Old 07-20-2003, 01:48 AM   #1
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default Understeer
Hi all, may I know that stock transmitter can cause the steering understeer?? Mean We need to use big turn to go in a tight corner, I already maximum the dual-rate. Please advice. Thanks.
khoo
tkhoo is offline   Reply With Quote
Old 07-20-2003, 12:54 PM   #2
B
mm
maybe try tuning your car to have more steering?
B is offline   Reply With Quote
Old 07-20-2003, 11:28 PM   #3
Im2lazy's Avatar
Have you tried a different steering servo? It could be shot. Also, is your car achieving maximum steering travel? Something could be blocking the way of the servo horn/servo saver, that could prohibit a car from having a tight cornering radius.
Also, it might be beneficial to have someone put your car on a setup station (hudy, integy, etc.) to see if your car is getting adequate steering throw. If you can find someone with a board to help, your car should have around 40 degrees of throw in both directions.
Im2lazy is offline   Reply With Quote
Old 07-20-2003, 11:38 PM   #4
me43's Avatar
try maxing out the EPA(or until your servo horn hits something)
jw
do u power into the turn, or are u coasting into the turn?
me43 is offline   Reply With Quote
Old 07-20-2003, 11:48 PM   #5
tkhoo's Avatar
me43, may I know what did you mean "do u power into the turn, or are u coasting into the turn?"
Im2lazy, I haven try other type servo. One of the racer saying that I need to use digital servo and Tx. But when I turn the steering it look like turn a lot >20 degree. Yes, I try to use Hudy to do the alignment on chamber, toe, caster.
Pls advice on the digital servo with stock Rx and Tx. May I know the weight for front shock and rear shock and rear diff. Thanks.
khoo
Old 07-20-2003, 11:54 PM   #6
me43's Avatar
i mean
are u gasing into the turn, followed by a hard brake
or are u slightly braking just before the turn and kina coast till you reach mid point of the turn
Old 07-20-2003, 11:58 PM   #7
tkhoo's Avatar
My style is when go into a corner, I release the throttle go into the corner and press again. I totally no brake before the turn. I brake when I understeer mean when want to hit the side track. Please advice.
Old 07-21-2003, 12:04 AM   #8
me43's Avatar
maybe u should try using a little brake
do u have a front one-way?
i assume u do since thats the kind of driving style a front one-way requires
a little brake wont hurt
Old 07-21-2003, 12:06 AM   #9
tkhoo's Avatar
yes, I using front one way. So, I need to change the style.........BRAKEEEEEEEEEEEEEEEE A BIT and GOOOOOOO
Old 07-21-2003, 12:10 AM   #10
Im2lazy's Avatar
No steering with a one way... .
One-ways have so much more corner entry steering, I couldn't imagine it.
Did you say only 20 degrees of servo travel in both directions? That is half of what my car has.
Oh, yeah, unless you use the 3pk with the HRS reciever, digitals are in no way a necessity.
Old 07-21-2003, 12:16 AM   #11
me43's Avatar
yeah i just remembered that(sorry i dont run a one-way)
you must be taking the turn really fast, or as im2lazy said, ur servo throw is being limited by something
what kind of car do u have?
do u have a pic of the turn?
Old 07-21-2003, 01:01 AM   #12
tkhoo's Avatar
Yokomo GT4 RTR. Sorry, I don't have digital camera.
Old 07-21-2003, 01:03 AM   #13
me43's Avatar
doesnt that car have a soild rear axel?
about how fast do u take the turn?
how does everyone else take the turn?
Old 07-21-2003, 01:06 AM   #14
Im2lazy's Avatar
...your car should have around 40 degrees of throw in both directions....
I'll double check what I've got, but around 20 degrees is very little throw (or so I believe).
Old 07-21-2003, 01:11 AM   #15
Im2lazy's Avatar
okay, I lied, 20 degrees is good. Then it comes down to setup.
Understeer on a XRAY XB8.. HOw to fix it? Mpowerz Nitro Off-Road 3 03-03-2008 02:22 AM
Definition of understeer and oversteer imjonah Electric On-Road 10 03-18-2004 02:27 PM
V-one-S Understeer Dishy Australian Racing 11 05-18-2003 08:19 PM
i hate understeer wahturi Nitro On-Road 15 01-19-2003 07:56 PM
How to fix understeer? TRF-Powered Electric On-Road 12 12-19-2001 09:02 PM
