Old 05-14-2009, 07:41 PM   #1111
corney_01's Avatar
hey im after a more snappy clutch set up with the 2d
Would i get this with the grey shoe or the red wouldnt the grey alow it to slip abit more thx
Steve
Comen back with..XRAY-KO PROPO- NOVAROSSI
corney_01 is offline   Reply With Quote
Old 05-14-2009, 07:55 PM   #1112
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Originally Posted by blount View Post
Ok, thanks! The time that I did use the 24t with 384 belt in toledo I didn't notice much difference in handling. I will campare lap times this wknd at 301.
let me know how thing workout....
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 05-14-2009, 10:53 PM   #1113
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
double post
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-14-2009, 10:53 PM   #1114
Steve
I don't know what engine you are running, and how it is tuned, but try this clutch setup.
2D clutch with 4 flyweights. Use the grey shoe. Use the stock spring and tighten it down to 1.3mm past the flywheel nut. (1.3mm of thread showing). Set the gap at .4mm. Set endplay with just enough to keep it from binding. If you still need more punch, add .1mm of endplay. If that isn't snappy enough then you need either a better engine setup, or it isn't tuned right.
Old 05-15-2009, 08:19 PM   #1115
Originally Posted by beers4evo View Post
So what parts do I actually need?
i have front diff housing (comes with evo2 kit) - do i need anything else like small screws? and the circle ring that sits inside the diff?
vz218 ?
vz219 ? do they come with 2 x 11 pins?
vz012 ?
bs107 ?
thanks.
My bad it is the vz218 not paying attention...The long ones yes they do come with the pins
and maybe 4 2.6x8 screws for the case if you don't have extras
Done and Done
calicool is offline   Reply With Quote
Old 05-16-2009, 05:39 PM   #1116
ALG
Hi guys,
Just come back from testing my new EVO 2 WC, my last car was aTeam Magic G4, just i can sat WOW!!!!!!!!!!!!!
Im using stock setup and the car is very good BUT I have a problem on the sweeper, it break loose the rear when pushing hard. any idea how to solve it?
Im using spool, and 15000 on the raer diff, everything else is STOCK. weight of the car is 1730gr. body STRATUS
Regards
ALG
ALG is offline   Reply With Quote
Old 05-18-2009, 09:54 AM   #1117
jeff1's Avatar
Questions??
Hi Scott and other experients drivers
my car has considerable play on arms shaft. It almost new 1 gallon and has it since I builded. I have noticed that others RRR have this play too.. Should I place some washers to remove this or let it? No one have consensus about. I have some says it helps the car handling on bump surface
jeff1 is offline   Reply With Quote
Old 05-18-2009, 10:26 AM   #1118
I shim my car to remove that slop. I doubt it makes a big difference either way, but really you should want the suspension to absorb the bumps.
I use armature washers from my electric racing days as shims.
Old 05-19-2009, 03:50 AM   #1119
corney_01's Avatar
hey does kyosho make a front lola body post mount or will the m3 one fit
Thx. steve
Old 05-19-2009, 05:01 AM   #1120
aizenbelle's Avatar
If it does not affect your driving leave it alone, my does that too. I see a bunch of people always in the bench tweaking away rather than racing. if you already have a good setup just get the tires on the asphalt and let the car do what it was supposed to do "Race"
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 05-19-2009, 05:44 AM   #1121
beers4evo's Avatar
hey guys, i was wondering what tool you guys use to adjust the toe for the front? these are not adjustable rods, these are the rods that come with the kit and has a hole in the middle. i've just been using pliers as i don't have a tool to use to put through the hole....let us know...thanks
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 05-19-2009, 07:26 AM   #1122
mcsquish's Avatar
I used a small allen wrench or exhaust spring tool (it has a hook at the end for ataching the headder springs, or any other hook type springs) AE makes one Hudy makes a nice one of course, EDS has nice one also.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 05-19-2009, 09:20 AM   #1123
i use a body clip
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 05-19-2009, 10:04 AM   #1124
Speyederjedi's Avatar
I use an L shaped pick which almost looks like a dentist's pick. Real easy to use in adjusting the tow. I have even drilled a hole in the rear camber links so I can use the pick to adjust the rear camber.
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 05-19-2009, 12:16 PM   #1125
Is there a gear set chart that list the different gear sets based on track size?
I ask mainly because i dont know which gears to get get for 301 raceway and my home track.
jiggamacdaddy is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
