Old 04-14-2008, 09:41 AM   #1
Default V1RRR WCE Throttle Servo
My WCE is one sick fast car that handles great but the layout of the throttle servo just irks me... I have two servos dead and i attribute their failing due to side impacts on the throttle servo side of the car during weekend mini-races... and cosmetically, it just seems wrong for the servo to be there(at least for me)...
My questions are:
a. Anyone with servo failures like mine due to the layout of the throttle servos on non-Evo V1RRRs? Any smart way to solve this issue?
b. Can I just get a evo radio plate to convert the layout of my WCE to that of the evo-v1rrs? what is the minimum of parts needed to do that?
katze is offline   Reply With Quote
Old 04-15-2008, 12:22 PM   #2
Speyederjedi's Avatar
I've had both the RRR WC and the RRR EVO. I did initially have a falure on the RRR WC due to an impact to the servo side of the car but it was because of the mounting screws used. The screws mounted the servo very rigidly to the upper deck and the shock from the impact was too much. A buddy of mine looked at how my servo was mounted and suggested inserting some rubber servo grommets he had and so I did. They allow the rubber to absorb most of the shock at impact. After using them I went over a yr with the WC kit without losing another servo and then moved over to the EVO kit. I now drive the Team Magic G4RS but to this day use I rubber grommets for mounting all my servos so on impact the rubber soaks up most of the shock to the servo. I haven't lost a servo in over 2 years. If you want to get the EVO upper deck to change the layout that would work as well. Both decks are interchangeable. Most hobby shops have the servo rubber grommets I am refering to.
G4RS
Speyederjedi is offline   Reply With Quote
Old 04-16-2008, 05:51 AM   #3
G4RS
So you mean i will only need the upper deck to change the servo layout? no other parts will need to be changed?
Anyway, how does the G4RS compare with the V1RRR.
Old 04-16-2008, 07:32 AM   #4
The receiver plate will change also.
V1RRR Evo WCTE - Sirio STI/NR 353 MM - Futaba 3PM FASST
FW05TRR - GXR15 Tunned - Futaba 3PM FS Pro
Ramiel is offline   Reply With Quote
Old 04-16-2008, 07:43 AM   #5
KyoshokiddT.D's Avatar
My questions are:
i am going to be honest with you i have had more servos go in the past and i dont think it is the car i run my servos standing up and they still seem to go bad and they are not cheap servos ko propo digital futaba s9550 and a airtronics 94358
KyoshokiddT.D is offline   Reply With Quote
Old 04-16-2008, 08:21 AM   #6
You will need the side plate to mount the receiver and some servo mounts for the throttle/brake servo to mount it to the deck. Use the rubber if possible.
G4RS
Throttle servo?!?! TeknikalMugen Nitro Off-Road 26 06-26-2008 06:10 AM
Steering servo and Throttle servo same speed? straightaway Nitro On-Road 4 11-06-2007 08:21 PM
Throttle servo gojoecrewchief1 Rookie Zone 5 09-14-2007 08:33 PM
Airtronics 94537 Servo Throttle Servo HS Imdadundada7 R/C Items: For Sale/Trade 23 06-19-2006 09:55 PM
Throttle Servo?? Hoggy Nitro On-Road 4 08-02-2005 12:13 PM
