Old 07-03-2009, 05:06 PM   #1291
GREGORY!'s Avatar
the only gain that i can think from a 2 mm offset is
1:a bit less flex in the rear.since the pillow isn't so unscrew.
and 2:a bit more side traction from the short arms.
but again i have not see any big difference.
GREGORY! is offline   Reply With Quote
Old 07-04-2009, 02:18 PM   #1292
aizenbelle's Avatar
Smile
if anyone is interested in my RRR WC Novarossi engine and Carbon fiber Vantage tuned pipe let me know
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 07-05-2009, 06:26 AM   #1293
RevMaxx's Avatar
Send a message via MSN to RevMaxx
i know ds has been asked before but just i couldn't find the page...
i just want to know what are d pros and cons of lay-down vs. upright servo for the throttle...
thanks..
RevMaxx is offline   Reply With Quote
Old 07-05-2009, 07:45 AM   #1294
tony montana's Avatar
Trader Rating: 66 (100%+)
I like the up right better only because it is easier to adjust the linkage
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 07-05-2009, 09:34 AM   #1295
dameetz's Avatar
thanks..
The lay down will lower the CG a bit I think compare to the upright but honestly I can't tell the difference when I drive it. For me I like it in upright position (easier to change the throttle servo when you need to and less hassle coz less linkage). I m also using low profile servo which I mounted below the upper deck which should lower the CG a bit and make it look good as it sits flush with the upper deck.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-05-2009, 09:37 AM   #1296
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by MikaR View Post
Yes indeed.
BTW, I replaced the steel pillow balls with Ti ones, substantial weight reduction. Now I'm also thinking of replacing the nimh batt with a lipo. What do you recommend for one? Regulator, too
I sell micro batteries and run a RRR WC Evo 2 and I've found that the car handles better with the NiMH than with the Lipo. I put a Lipo in and switched back. I'm not so sure there is an advantage to Lipo in this car as I get a whole day of racing from one charge of my 1500 5 cell receiver packs. I currently only have 900mah Lipo packs for the gas cars, but I am having some 1900's made in the same dimensions as a 5 cell side by side NiMH receiver pack to see if it is enough weight to make the car feel better.
If you are going to use a Lipo I would suggesting something in the 1000mah or better range with a 4a regulator on it. Today's servos with 200+ oz/in of torque pull quite a bit of juice from the packs when you are at full brake or you have something binding your steering (like another car or the wall in my case hahah).
Some links and info:
Well soldered 5 cell pack with wires routed along the side
85mm
| | | | | | 32.5mm
and 17.4mm tall with shrink, remove .1mm if you don't have shrink on your receiver pack.
My packs are not ready yet, but in the mean time I've had to test a bazillion Lipo manufacturer's products and settled on these and highly recommend them:
Hyperion
http://www.aircraft-world.com/shopexd.asp?id=6597
Common sense rc
http://www.commonsenserc.com/product...products_id=46
IP
http://www.rcmart.com/catalog/rc-bat...?cPath=52_1285
If you want to go cheap (these cells are o.k. but they don't last as long as above before puffing).
Yeah Racing:
This all assumes of course that you are mounting your regulator somewhere else. If you are mounting your regulator in the same compartment as your Lipo pack the most you are going to be able to fit in there is a 1200 or so. It will depend on how big your regulator is and i'd suggest shrink wrapping your regulator and your pack in the same "package" to avoid vibration issues.
1000's last a day or so give or take in a 1/10 like our Kyosho's, the 2200's will last about 3 full days of racing without being charged although i'm sure none of use will leave it that long after being the habit to charge after each heat .
I am working on more information and sharing the research I did fro my company into the deep rabbit hole of NiMH Lipo and LiFe batteries. Keep an eye on www.skyrocketracing.com for info in the near future. Feel free to shoot me battery questions and such via the forum, pm's or my site.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-05-2009, 09:54 AM   #1297
MikaR's Avatar
Thank you for a very comprehensive answer, nice to read.
Based on your writing I'll stick with my nimh pack unless anyone else says otherwise
Thanks again
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 07-05-2009, 04:42 PM   #1298
what is the stock spur gear and pinions on the evo
Old 07-05-2009, 05:03 PM   #1299
beers4evo's Avatar
pinion 16/21
spur 56/61
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 07-05-2009, 09:41 PM   #1300
YmeBP's Avatar
Thanks again
Oh i forgot to mention that the 1500mah NiMH are about 120 grams vs the 900mah lipo at like 40grams.
Old 07-05-2009, 10:09 PM   #1301
THeGame's Avatar
Send a message via AIM to THeGame
thanks..
When I laid the servo flat it smoothed the car out a lot. It also help on high bite with traction rolling...
I would defiantly try it out and see if you like it or not...
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 07-06-2009, 07:30 AM   #1302
this is why you run a 60-70g battery tray, putting the weight even lower than it could be with nimh. if you run certain KO servos/receiver you don't have to run a regulator and get 7.4v power straight through which takes a 0.10 servo down to 0.07 or so.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-06-2009, 08:47 AM   #1303
YmeBP's Avatar
JR just released some high voltage servos as well, and I think HiTech RCD also has 7.4 volt servos. I'm curious about the receivers though, some of these higher voltage servos have up to 500 oz/in of torque, I don't know how many amps that would be but ... it can't be a small number.
I thought about the heavy radio tray. I may give it a shot again with the tray, but the car felt tippy and I would dig into the corners and slow waaay down without that extra 80grams in the belly.
Old 07-06-2009, 09:40 AM   #1304
radio tray or battery tray? my lipo + brass battery tray come out to about 120g total and you can lower the tank some and I still have to use lead on the left side of my chassis.
Old 07-06-2009, 11:51 AM   #1305
YmeBP's Avatar
Battery tray sorry about that, had radio tray on my brain . Who makes the brass trya you use? I was thinking of having a steel one milled.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
