Old 07-21-2003, 02:01 AM   #31
me43's Avatar
acctually
ur supposed to use support blocks and a droop gauge
droop controls how far down the sus. arms can go
me43 is offline   Reply With Quote
Old 07-21-2003, 02:04 AM   #32
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Fix it at hudy and press at the front and measure the high from chasis to the ground??
tkhoo is offline   Reply With Quote
Old 07-21-2003, 02:09 AM   #33
me43's Avatar
wen measureing droop
detach your shocks
then place ur car on the support blocks
then slide the droop gauge underneith each sus. arm to measure it
Old 07-21-2003, 02:11 AM   #34
me43's Avatar
take off ur tires as well
Old 07-21-2003, 02:14 AM   #35
tkhoo's Avatar
OK u mean fix the car at Hudy and take out the shock and measure from chasis to ground?? Take out front and rear shock??
Old 07-21-2003, 02:17 AM   #36
me43's Avatar
no not from the chassis
from the end of the suspention arm
and yes take off all the shocks and wheels
Old 07-21-2003, 02:21 AM   #37
me43's Avatar
http://www.rccaraction.com/rc/articles/setup.asp
look at the pic right above final thoughts
Old 07-21-2003, 02:53 AM   #38
tkhoo's Avatar
I don't have the guage that put under the car........ so, may I know how high that guage? Maybe I can use allen key to replace that guage. As for the shock, it look like no disconnect the shock. Pls advice.
Old 07-21-2003, 03:10 AM   #39
me43's Avatar
either way works
but i would rather take the shock off
Old 07-21-2003, 03:12 AM   #40
tkhoo's Avatar
may I know how high the support block?? I follow your advice...........take out the shock.
Old 07-21-2003, 03:25 AM   #41
me43's Avatar
bought 1in. x 1in.
i use my old cassest player(very slim bout 1in. high)
and a ride height gauge
Old 07-21-2003, 03:25 AM   #42
me43's Avatar
Originally posted by me43
bout 1in. x 1in.
Old 07-21-2003, 09:16 PM   #43
Im2lazy's Avatar
While the way in which me43 is telling you how to adjust droop is the standard for droop adjustment... I absolutely hate it.
Uptravel is a much more easily understood and more precisely measured adjustment. It does the exact same thing, but takes into account factors that are not of any concern with a droop gauge (very bad part of droop gauges IMO) such as shock length and inconsistent parts height (by that I mean parts marred by crashes and shaved by flexible rims). You can set a car to have ___ amount of droop, but once you put the shocks on, it is possible that the length of the shock will not allow for the amount of droop you wished to have, and if you do not measure up-travel, you will never know why you're car acts so strangely.
Here is how to measure up-travel... and since you have a hudy setup system and a ride height gauge (that I take for granted here), you just measure the difference in height between ride height and full extension.
An example taken from my car:
My rear ride height is 5.5 mm. I want the car to have 1.5 mm of uptravel so 5.5 + 1.5 = 7mm at full extension. However, with tires, it can be tricky if you use rubber tires or un-trued foams so I suggest you adjust ride height normally (pressing down on the car so it bottoms out, which sets the car. Then you take the ride height reading). Then you put on the setup system. You put it on the flat board as you usually do, and measure the distance from the chassis to the board. You take that number and add 1.5 mm (I.E. 7.5 mm + 1.5mm = 9 mm) so you now want to lift the rear of the chassis and see where it is at full extension. Adjust the droop screws until the both rear setup gauge lifts up at 9.1 mm and exactly the same time.
That was very long, but the reason I went over it is that there is a possibility you will want 1.5 mm of uptravel, but no matter how far you screw out the droop screws, you can't achieve it. There could be several reasons and the most common is too short of a shock length. Thread out the lower eyelet and measure again until you achieve the desired uptravel.
Im2lazy is offline   Reply With Quote
Understeer on a XRAY XB8.. HOw to fix it? Mpowerz Nitro Off-Road 3 03-03-2008 02:22 AM
Definition of understeer and oversteer imjonah Electric On-Road 10 03-18-2004 02:27 PM
V-one-S Understeer Dishy Australian Racing 11 05-18-2003 08:19 PM
i hate understeer wahturi Nitro On-Road 15 01-19-2003 07:56 PM
How to fix understeer? TRF-Powered Electric On-Road 12 12-19-2001 09:02 PM
