Old 07-21-2003, 03:37 PM   #1
spenzalii's Avatar
Send a message via AIM to spenzalii
Default Changing plug makes car run rich?
Here's the scoop. I have a .15 CV-R which I broke in with the included A8 plug. After break-in and tuning thru 1/2 gallon, the plug gave up the goods. At the time, temps ran around 230-240, with a nice, thin trail of smoke. When the plug died, I swapped it with an O'Donnel plug my shop gave me. While the car fired up, I noticed the car bogged down and loaded up a bit if it idled more than 4 seconds and the smoke trail was now quite a bit thicker, indicating the mixture was now a bit rich. Sure enough, the temps were now around 215. Is this normal? Will I have to retune every time I switch brands of plugs? While I heard good things about the O'Donnel plugs, and there's only 2 kinds (1/8 and 1/10), I still have a few A8 plugs I can use.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 07-21-2003, 04:45 PM   #2
Francis M.'s Avatar
it is normal to have to retune when changing
brands of glowplugs especially when changing
to a different temp plug.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-22-2003, 07:10 AM   #3
spenzalii's Avatar
OK. I'll check to see which plug (either the 77 or 99) and lean out the carba bit. I'll just have to note how far in I have to go so when I go back to the A8 plug, I won't kill the engine
changing from hot to cold glow plug srac cr ot wen Nitro Off-Road 1 07-30-2008 09:59 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Low-speed too rich? sstupid Onroad Nitro Engine Zone 6 03-27-2006 10:08 AM
Racer Rich Packfan Buyer/Seller dispute and Feedback discussion forum 1 02-24-2005 05:22 PM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
