Kyosho V-ONE RRR EVO 2
#1366
wear? remember I set my gear mesh until it grinds but spins freely and then I wear the gears in on the first run. I still get hours of time out of them this way. I don't think the gears have enough of a difference in size to really matter, gear for your engine and work with the rest. My IDM engine will happily pull 17/59 on all but the shortest tracks where I will go to a 60 or 61 with the same 55 or 56 spur, all without changing the gear mesh.
I must test it, up to day I only use two sets for my tracks, maybe there is time
for more play with gears
Regards!
m.
#1367
.08 Modular Gear System
Somebody out there correct me if I'm wrong, but, I believe a few years ago that Serpent (gets credit for this), introduced the .08 Moduler gear system which is esentially, the spur and pinion gears of their respective locations (1st pinion/spur OD are the same, 2nd pinion/spur OD as well proportionally, are the same). Therefore, or in other words, it is OK to mix and match gear combos regardless of whether the # of teeth for 1st and 2nd gear ratios = the same #'s. At any rate, I've used various nonconventional combos with no problems, however, setting motor location is very important. I set it tight, then run the car with no load (on the starter box) for a few minuetes, and listen to the transmission, then shut it off, recheck mesh, readjust if necessary.
#1368
Nice info, I wasn't sure where it started but I know Xray claimed something like that in some of their original marketing and the Kyosho seems to be the same to me or at least it doesn't make enough of a difference to matter. They supposedly vary the pitch of the gears since we have such a large pitch you can go plus or minus enough to get a few teeth and still have the overall diameter the same and still get a reasonable gear mesh. I will admit that my 1st gear pinion wears quite a bit faster than my second but then I only use 2nd gear on two portions of the track otherwise it is free to spin so perhaps that is where the lack of wear comes from.
#1369
I have two rrr's wc if anyone is interest in parts or a full roller let me know
#1370
OK, question for you all. I have to get a new chassis after I "adjusted" it at the GLC. Which does everyone like better, Evo or Evo 2?
#1372
#1375
The NiMH pack is usually 84mm x 29.3mm x 17.1mm
There is a reply a few pages back that lists all lipo packs that
suit the RRR
#1376
I have been over the idea of using LiPO in my RRR and have
a question about the chassis.
I have a shimo chassis (no battery tray) and was wondering if it is heavy enough for use with LiPO or should i use my standard chassis and get a Brass
battery tray ?
Thank you
battery tray ?
Thank you
#1377
I remember seeing a post about how to get more rear traction on the RRR Evo WC. But I can't find it. I'm suspecting that i have to rebuild the car and go w/ a lighter diff fluid and lay the shocks down a little towards the center of the car.
Any sights with setup sheets for the RRR Evo?
#1378
sorry about the noob question but does the evo only use 2mm offset in the rear or all the way around? I was reading only in the rear of the car but was unsure.
#1380
Dont you mean longer dogbones and screw the pivot balls out?
