Old 06-09-2009, 01:06 AM   #1231
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by MikaR View Post
By "locker" you mean the spool or the oneway? thanks
the term locker means locked front diff..... spool
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-09-2009, 03:28 AM   #1232
MikaR's Avatar
right, thanks!
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-09-2009, 04:17 AM   #1233
corney_01's Avatar
Just like yesterday the guy who smashed us all in the final ran a locker[/QUOTE]
Yea but gregs a robot he could run 3 wheels on his car and some how finish in front lol
but wat i did notice in the heats when me and greg would get on the straight together he would have to get off the gas on the bend as i was able to still be on the gas. Another thing i noticed greg carried more corner speed with the locker i thought.
When me and dad went to whalen the diff felt alot quicker but we will have to see the lap times.
Are you going to whalen this weekend?
Comen back with..XRAY-KO PROPO- NOVAROSSI
corney_01 is offline   Reply With Quote
Old 06-10-2009, 05:18 AM   #1234
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Are you going to whalen this weekend?[/QUOTE]
Diff the way to go at least on gosford track , how ever i had a shit day , long weekend away and the 6 hour drive back home got the better of me with my setup . didn't realize till i was driving back home i was running whalan gearing. ... should have listened to green machine when he said i was too slow to what he has seen. oh well there is always a next meet.
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 06-13-2009, 07:35 AM   #1235
beers4evo's Avatar
Default front diff
hey guys, i just installed the front diff. using old ackernman number 10 and seems to be turning freely without hitting the front diff. When i connect the toe arms connectors to the ackernman they rub against the diff!! argh =( does anyone here have a solution or had this problem with a fix? please let me know.....advice please guys! thanks in advance!
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 06-13-2009, 07:44 AM   #1236
GREGORY!'s Avatar
grid them.the diff or the ball ends.it's not a big deal.
GREGORY! is offline   Reply With Quote
Old 06-13-2009, 08:04 AM   #1237
YmeBP's Avatar
Trader Rating: 32 (100%+)
I just ran the car i have a strong servo in there. I figured it would wear in the perfect amount by itself.
Now i'm having some issues adjusting the brakes. has anyone shortened the stock brake rod to get more brakes?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 06-13-2009, 11:12 AM   #1238
Sounds like you need to tighten the two screws that hold the brake pads to the bulkhead. That assumes you have your linkage and your endpoint setup properly. You shouldn't need to shorten the brake arm.
Old 06-13-2009, 12:04 PM   #1239
kest's Avatar
Trader Rating: 1 (67%+)
Yup..thats the answer...i had the same problem before. just a few turns on the screws and..Whallah..!! problem solved.
K..Y..O..S..H..O..I..S..H..O..B..B..Y
JBRCC
BCRT
kest is offline   Reply With Quote
Old 06-14-2009, 02:40 PM   #1240
LowBoost's Avatar
Trader Rating: 63 (100%+)
Anyone knows where I can order the Atomic box in US?
http://www.rcatomic.com/atomic/index...emart&Itemid=1
Also the brake lever in blue aluminum?
LowBoost is offline   Reply With Quote
Old 06-14-2009, 03:20 PM   #1241
Kyosho makes the brake lever in blue aluminum
Old 06-14-2009, 05:38 PM   #1242
Try hkshobby.com They carry many Atomic parts.
andy4 is offline   Reply With Quote
Old 06-14-2009, 07:36 PM   #1243
beers4evo's Avatar
hi guys what would you consider your car being heavy if the minimum weight requirement is 1725grams without fuel and including transponder...?
Mine is 1757grams and I consider that heavy....
Also, what parts could be used to lighten the car?
thanks!
Old 06-14-2009, 09:35 PM   #1244
thanks!
1757 to 1725 could be the height of your tires, you want to be around 1725 with 57 and 55mm tires (or the lowest you normally go for a main) although I have liked my car better on certain track conditions in the 1800+ range. Remember this is with your body, full ready to run without fuel. so you can count tire dust too
from least to most expensive
twister pro-light wheels, around 3-5g per wheel of rotating mass over most others especially if you get the kyosho style.
titanium screws, not sure how much but I grabbed a hand full of steel and
titanum, and it was drastic but keep steel in the front and on things you need strength on.
titanium pivot balls are worth quite a bit
ybslow aluminum spool
lipo + regulator, you can save 50+ grams here (I run a brass battery plate from ybslow that is 68g under a lipo)
KO 2413 servos. half the size and worth 10 grams each I believe. half height servo is a perfect place for your lipo regulator to attach to the bottom of
also, various pipe/engine combinations can play a major role. any of the pipes with the stinger saver are heavy.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 06-18-2009, 07:18 AM   #1245
Hi guys.I bought my new Kyosho Evo2 WC kit.But setting data is Japanese.
Has anyone got English version?
mydo84 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
