Old 07-28-2009, 12:37 AM   #1351
barg's Avatar
Send a message via Yahoo to barg
Anyone know where I can get VZW024v-8 Titunium pivot balls in a hurry?
Ive looked everywhere......
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 07-28-2009, 03:10 PM   #1352
rc-mushroom or ebay
Like this???
Hope this helps!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-28-2009, 04:14 PM   #1353
or try here.
http://www.rc-toro.com/product_info....4454f3d4ee08ad
silverM3 is offline   Reply With Quote
Old 07-30-2009, 09:32 PM   #1354
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
New hopup part guys!!!
YBLSLOW has a titanium 2 sp shaft. While there are a few other companies that make this part, there is at least one thing that makes this one unique. First it is made out of a very high grade of titanium. It is hard enough that I know Brad has broken more taps when making these things than any other part he does.
Here is the real cool thing about this one (besides the obvious weight savings):
This one has all the flats ground on it if you use the current brake pulley system which is an aluminum brake pulley. It also has all the pinholes so for anybody (such as myself) that prefers to use the older RRR plastic brake pulley setup. It uses center ground titanium so it is a good and true diameter. This is one of those hopups that is not only a weight savings up higher in the car, but it is also rotating weight.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-30-2009, 09:40 PM   #1355
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
i think i have some used once i will have a look and bring it to the track .
Alex S
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 07-30-2009, 11:22 PM   #1356
barg's Avatar
Alex S
Thanks Alex, I found some but they are a couple short.
Kyosho only sell the 2 pack now. The 8 pack has been discontinued.
Are you guys coming to Moorebank on Sunday?
www.nswrcrcc.com
Old 07-31-2009, 02:55 AM   #1357
yeah me , steven C and rob C are coming down. i dont know about other coasties
well i think i could only find 6 myself. anyways i bring them with me .
Old 07-31-2009, 03:22 AM   #1358
Why do you think that Kyosho discontinued the 8 pack? I am not saying you are wrong, because I don't know but that makes no sense at all.
Old 07-31-2009, 05:35 AM   #1359
barg's Avatar
Well no one has them anywhere and one co in Japan I asked said they were discontinued. I could be wrong. Its just what they said.
www.nswrcrcc.com
Old 07-31-2009, 05:37 AM   #1360
barg's Avatar
How much are they worth?
www.nswrcrcc.com
Old 07-31-2009, 11:01 PM   #1361
prg
Hi Guys
Can anyone tell me if using a 17t 1st pinion and and a 23t 2nd pinion will strip gears spurs are 55 and 59.
peter
prg is offline   Reply With Quote
Old 08-01-2009, 07:02 AM   #1362
barg's Avatar
Originally Posted by prg View Post
Hi Guys
peter
It shouldnt. I havent run 59 ive run 60/55 17/23 with no problems. Its all about the mesh. On the kyosho you need to run your mesh as tight as possible without it binding. There should be no play between the pinion and spur as long as it spins freely.
Give it a try.
www.nswrcrcc.com
Old 08-01-2009, 01:56 PM   #1363
Hi Guys
peter
I ran 17/59 and 23/55 earlier today. as barg said, you need the mesh right.
To me, right almost sounds like it is binding when you spin the gears but they spin free. they will wear in but it seems extremely tight.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-03-2009, 06:56 AM   #1364
Hi Brian!
You wrote that 17/59 and 23/55 you have run, but:
17+59 = 76
23+55 = 78
and 76 != 78 ...
They are mesh right without wear?
For me better is 17/61 and 23/55 that I test and no wear ...
I ask because I'm a little curious :-)
m.
Michal Abramowicz
Old 08-03-2009, 07:32 AM   #1365
Originally Posted by M.Abramowicz View Post
Hi Brian!
17+59 = 76
23+55 = 78
and 76 != 78 ...
m.
wear? remember I set my gear mesh until it grinds but spins freely and then I wear the gears in on the first run. I still get hours of time out of them this way. I don't think the gears have enough of a difference in size to really matter, gear for your engine and work with the rest. My IDM engine will happily pull 17/59 on all but the shortest tracks where I will go to a 60 or 61 with the same 55 or 56 spur, all without changing the gear mesh.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
