Old 07-12-2009, 06:37 AM   #1321
Team-RTR's Avatar
when using the front diff, will the evolva M3 style ackerman plate still hit the front diff? running an original RRR and wondering if i should convert to evolva ackerman plate to run the front diff.
Team-RTR is offline   Reply With Quote
Old 07-12-2009, 08:47 AM   #1322
dameetz's Avatar
Yes it will touch, stay with the old one if you want to use diff.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-15-2009, 03:13 PM   #1323
ALG
Originally Posted by HoboShop View Post
my evo 2 wc with only ti pillow balls is under weight. The evo 2 wc is a light car out of the box you shouldn't have to take away any weight. 1727 with over-sized tires.
kyosho evo 2 wc
jp eagle tl3-t
jp 2620 pipe and manifold
futaba 9451 brushless servos
3.1 stratus
2d clutch 4 flyweights
personal transponder
hopups:
ti pillow balls
alu brake lever arm
alu middle shaft mount
weight 1727 with oversized tires.
your car is light enough trust me
Ti pillow balls are GREAT diet helpers.
Have fun
ALG is offline   Reply With Quote
Old 07-15-2009, 05:44 PM   #1324
Hey guys if you want a weight reduction and you run a spool try using the spool from the V One S111, its plastic, I ran it with no problems, that must shave off a few grams, and while I'm here anyone got any quick fixes for a loose rear end, I have to be careful exiting turns as my rear tends to loose traction and spin around, i currently run 30k oil in the rear diff, any one line answers would be great.
B.C.Ninja is offline   Reply With Quote
Old 07-15-2009, 06:37 PM   #1325
el salvador's Avatar
Default B.C.Ninja
1. Disconnect rear sway bar.
2. Put 10k lube in rear diff, (only fill it about half full).
3. Move lower arms hinge pins closest to chassis plate.
4. Softer Shore rear Tires. (all recomendations for low traction situations in no paticular order).
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 07-15-2009, 09:25 PM   #1326
more rear toe-in can help, up to around the 4 degree range is fine.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-16-2009, 02:18 PM   #1327
Cheers for the quick info guys I will try it out for this weekend, also just wondering if anyone else was dissapointed that the Evo2 WC didn't have the fancy white writing on the upper deck like in all the photos, I like my bling you see.
Old 07-16-2009, 02:23 PM   #1328
Just to let you know about the low traction conditions for our track, we race in a car park next to a beach surrounded in pine trees, MMMMmmmmmmmmmmm thats all class really.
Old 07-16-2009, 03:17 PM   #1329
I don't think they could get it to stick to the carbon cheaply enough to make it worthwhile. I have the KM top deck that had a logo on it but the first fuel to spill on it took care of that. The JLR logo on the side of those black starter boxes comes off with fuel too. If you don't cut it, it won't stay on.
Old 07-16-2009, 07:05 PM   #1330
barg's Avatar
Send a message via Yahoo to barg
Questions??
Originally Posted by Scott Fisher View Post
I am about to walk out the door to go to the airport, but I will give some insight. A LOT of titanium and some aluminum.
Ti Pillow balls VZW024V -8 ?
Ti hinge pins
Ti 2-sp shaft
Ti front shaft
Ti upper screws
Futaba 9452 and 9551 servos... There is a lot of weight there.
Shorten servo wires
Alum front spool
Ceramic bearings (I dont really use them anymore though)
Lipo battery (1300 mah)... Bigger battery is totally unnecessary... and yes I use a Novak regulator and an on/off switch.
Small/light receiver: I use a Spektrum 3520
Hi Scott,
Can you confirm the part numbers for the titanium bits? Are they Kyosho parts or after market?
Thanks.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 07-16-2009, 08:34 PM   #1331
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
That is the correct part number. It is a Kyosho part
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-21-2009, 06:19 PM   #1332
Does anyone know where I can get a VZ228 (evo rrr) main chassis? I do not want the evo2 chassis. Thanks for any help.
Anthony Andrews
laptraffic is offline   Reply With Quote
Old 07-21-2009, 06:29 PM   #1333
Default VZ228
KYOSHO America has limited quanties, $92.00
Old 07-21-2009, 07:15 PM   #1334
Get it here. Less money and a good hobby shop.
http://ashfordhobby.com/SearchResult...KeyWords=vz228
Old 07-21-2009, 07:53 PM   #1335
Yeah Scott, I thought of Ashford, and Kamikaze, but K-America has it in stock....
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
