Old 05-13-2009, 10:07 AM   #1096
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Originally Posted by blount View Post
I was running the solid. Did you notice anything different with the way the car handled?
Yes I did notice a big difference, on & off power push with the solid with the diff no more push try it out when u go testing at 301...
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 05-13-2009, 10:28 AM   #1097
blount's Avatar
That's not good! If that happens I will put the 23t back on. Did you have the push on a high bite track?
blount is offline   Reply With Quote
Old 05-13-2009, 01:02 PM   #1098
GREGORY!'s Avatar
can someone post the standard set up from the evo 2 wc?
thanks.
GREGORY! is offline   Reply With Quote
Old 05-13-2009, 03:06 PM   #1099
I Misunderstood what your sayingI was comparing solid & diff, far as 23t versus 24t pulley, The only difference I notice car had faster laps with 23t (2mm split) & 384 middle belt vs 24t (1mm split )& 384 belt I haven't tried the 24t (1mm split) & 387 middle belt yet..
Far as the handling of the car seem the same to me... I think Scott Fisher might be able to shed more lite on this subject he's a sponsor driver for kyosho an has good knowledge on certain aspects of the car.
It's always good to test out different set up packages on your RRR because I found what works for me might not work for you due to driving styles..
Old 05-13-2009, 07:07 PM   #1100
beers4evo's Avatar
hey guys i want to put the front diff in my evo 2, and read back a few pages to get the following parts, but i want to make sure these are the parts,and if theres ANYTHING else i should know or get?
VZ009 - diff casings (i think this has the tiny screws)
92051 - 2x11 pin's
92052 - orings
vz012 - bevel gears
bs107 - steel shafts, you can get these in titanium too
thanks
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 05-13-2009, 07:59 PM   #1101
mcsquish's Avatar
From what I understand, with the 24 pulley it should be a 0mm split.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 05-13-2009, 08:30 PM   #1102
92051 - 2x11 pin's
92052 - orings
vz012 - bevel gears
thanks
you will also need vz218 diff joints which i believe come with the 2x11 pins, you should have got the front diff case and pulley with the kit and you don't need the orings they come with the gear set so
vz218 diff joint
vz012 bevel gears
bs07 shafts
and if you don't have them the 2.6x8 screws
and that should be all you need
calicool is offline   Reply With Quote
Old 05-13-2009, 09:13 PM   #1103
beers4evo's Avatar
Originally Posted by calicool View Post
you will also need vz219 diff joints which i believe come with the 2x11 pins, you should have got the front diff case and pulley with the kit and you don't need the orings they come with the gear set so
vz219 diff joint
vz012 bevel gears
bs07 shafts
One page back Novarossi says
"Hi Mate,
The front/rear housing comes together in a set.
They use the same bevel gears, but use different outdrives (VZ218 are the outdrives used for the front Diff)
Apparently they use the vz218 joints, you say vz219? so which one? can someone confirm.....? thanks
Old 05-13-2009, 11:35 PM   #1104
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
"Hi Mate,
VZ218 are the front outdrives.
VZW211 is the part number for the Titanium Bevel Shaft if you want to save a few grams of rotating weight.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-14-2009, 01:12 AM   #1105
beers4evo's Avatar
So what parts do I actually need?
i have front diff housing (comes with evo2 kit) - do i need anything else like small screws? and the circle ring that sits inside the diff?
vz218 ?
vz219 ? do they come with 2 x 11 pins?
vz012 ?
bs107 ?
thanks.
Old 05-14-2009, 06:42 AM   #1106
mcsquish's Avatar
beers4evo I'm fairly sure this is everything you need:
BS107 steel cross shafts
vz012 bevel gears and other innerds
vz203 front pulley (if you need one)
vz204 diff case
vz218 front outdrives W/ pins
vzw211 TI cross shafts (if you want an upgrade)
Old 05-14-2009, 07:58 AM   #1107
blount's Avatar
Ok, thanks! The time that I did use the 24t with 384 belt in toledo I didn't notice much difference in handling. I will campare lap times this wknd at 301.
Old 05-14-2009, 08:53 AM   #1108
ALG
Default Stratus 3.1 mounting
Hi Guys,
I need some help were to locate the body (Stratus 3.1 and Civic Central) on my new EVO2 WC,
One of my question is, DO i need top trim the front bumper? or do you put the body way front? OR take the bumper, instal the body and then trim the bumper?
That is the reference point to measure?
On the CIVIC boby the only dimples that fit are the ones on the back, and on the Stratus, I dont see any dimples.
Thanks for your help
ALG
ALG is offline   Reply With Quote
Old 05-14-2009, 11:11 AM   #1109
afm
afm's Avatar
Originally Posted by ALG View Post
Hi Guys,
ALG
What happened to your new Serpent????........oye loco, nos vemos el fin de semana.......preguntale a eleasar y al chino wong sobre la posicion de tus bodies
CYA
AFM
afm is offline   Reply With Quote
Old 05-14-2009, 12:27 PM   #1110
Hi Guys,
ALG
Use one of your ideas. Remove the front bumper, and mount the body onto the car. Use the front wheel wells as your refernce point by centering your front wheels into the wheel wells. Then trim your front bumper so that it now fits inside the body. Trim off as little as possible so the bumper supports the front of the body.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
