i would be getting a set-up system soon, which is the better one?
Hudy - plastic made or the 'Team Magic' - alu. made ones? or any other brand?thanks
Advanti is offline
Old 07-24-2003, 12:26 AM
I've been pleased with my Integy setup station. It doesn't have bearings like the Hudy but its also not as expensive. Spend the extra $10 and get the case with it.
Lythion is offline
Old 07-24-2003, 01:32 AM
eddiethefish's Avatar
Default Re: which set-up system?
Originally posted by Advanti
hi all,
Go for Yokomo YT-SGN setup station.
eddiethefish is offline
Old 07-24-2003, 02:41 AM
Que
If you want to exatly copy or duplicate some ones hot set up it is best to use the setup station that they use and most all top drivers use the Hudy station as do i. Also it a great product i have the integy one and it is a little slopy where the pieces come together, Probably due to the fact that they don't use bearings like the hudy system
Que is offline
Old 07-24-2003, 02:45 AM
Advanti's Avatar
thanks que, eddiethefish & lythion.
i am goin for the Hudy ones, thank you all again.
Advanti is offline
Old 07-24-2003, 02:47 AM
Que
Hey man no problem that is what the fourm is for
Que is offline
Old 07-24-2003, 02:48 AM
Que
Man i love this board
Que is offline
Old 07-31-2003, 07:13 PM
V-1-R's Avatar
Default how about this, good?
PMB set-up system?
http://www.pmbproducts.com/
V-1-R is offline
Old 08-06-2003, 12:38 PM
I'll 2nd that!
Nuke is offline
Old 08-06-2003, 03:54 PM
che
che's Avatar
I have the Integy one and love it.
I run Associated products and you do not have to modify the Integy board to fit (no reaming or dremeling required).
And it is less expensive. Definetely get the carry case.
che is offline
Old 08-06-2003, 08:09 PM
Que
let my add this i have the integy one also i was trying to save money when i first started with this pivot ball suspension on the higher end cars i saved some money and bought the hudy one later and i have found that there is a big difference between the two!! the hudy doesent have as must slop movement in the verticle upright that the triangles hang from. that equals more precise settings!!!!
Que is offline
Old 08-06-2003, 09:24 PM
You could probably get some flange bearings for the Integy and still be under the price.
Lythion is offline
Old 08-06-2003, 11:55 PM
Que
That might work if you were a machinest because you would have to drill out the holes in order to get them to fit and if you did that with out the precise equipment that is needed for that job you throw off the seting capability of the machine
Que is offline
Old 08-07-2003, 12:01 AM
EVOLUTION's Avatar
On the topic of setup systems,has anyone seen or heard of a storage case for the hudy system?
EVOLUTION is offline
Old 08-07-2003, 12:36 AM
Que
Well i made mine out of a old exercise mat. Any thick foam or Neopreen type material would work well. I made mine to fit inside my tool box shelf so it is safe and with me at the track for fast adjustments!
Que is offline
