Old 05-19-2009, 05:27 PM   #1126
blount's Avatar
Originally Posted by jiggamacdaddy View Post
Is there a gear set chart that list the different gear sets based on track size?
I ask mainly because i dont know which gears to get get for 301 raceway and my home track.
For 301 you want to go with 17/60, 23/56 or 22/55 depending on your motor and tire size for quals or mains and tire wear that day.
blount is offline   Reply With Quote
Old 05-19-2009, 05:28 PM   #1127
beers4evo's Avatar
oh yeah forgot to mention i've used the castor clip (the tool with the hook on the end for the header springs), didn't feel at ease, and don't have a nice allen wrench to fit in the hole, but i have tried the body clip which i figured that on my own and works perfect in the meantime
NOTE TO SELF, don't curse the setup of your car when your understeering on the track...REMEMBER TO TAKE THE BODY CLIP OUT of the front toe hole.
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 05-19-2009, 05:32 PM   #1128
would anyone happen to know what to what gears to use for the sugar bowl in georgia?
jiggamacdaddy is offline   Reply With Quote
Old 05-19-2009, 05:38 PM   #1129
blount's Avatar
I'm not the SME with RRR at the bowl but, I would start with 16/61 21/55 as a start. I think that come stock!
Old 05-19-2009, 08:09 PM   #1130
corney_01's Avatar
Originally Posted by corney_01 View Post
hey does kyosho make a front lola body post mount 4RRR or will the m3 one fit
Thx. steve
AnyOne?
Comen back with..XRAY-KO PROPO- NOVAROSSI
corney_01 is offline   Reply With Quote
Old 05-19-2009, 09:43 PM   #1131
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Scott Fisher View Post
It has been over 2 years since I built mine so I am sure I am forgetting some stuff: Get two rear shock towers, and glue them together. Run that doubled up version on your car. I also use RTV blue to seal my diffs. Some people say they never have leaking issues, but mine did so now all my diffs are sealed with RTV. When screwing the rear shock tower to the car, use a very long screw. When attaching the rear camber link to the rear hub carrier, use a longer screw than what the manual says. If I remember more I will say and my guess is that others will chime in as well.
Thanks for the tips!! Is there a way to change the front drive from a one way to a diff/spool without disassembling the whole car? Also any must have hopups? I think i'm going to get an nt1 radio box as the current one makes me nervous that i's just hanging out in space.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-19-2009, 10:39 PM   #1132
barg's Avatar
Send a message via Yahoo to barg
hey does kyosho make a front lola body post mount or will the m3 one fit
Thx. steve
Yes there is a Lola bumper and body mount. I think it is off the RR.
Rick Bart will probably have them in stock.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 05-19-2009, 11:07 PM   #1133
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
To change over the front axle is somewhat of a job, but not bad if you have a small cordless screwdriver. Take the radio tray off and I take apart the front end as well. It doesn't take that long once you have done it a few times. If you think you are going to run a diff sometimes, I would use the older ackerman plates. The Evo 2 uses the one off of the M3 car. You kit probably came with the older ones. Start with the #11. I have not run a radio box in about 5 years, but if you feel better using one, go ahead. The only downside is the extra weight.
Must have hopups? Probably not, but there are benefits to some of the hopups. I don't know if your car came with CVD's but if it didn't, I would run them in the front. For racing applications, if you run a spool, the YBSLOW front spool is less than half the weight of the steel spool. I wouldn't use it all the time as it will wear more quickly, but when you are serious that is the time to go for it. I really like the convenience of clamping wheel hexes. I use the ones made for the Team Magic G4. The Kyosho SP belts free up your drivetrain quite a bit. APP brake pads are a good upgrade. I would also pick up some steel pinions (at least first gear pinions).
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-20-2009, 08:56 AM   #1134
GREGORY!'s Avatar
i change the front drive without disassembling the radio plate.
i just unscrew the middle axle unit and take of the steering rod.
it is quicker!
GREGORY! is online now   Reply With Quote
Old 05-20-2009, 01:26 PM   #1135
YmeBP's Avatar
it is quicker!
would that be the front layshaft assembly?
Thanks for the tips, the evo 2 wce comes with a one way and cvd's i bought the guts for a diff, another evo driver at my track suggested thats the way to go. I'll have to look into the belts and brake pads and clamping hexes.
Old 05-20-2009, 07:33 PM   #1136
YmeBP's Avatar
Originally Posted by Novarossi View Post
Hi Mate,
The front/rear housing comes together in a set.
They use the same bevel gears, but use different outdrives (VZ218 are the outdrives used for the front Diff)
You also need to use the older servo ackerman arms (they come standard in the EVO2 kit)
Also, you need to use ball ends on the ackerman to prevent it rubbing with the diff.
To be honest, it took some time for me to get the diff into my EVO2, and working fine.
I only got to test it once at Moorebank with 100k oil, but I must say the car did feel much easier to drive, and I am sure with a few minor tweaks and an adjustment to my driving style (going from solid to diff) the car would be quicker.
Check this topic a few pages back, someone posted the parts required.
When you say old servo ackerman arms which ones do you mean? On my parts tree i have three one marked 10, 11 and 12. Is the 10 the one i want to use?
Old 05-20-2009, 09:02 PM   #1137
All of those are the older ackerman arms. The EVO 2 also comes with the ackerman setup from the M3 car which is what the instructions will tell you to use. I would use the #11
Old 05-20-2009, 09:10 PM   #1138
corney_01's Avatar
does anyone know how many teeth are one the rear diff gear.
Steve
Old 05-20-2009, 10:22 PM   #1139
GREGORY!'s Avatar
Steve
rear diff 42 teeth
front diff 27 teeth.
what are you trying to do?
put a nt1 diff in the rrr?
Old 05-20-2009, 11:54 PM   #1140
corney_01's Avatar
rear diff 42 teeth
Yea i got a nt1 front diff im putting in my rrr and just wanted to see if the rear would work
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
